View Poll Results: which blower cam
jre rough idle 18 21.95%
ecs big blower 7 8.54%
lethal night fury 13 15.85%
texas speed blower 7 8.54%
custom grind 37 45.12%
Voters: 82. You may not vote on this poll
Old 10-04-2013, 11:21 PM   #29
BLACK10
BLACK10's Avatar
We can make custom changes to the NFC to suit your build if needed but we often make 700+rwhp with the NFC and the ECS Kit just as you have. In fact, after ECS we probably install the most ECS kits than any other vendor on this site . They just perform plain and simple!
Old 10-04-2013, 11:48 PM   #30
blake-b
blake-b's Avatar
Drives: Black 2010
custom centri cam for the 377 that made over 1krwhp and another custom turbo grind for the AGP kit being installed by Joe@CPR. I wouldn't sleep as well knowing I didn't try to squeeze MOST of the power out of the combo.
Old 10-05-2013, 03:33 AM   #31
Scourage
Syntax Error
Scourage's Avatar
Drives: 2010 Camaro 2SS/RS
http://www.guerragroup.com/#!camshaft-help/c1mq5
Scourage is offline   Reply With Quote
Old 10-05-2013, 08:39 AM   #32
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Vengeance Racing stage-2
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-05-2013, 10:35 AM   #33
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Originally Posted by SmokedSS View Post
Night Fury.. 557RWHP before, 665RWHP after
Yeah with about 2-3 lbs of boost added..
gnturboray is offline   Reply With Quote
Old 10-05-2013, 12:41 PM   #34
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Originally Posted by blake-b View Post
] I wouldn't sleep as well knowing I didn't try to squeeze MOST of the power out of the combo.
Yea im like that too
ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 10.41@133mph
bct10985 is offline   Reply With Quote
Old 10-05-2013, 08:32 PM   #35
old motorhead
Drives: Maggie blown LS3 vette
A custom cam might better be described as a "personal" cam. No way would I install anyone's secret cam. If I don't know the specs, it ain't goin in. I see some cams used by folks that I think are pretty dumb. Does that make them wrong? Hell no. Wrong for me may be perfect for you. It's all about the combo and what you're wanting the cam to help accomplish.
Cams are one big compromise. You get a little here and give up a little there. The neat thing about f/I is that you don't need a cam that causes your rig to be ill mannered. You can have it all. Great manners and stupid big power. Of course, if an ill mannered cam cranks your tractor, I'm not going to tell you your cam choice is wrong. Just becuz I wouldn't do it doesn't mean there's anything wrong with it. I've had my black car, my convertible, and my stupid big cam. I won't be revisiting any of those again.
old motorhead is offline   Reply With Quote
Old 10-05-2013, 08:58 PM   #36
grocerygetter
instigator
grocerygetter's Avatar
Yup...FI plus a VVT cam is even more friendly....gains everywhere, no losses.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 10-05-2013, 09:17 PM   #37
BLACK10
BLACK10's Avatar
Its at the Same 11psi as before the cam
OP, no matter which cam you choose, having a tuner that knows how to make not only the power but how to make your car drive well is really a huge part of it too.
I had someone recently call me and ask me about the NightFury cam. He was having ECS install their sc kit on his car so there was only one correct answer to give imo........if ECS is doing the install and tuning, it just makes sense to go with their big blower cam. After all its their cam, they are doing the install and they install and tune it very well ALL the time.
Its not always about just trying to sell parts....
Old 10-05-2013, 09:53 PM   #38
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Same Boost for dyno results
SmokedSS is offline   Reply With Quote
Old 10-06-2013, 01:48 PM   #39
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
ECS...
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 10-06-2013, 03:52 PM   #40
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Might be the same boost, but it was using a smaller pulley to do that. If you just added tem cam the gains would be less.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-06-2013, 04:39 PM   #41
MANNYS2SS/RS
I lost 1.5 psi of boost when I installed the cam with the same pulleys.
Old 10-06-2013, 04:42 PM   #42
BLACK10
BLACK10's Avatar
Of course there was a pulley swap to keep the boost the same. It didnt increase the overall psi though. Before cam 11psi, after cam 11psi. The goal was just that, nothing more. We know the cam will drop the boost a few psi so changes were made to keep it at the previous psi. SmokedSS wants the best possible gains to be able to improve at the track.
