Solo Performance
Old 10-10-2013, 08:27 AM   #1
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
Octane question
Hey all, I've been noticing that a lot of our BP stations around here are getting rid of their 93 (10% ethanol) and replacing it with 91 (100% pure)
So my question is, with higher horsepower levels, which would be better? 93 with 10% ethanol or 91 pure gasoline? I run meth as well.
mcdoogle6969 is offline   Reply With Quote
Old 10-10-2013, 10:06 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
You will need to take out some timing.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 10-10-2013, 10:10 AM   #3
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
93 with 10% is less prone to knock than pure 91. Agree with ted, drop the timing.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 10-10-2013, 11:59 AM   #4
Unreal
Drives: 2006 Z06
93 e10 is better than 91 as the two nice guys above said.
Nick
Corvette Z06 -1200ish rwhp
Old 10-10-2013, 12:57 PM   #5
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Nothing 16oz of Torco cant take care of when added to 12-13 gallons of 91
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 10-10-2013, 01:14 PM   #6
mcdoogle6969
Thanks guys
Old 10-10-2013, 02:17 PM   #7
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15STI,'10Expy,'10 2SS/RS M6,'47KB1
Why? Do they start with 93 octane gas and add 10% ethanol? If so, I would agree with the others above. Or do the oil companies factor in the higher octane rating of ethanol and blend it with a lower octane of gas to achieve 93 octane? Not doing the math, but would think that the gas would be around 92 octane for the blend, if that's how it is done, so still better than 91 straight.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 10-10-2013, 02:33 PM   #8
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Actually the specs are about 2 points higher leaving the refinery to leave some margin of error. 93 Amoco Ultimate is 95 when it leaves the blending station in the refinery. The gov't frowns on the octane being below the r+m/2 at the pump.
The ethanol is splash blended at the terminal into the trucks. We refine gasoline and buy the ethanol, prob why BP is getting away from it.
Ultimate USED to be shipped in it's own tankers exclusively when it was still Amoco to keep the quality up, not sure that's the case since BP bought Amoco in '99. Too easy to get some dilution with leftovers (87) in the tankers.
Question for the OP...Do the 91 pumps still say Amoco Ultimate up there? Might be coming from a different refinery.
Iam Broke is offline   Reply With Quote
Old 10-10-2013, 11:40 PM   #9
mcdoogle6969
I haven't checked, I'll have to pay more attention next time. All I know is that 3 BPs that I use to go to for 93 all changed over to this "pure" 91. Which I'm not too thrilled over. I may start putting some race fuel in.
Old 10-11-2013, 05:52 AM   #10
Iam Broke
PHAT B33
Iam Broke's Avatar
You could always splash in your own ethanol with E85 to raise the octane a few points.
There is a calculator online at http://www.intercepteft.com/calc.html to determine the octane/percentage blending your own.
The stock fuel system can handle a 1:1 blend (E47) but you need a tune for anything over around 30% ethanol to keep from popping a CEL for excessive positive fuel trims. The fuel trims adjust for the extra fuel needed after driving a few miles and the fueling carries over into the WOT fueling for positive fuel trims also. I ran 30% E with no issues when I was stock.
Avoid leaded race fuel as it will destroy your O2 sensors over a short time.
Old 10-11-2013, 11:18 AM   #11
mcdoogle6969
I'm far from anywhere near stock. My 02 sensors are tuned out. Running the squash return style fuel system. I'm going to be running two tunes. Ones on pump gas, other is pullied with c16. I'm just trying to figure out what I should run for pump gas. I'm going to have to search around and see if there's any place around here with 93 still.
Old 10-11-2013, 11:21 AM   #12
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Your O2 sensors are "tuned out"? Huh? Not completely; how does the system monitor your AFR? Do tell.
Bye bye, Bumblebee!
Old 10-11-2013, 01:09 PM   #13
Iam Broke
PHAT B33
Iam Broke's Avatar
He could have a speed density (VE) tune and not use the O2's. Guess we should have read his 7 page build thread. :-/
Old 10-11-2013, 01:44 PM   #14
Unreal
Drives: 2006 Z06
SD has nothing to do with not using O2s. He could have the tune locked in open loop. I've seen it before. Not sure why some people do it unless it is a race car, but it is easy to disable closed loop feedback and just run it that way.
Nick
