Old 10-09-2013, 08:45 PM   #29
Camper
Banned
Drives: 10' 2SS LS3 M6
Originally Posted by Matt @ FSP View Post
I'll be handling some remote tuning on this to try to get it in line. Camper is an awesome guy and I just want his car to run correct.
Look at the narrowbands just drop out, so its going real on the lean side based upon the narrowbands and wideband reporting that Camper has told me. Any situation like that will induce knock of course.
This car can be tuned fine on GMVE/MAF, MAF only or VE/SD only... Just pick one. However as this tuner did, turning off the LTrims and putting it in MAF mode only is definitely not my choice with a blower setup without having multiple bypass valves at this level. You just won't dump the air fast enough to have a steady MAF curve.
Making adjustments on the GMVE in non-custom OS in HPTuners is actually very easy. Use Bluecat's EQ>VE program. The SD tunes take less time because you are only tuning a base VE table, not going back and forth between turning off the MAP, dialing in the GMVE and turning back on MAF...
thats why Im sending my wife to your place
Camper is offline   Reply With Quote
Old 10-09-2013, 08:59 PM   #30
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Originally Posted by Unreal View Post
Canuk, he has a wideband just not hooked into hptuners.
Camper, if it isn't fixed by Sunday bring it over or I'm coming to you.
I found a picture of Unreal...
He's a real ...
Matt @ FSP is offline   Reply With Quote
Old 10-09-2013, 10:14 PM   #31
Unreal
Drives: 2006 Z06
Tuna? I love tuna.
Nick
Corvette Z06 -1200ish rwhp
Old 10-09-2013, 10:19 PM   #32
Matt @ FSP
Matt @ FSP's Avatar
Tuna? I love tuna.
Yes you Toona....
Old 10-10-2013, 03:29 AM   #33
stevieturbo
Drives: Slow
Originally Posted by Camper View Post
Dude, my blower sounds like a jet airplane. I can't hear my motor let alone something that sounds off..
That's why any sensible tuner/technician would use a stethoscope. Dont these guys ever have to diagnose problems ?
That's just basic stuff, not rocket science. You can hear the engine in very great detail, and you'll hear detonation or anything remotely like it far better than any knock sensor ( assuming your hearing is good )
stevieturbo is offline   Reply With Quote
Old 10-10-2013, 07:13 AM   #34
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Actually any sensible tuner would use a knock box on the dyno. With the blowers and exhausts most of these cars have, you wont hear much without it.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 10-10-2013, 08:27 AM   #35
Matt @ FSP
Matt @ FSP's Avatar
Yes any diagnostic equipment you can use is a huge plus. However, after doing this for so many years you also get a keen ear to anything going on, surprised I still have it but my hearing is awesome 12 years later...
Old 10-10-2013, 08:39 AM   #36
stevieturbo
Drives: Slow
And it is those very people who struggle to diagnose problems, because they think technology will do it for them. It would be foolish to rely on a knock sensor, when you already know it is detecting false knock.
Get someone with actual experience solving problems
Old 10-10-2013, 08:43 AM   #37
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
nevermind found it
You found the Problem?
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 10-10-2013, 08:48 AM   #38
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Put the car in power enrichment earlier, I'd bet the problem goes away. I see this from time to time on some na setups with headwork and fast manifolds. Depends on the engine setup really, but at 108 kpa like in the pic you showed, id have it dipping into pe mode.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 10-10-2013, 09:27 AM   #39
Camper
Banned
It appears it was all in the tune as Matt rewrote my tune and we datalogged and made adjustments for over 2 hours last night. We have a slight concern my valves are hanging open due to incorrect pushrod length but we will continue datalogging today and I'll measure pushrods just to be safe.
pushrods are currently a 7.65, I was concerned that was a little long for the application.
239/251; .624/.624 LSL cam and PRC 260cc heads, not milled
Old 10-10-2013, 09:31 AM   #40
JANNETTYRACING
Possible 7.400 is more typical
That is a 1/4 inch difference.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 10-10-2013, 10:09 AM   #41
Rhino79
Rhino79's Avatar
Holy preload!
Old 10-10-2013, 10:30 AM   #42
Camper
Banned
in all my research the PRC 250/255/260 required somewhere in the 7.5-7.6 range. Its an aftermarket casting with the modified angle, deeper pockets and such.
