B&M Racing
Old 10-07-2013, 06:45 PM   #1
Camper
Banned
Drives: 10' 2SS LS3 M6
Experts- need some serious help
Ok, my car is doing some wierd crap between 2500-4000 rpm when attempting to throttle through that powerband. It almost feels like im lossing ignition and will buck/stutter really hard. It reacts better if I just stab it when im in that range but still has a stutter. Its almost nonexistant on the dyno due to being wot at an earlier rpm range(2k) and it will just push through.
Tuner has looked at it 3 times and swears there is a mechanical issue as he has added fuel/removed fuel, advanced timing/removed timing etc. I have replaced plugs, plug wires, coils, throttle body(TPS sensor), checked fuel pressure. Im not sure where to go next... I thought maybe it was in the harness, but im throwing no codes. Help!?
attached is a snap shot of whats going on in the datalog. You can see fuel trims going super positive and Knock going through the roof while pulling 4-10 degrees of timing. We have checked everything physical and cant seem to locate anything causing the knock.
one common I noticed going through my log and reviewing every event is that it happens at the 38-41% TPS everytime no matter what gear
Car is on E85 & meth
Camper is offline   Reply With Quote
Old 10-07-2013, 07:15 PM   #2
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Have you checked anything in the fuel system yet? And have you filled up since the issue began?
When I was involved in the import game E85 was the fuel of choice for lots of STi owners, and a bad batch of corn can lead to symptoms very similar to this.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 10-07-2013, 07:25 PM   #3
Camper
Banned
Ive dropped the filter and it was clean, have also had my ID2000 injectors cleaned. I have been on about 6-7 full tanks of fuel from 3 different stations.
Old 10-07-2013, 07:33 PM   #4
2SS45th
2SS45th's Avatar
Gotcha, I really thought I was on to something there. What plugs are in it?
Old 10-07-2013, 07:39 PM   #5
Camper
Banned
currently BR7ef gapped at .028, previously had TR7ix and did it with them only after head swap/retune.
Old 10-07-2013, 08:20 PM   #6
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Little weird how the map spikes just before you got that big knock
Motion427 is offline   Reply With Quote
Old 10-07-2013, 08:32 PM   #7
Fluidmachine
Drives: Soon to be - 2010 Camaro SS
Have you tried replacing/cleaning the MAP/MAF sensors yet?
Fluidmachine is offline   Reply With Quote
Old 10-07-2013, 08:46 PM   #8
Camper
Banned
Brand new maf sensor. Was gonna swap the map with a known good one tomorrow.
Old 10-07-2013, 08:51 PM   #9
Fluidmachine
Solid plan. Like motion427 said, that little MAP spike just before the big KR kick-in is slightly iffy-looking. Let us know how that ends up going for you.
Old 10-07-2013, 09:39 PM   #10
2SS45th
2SS45th's Avatar
You could also try a warmer plug, if you are mostly just driving the car, try the ZR1 plugs. I had random misfires, car breaking up, coughing, etc. and it went away with the plug change to ZR1s.
Old 10-08-2013, 12:18 AM   #11
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
The timing is probably being pulled due to the knock. I don't really get why your AFR stays the same while your going into boost. It looks like it just stays at 12.5 right through that log.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 10-08-2013, 12:21 AM   #12
Unreal
Drives: 2006 Z06
It isn't hooked up is why. Warmer plug would not solve this. It isn't a slight misfire, it is breaking up pretty badly.
Nick
Corvette Z06 -1200ish rwhp
Old 10-08-2013, 12:30 AM   #13
realcanuk
realcanuk's Avatar
Why log and look for this issue with no wideband. If its lean it would show the symptoms described. Knock and breaking up.
Old 10-08-2013, 03:08 AM   #14
blake-b
blake-b's Avatar
Drives: Black 2010
My car did something similar and it turned out to be a loose passenger head ground... It would just fall on it's face and then pick right back up and buck back and forth.
It doesn't sound like you have the exact symptoms I did but it is something to think about. I replaced plugs and wires in my quest... turned out they were fine.
