sjm autoprod
Old 10-09-2013, 03:56 PM   #15
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Anyone needing replacement pulleys has been asked to contact IPF at support@kpe-products.com
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-09-2013, 04:22 PM   #16
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
thanks, will look into this. NOW
Old 10-09-2013, 04:52 PM   #17
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Just checked mine, except for a small fraying area on the engine side about 5 inches long, belt looks good and the pulley's still turn freely (took the belt off the alternator).
Sucks it happened, but at least IPF is taking care of it. Wonder if it would be a worthwhile upgrade to go to an 8 rib system instead of 6 ribs.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is online now   Reply With Quote
Old 10-09-2013, 05:09 PM   #18
JohnnyBfromPeoria
Don't know about that part, GB, but my belt went from near-perfect to shrapnel in ten seconds flat once the pulley locked up. Not sure any belt could withstand that.
John B.
Old 10-09-2013, 05:12 PM   #19
MagnumForceGB
A Chuck Norris belt could handle that with ease.
Old 10-09-2013, 05:31 PM   #20
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Sorry to hear of your misfortune. But it good to hear ipf step up for repairs.
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 10-09-2013, 05:41 PM   #21
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Sorry for my ignorance (haven't seen the IPF up close), but does the pulley have a sealed bearing?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-09-2013, 05:41 PM   #22
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by JohnnyBfromPeoria View Post
It's touching that you have something nice to say about them.
Hahahahaha. Ha.
John B.
I'm glad to hear that IPF jumped in so quickly to get this solved
Proud owner of litho #179 Click Picture for Build Thread
Old 10-09-2013, 06:55 PM   #23
sycraft
COTW 5/06/2013
sycraft's Avatar
Take you bad set and remove the snap ring, go to a bearing supply house and get FAG bearings and replace, then you will have a spare emergency set. get a belt and the tools and you can change all in about 15 minutes if needed. It would be best if these pullys were a little larger to reduce rpm and use a alternator or tensioner bearing. also sealed bearings are better as the metal shielded tend to let out the lubricant and allow dust to enter.
Old 10-09-2013, 07:44 PM   #24
JohnnyBfromPeoria
The new bearings are sealed German units instead of the Japanese bearings that were used initially. I took both of my units in this afternoon and they pulled the snap rings and pressed out the spacers (one on each side) and the two bearings per pulley, then pressed in the new bearings, then the snap ring, then the spacers were pressed in. I was given a new belt as well. The pulleys both seem smoother than they ever were initially. The shop guy that did the work for me (thanks!) said he was the one who had originally put everything together in the first place. I compared the bearings and they are indeed different.
I just have to split the unit and reinstall the belt, but not today.
If you order new bearings, you will need to have a vice and appropriate sized sockets to help do the pressing in and out of the various parts. It's all pretty apparent what to do when you see everything. An 8 mm Allen key removes the bolts that hold the pulleys.
Excellent, excellent customer service from IPF/KPE (the shop that IPF works out of). Today they had a Porsche from Kuwait that had been shipped over for them to hop up, a Panoz (new) and a bunch of other exotic stuff.
John B.
Old 10-09-2013, 08:37 PM   #25
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Thanks for the heads up John! E-mail sent. Since we purchased at the same time, I'm sure I can benefit from an upgrade as well.
Love this forum! We don't take you for granted C5!
Old 10-10-2013, 11:18 AM   #26
KMPrenger
KMPrenger's Avatar
Sucks it happened but the response was great and hopefully these upgraded ones are more durable.
Thanks for sharing!
Old 10-10-2013, 12:05 PM   #27
Ventmaster
Ventmaster's Avatar
Got a same-day response from IPF and spoke with Andy this morning.
He said all purchaser's of the IPF system will be receiving the upgraded bearings.
They are working on a "technical service bulletin" to go with them instructing owners how to change them out.
Evolution Motorsports will be handling distribution and may be contacting owners for shipping addresses.
First rate customer service for sure!
Old 10-10-2013, 03:01 PM   #28
ASH@IPF-TUNING
ASH@IPF-TUNING's Avatar
Drives: 4x4 Turbo
Hi everybody !
the actual replacement bearings we send from our german SKF Factory to the USA ...
These bearings were metric size (35x10x17mm ) with corrosponding to the EU DIN 6003 and they are matching 100% the requirements of the IPF-TUNING sc-Pulleys ... in Temperature range .. horizontal driving force and max RPM Speed !
We will never source these important parts again from the far east ... no constant Quality .. as you see .. some Japan bearings fail never ... some quickly ... so better use the original factory bearings from Germany !
regards ASH@IPF-TUNING
ASH@IPF-TUNING is offline   Reply With Quote
