JDP Motorsports
Old 10-10-2013, 10:18 AM   #1
humblebeast07
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF
Clunking coming from rear end
So im at about 7800 miles(hard miles..burn outs, launches ect) on my 1LE and I hear....notice a "clunking" with the rotation in the wheels. I work at a mechanic shop , so I decided to put it on my alignment rack, raise up the rear end put it in gear (tried 1-4th) and listen from under the car. I found that the rear diff and transmission make a significant amount of noise(lots of random noises from trans and clunk clunk clunk from diff). Im trying to find out if and one else has dealt with these type of issues before removing my headers and intake and bringing it to the dealer. Thanks
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
humblebeast07 is offline   Reply With Quote
Old 10-10-2013, 10:24 AM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I have heard the slop in the drive line from day one if it was not under a load. I consider it normal.
gajagfan is offline   Reply With Quote
Old 10-10-2013, 10:54 AM   #3
humblebeast07
The Beast
I believe its happening under a load also, I just can barely hear it because of the exhaust.
Old 10-10-2013, 10:57 AM   #4
gajagfan
gajagfan's Avatar
I have no noise under a load, and with the nice and quite std exhaust, I would hear it I think. I will say the car has been driven hard, but no burnouts or clutch dumps from any RPM. It does have plenty of no lift shifts on it though, and everything seems fine. You might want to get that checked out at the dealer.
Old 10-10-2013, 11:19 AM   #5
SteveV
Drives: 2013 VR Camaro 2SS 1LE
Have you swapped out the Diff and Tranny fluids? They recommend doing them more frequently if you drive it hard.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 10-10-2013, 11:44 AM   #6
humblebeast07
The Beast
I have not changed the fluids, and I just re listened to it and it is very loud it almost sounds like a rod knock but its not coming from the motor, I believe its from the trans. Im uploading a video now.
Old 10-10-2013, 12:10 PM   #7
humblebeast07
The Beast
your really here it @15-20 seconds
Old 10-10-2013, 12:45 PM   #8
gajagfan
gajagfan's Avatar
Does the sound seem like it is coming from the transmission? I ask because it seems to be the focus of the video.
Old 10-10-2013, 01:20 PM   #9
humblebeast07
The Beast
There are noises from both the trans and diff, but you can feel the clack in the rear end more
Old 10-10-2013, 02:26 PM   #10
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
I sent you a PM. I work for Chevy in the Service dept here locally in the Houston area.
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 10-10-2013, 03:15 PM   #11
Buffman
1LE FTW
Buffman's Avatar
Drives: 2014 Camaro 2SS/RS 1LE Recaros NPP
No not normal at all - get her into the Dr. quick....
Buffman is offline   Reply With Quote
Old 10-10-2013, 03:45 PM   #12
John E
John E's Avatar
Drives: 2014 2SS rs 6M
+ 1
John E is offline   Reply With Quote
Old 10-10-2013, 08:59 PM   #13
humblebeast07
The Beast
Could that be the drive shaft, resonating through the diff and tranny
Old 10-11-2013, 01:18 AM   #14
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Sent from my DROID RAZR using Tapatalk 2
tramtwo is offline   Reply With Quote
1le, clunk, noises, rear differential, rear end
