Cold Air Inductions
Old 10-13-2013, 01:27 AM   #15
Unreal
Drives: 2006 Z06
Agp shop car with l99 went 10.9@132 tonight in crappy 6000+ da. Not bad.
Nick
Corvette Z06 -1200ish rwhp
Old 10-13-2013, 01:39 AM   #16
DuskED13
DuskED13's Avatar
Drives: 2013 SS Dusk Special Edition Camaro
That is amazing out of the box performance!
If I need more power later on (which I don't lol) I will deff do this before a supercharger
2013 2SS/RS Dusk Special Edition
K&N Typhoon, GMPP Exhaust, Synergy Stripes
DuskED13 is offline   Reply With Quote
Old 10-13-2013, 09:36 AM   #17
Levischilz
Drives: 2012 Camaro SS Transformers Edition
ill double check afr. I watched it on the dyno and it was fine have not got too crazy on it since I picked it up. I do know the timing was only at 14*
Levischilz is offline   Reply With Quote
Old 10-13-2013, 11:23 AM   #18
BUMBLEBEE_SS
BUMBLEBEE_SS's Avatar
Drives: 2010 SS LS3 S200 56/61 AGP TT
6000+ da.? What's that. How many psi were you running?
BUMBLEBEE_SS is offline   Reply With Quote
Old 10-13-2013, 12:57 PM   #19
Unreal
Drives: 2006 Z06
11ish
Nick
Old 10-13-2013, 01:57 PM   #20
BUMBLEBEE_SS
11ish
What's the 6000 da. mean?
Old 10-13-2013, 02:49 PM   #21
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Density Altitude. Physical elevation plus atmospheric conditions calculated in relation to ideal conditions at sea level.
The torque curve is more concave than I would have thought. The S256 is relatively large. Most of the BW stuff likes more pressure ratio.
Still waiting to see an EFR set-up on a v8.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 10-13-2013, 04:27 PM   #22
Unreal
Drives: 2006 Z06
Torque curves have been really dependant on tune and customer wants. Shop car made 740ft/lbs at 3k rpm. Also using a loaded dyno vs unloaded has an effect on the spool up time which makes it look like power comes on a lot later than it does on the street.
Nick
Old 10-13-2013, 04:41 PM   #23
Unobtainium
Fabricator
Yeah, unloaded Disneyjets aren't ideal for turbo.
The shop car has the same turbos, displacement,etc?
I would expect a lower boost set-up on a street car to be very fat mid-low with a good match for sure.
Roto-fab CAI
ARH LT's
393whp L99
Twin Mini's...soon
Permagrin...Always
Old 10-13-2013, 06:33 PM   #24
Unreal
Drives: 2006 Z06
Not 100% sure on which turbos. AGP would have to chime in. I was racing the shop c7 vette, and it was slow. Camaro killed it.
Nick
Old 10-14-2013, 09:52 AM   #25
Levischilz
Well a few things were playing into that graph. A little false knock was making it jump down. Things fit pretty tight and we thought they might be tapping/rubbing around that point. I was going to try alternate motor mounts later along with other goodies and will retune and see how it looks.
Also the car needs 3" exhaust for these turbo's, I would worry about it even less with the s251's but I think it would help even more with these. The exhaust and motors mounts will get done come spring. Already getting down to the 40's here.
I tried to play a little the other day when it was about 65 out was just going sideways lol
Also it would continue to build better imo with a .82 a/r as right now im running .63 which Kevin recommended I swap to the larger but since I already had the kit and was more wanting a street toy I wanted to see how the lower a/r would play on the street. Ill be running more in the mid band than upper on the street.
I was actually a little disappointed at the boost kick in, you can tell that they are there from 2k+ on the street but it does not get wild till about 3500+
Old 10-14-2013, 09:59 AM   #26
Unreal
Drives: 2006 Z06
Its all trade offs. The base turbos kick in crazy fast. You got the bigger ones that will do 1100+ and are making <700. A 3" exhaust will help a bunch though so don't be too worried.
Nick
Old 10-14-2013, 10:36 AM   #27
Levischilz
Ya, thats what I think also. Honestly right now its awesome the way it is. Im not worried at all.
The "only" problem i've had so far is getting someone to play with me once they hear my car :(
I've passed a turbo porsche and a ton of mustangs and a couple rice burners and not getting much love in getting someone to play LOL
Old 10-14-2013, 01:45 PM   #28
Unobtainium
Fabricator
I'm sure it's still a ton of fun.
I was actually saying I would want boost sooner, not more power.
All depends what you want,but most go too big because they think 1000whp will happen in the future. The kits don't seem to be any different.
Roto-fab CAI
ARH LT's
393whp L99
Twin Mini's...soon
Permagrin...Always
