Old 10-09-2013, 03:01 PM   #1
Jeza
Jeza's Avatar
Drives: 2012 Camaro Rs
HELP! 2O12 CAMARO RS PROBLEMS
I KEEP GETTING THE ENGINE LIGHT, AND WHEN EVER I CHECK GIVE ME THE SAME CODES P00C9 P0092, I GOT HID LIGHTS. WHAT SHOULD I DO BECAUSE I KEEP GETTING THOSE CODES AND ALSO "ENGINE POWER REDUCED" ON THE DASH BOARD !
Jeza is offline   Reply With Quote
Old 10-09-2013, 03:02 PM   #2
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Go to the dealership...
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 10-09-2013, 03:03 PM   #3
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Did you just put on winter tires by any chance?
JR 1 is offline   Reply With Quote
Old 10-09-2013, 03:04 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Interesting, see the below. Something you did with the HID's is causing the issue, are they aftermarket HID's?
http://www.camaro5.com/forums/showthread.php?t=276947
FSP tuned: 377/389
Old 10-09-2013, 03:10 PM   #5
Jeza
Jeza's Avatar
YES THEY ARE AFTERMARKET HIDS !
Old 10-09-2013, 03:11 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
My guess is they are not compatible, take them out and see what happens. Oh and STOP SCREAMING!!!
FSP tuned: 377/389
Old 10-09-2013, 03:12 PM   #7
ssrs2lt
ssrs2lt's Avatar
Drives: too many
I did a quick Google search of those codes and I believe it's light related
ssrs2lt is offline   Reply With Quote
Old 10-09-2013, 03:14 PM   #8
Jeza
Jeza's Avatar
thanks i will try that !
Old 10-09-2013, 03:29 PM   #9
Swacer
Drives: 2012 Camaro 2SS/RS
LMAO HIDs will not give you a check engine light. And since you think they would...you should probably stop modding now hahaha
Go see your dealership, you'll find everything out there.
2012 2SS/RS Camaro~Imperial Blue Metallic~LS3~M6~GM High Spoiler~GM Ground Effect~GM Tower Brace~Heritage Grill~Roto-Fab Cold Air Intake~Stainless Works Exhaust~Stainless Power Headers~VMAX Ported Throttle Body~BTR Stage 4 Cam~BTR CNC LS3 Heads~FAST 102 Intake~1LE 3.91 Gears~LPW Rear Cover~GEN5DYI Spare Clutch Reservior~Barton Short Throw~ShowStopper Side Markers~UMI Performance Trailing Arms~UMI Performance Tunnel Brace~Elite Engineering Catch Can~VMR V710s
Swacer is offline   Reply With Quote
Old 10-09-2013, 03:32 PM   #10
nyrfan
Let's go Rangers!
nyrfan's Avatar
Actaully there have been a couple of people that reported issues in the past with aftermarket HID's, so it's not entierly out of the question. It has to do with a votage change (drop or something like that), or burnt wire, I cannot remember exactly.
These ECM's are very finicky.
FSP tuned: 377/389
Old 10-09-2013, 03:34 PM   #11
Swacer
Originally Posted by nyrfan View Post
Actaully there have been a couple of people that reported issues in the past with aftermarket HID's, so it's not entierly out of the question. It has to do with a votage change (drop or something like that).
Wow...what crap dealerships in that case.
Old 10-09-2013, 03:58 PM   #12
CamaroJoe96
CamaroJoe96's Avatar
Drives: 2013 Full Bolt on LFX M6
Glad you finally found that cap lock button OP!
CamaroJoe96 is offline   Reply With Quote
Old 10-09-2013, 04:03 PM   #13
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Stupid question, if you already had a "RS" why the after market HID's ...
Old 10-09-2013, 04:17 PM   #14
Jeza
Jeza's Avatar
i got a different front bumper and add other lights under the fog lights so i add HIDs on there. not the main ones,
2012, camaro, engine, power, reduced
