Old 10-15-2013, 11:49 AM   #29
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Well there you go. Now you at least know what to do
Sent from my HTC One using Tapatalk 2
[B]
Old 10-15-2013, 01:44 PM   #30
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Keep that pad as flat as you can on your paint surface. Try not to lean too hard on the edges or the pad edges either. Finally, when you turn off your machine between applications, be sure to leave the pad squarely on the paint surface and wait for it to stop rotating before you remove it from the surface.
Glad it's proceding. Sounds like you're making good progress.
WiSSDiver is offline   Reply With Quote
Old 10-15-2013, 05:09 PM   #31
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Remember the porter cable isn't a rotary. You see people with a rotary buffer using it's edge. Don't. Keep it as flat as you can on the car surface.
AmericanMuscleCars is offline   Reply With Quote
Old 10-15-2013, 06:19 PM   #32
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Ok I just gave a section another try, and there is still micro scratches! I'm pretty sure my technique is good, I'm keeping it flat and going slow. Should I keep polishing and going over the area with one application of polish or should I wipe down after a go, then reapply polish and start over?
ilirg is offline   Reply With Quote
Old 10-15-2013, 06:26 PM   #33
ec1990
Drives: 2012 AGM SS
How many section passes are you doing? A pass is usually defined as going over a block of area usually around 2' x 2' vertically and horizontally once. Expect between 5-8 passes required.
As for the polish, it depends what you're using but after 5-8 section passes, wipe off the area, clean your pad if necessary, then reapply polish, 2-4 dime sized peas.
ec1990 is offline   Reply With Quote
Old 10-15-2013, 09:54 PM   #34
ilirg
ilirg's Avatar
Ahhh, I've been doing 1 pass horizontally and 1 vertically then wiping down. Getting there slowly but surely lol.
For sections of my car that are in pretty good shape, no really noticeable scratches or swirls, can I go directly to the M205 finishing compound?
Old 10-15-2013, 10:01 PM   #35
CamaroDreams07
Drives: Slow V6
Yes
[B]
Old 10-15-2013, 10:03 PM   #36
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
Go to the store get your supply of beer.
My first Camaro I let the dealer clean it up before I took it home,bad mistake.My 11 and now my 13 I instructed them not to touch it.When I started on my first Camaro it was 6 hrs on Saturday and 6 hrs Sunday and hit it again the following Saturday.
What I'm saying is it takes time.Do one panel at a time and take your time.Get it to a point where you can live with it till later.(pop a brew relax)Since you did not have a buffer when you purchased the car you are now seeing and removing all the defects from prior washing and waxings.
You said that the rubbing compound marks are now gone,well you are on the right track to perfecting your paint and technique.When you are done and the compliments start you can pat your self on the back knowing that you did it yourself.
Ohten is offline   Reply With Quote
Old 10-16-2013, 08:32 AM   #37
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Try 4 horizontal and 4 vertical. That's a good place to start with with m205.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 10-20-2013, 06:38 PM   #38
ilirg
ilirg's Avatar
Im ready to give up guys. Ive been doing everything we have talked about until now, and its like nothing is happening, I still have all these circular scratches where I have polished. I have a video that maybe can give insight into what Im doing wrong.
https://docs.google.com/file/d/0B3Kf...it?usp=sharing
Old 10-20-2013, 06:41 PM   #39
midnighter
Drives: nothing
Rubbing compound is just 1000 grit sandpaper mixed with paste.
Old 10-20-2013, 07:36 PM   #40
CamaroDreams07
Drives: Slow V6
You posted a private vid
[B]
Old 10-20-2013, 09:01 PM   #41
AmericanMuscleCars
Harbor freight has a DA polisher for 50 bucks, just get good pads and good polishes, learn from my mistakes.
Old 10-20-2013, 09:04 PM   #42
CamaroDreams07
Drives: Slow V6
He's got a PC. Why would he care about some budget Harbor freight polisher?
[B]
