Old 10-11-2013, 12:17 AM   #1
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
Back pressure question
Ok guys, someone way smarter than me need to help me out with this. I had a big 2003 ford f-150 before my camaro, and I ran true straights; no cats, no mufflers so essentially no back pressure. It caused a head gasket to blow because of the lack of back pressure. My question is will putting things on my camaro like HFC and/or axle back exhaust have enough back pressure to the engine for it to run properly or how would I counteract the lack of back pressure, and make it not cause problems in the long term.
13lstuner is offline   Reply With Quote
Old 10-11-2013, 10:32 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Haven't heard of that issue here on the forums. But I'm not sure how many LFX run straight pipes? I imagine the sound would be awful.
Mods:
Old 10-11-2013, 11:39 AM   #3
13lstuner
13lstuner's Avatar
Haha I don't plan to run straights! Just curious as to the engine and back pressure issues
Old 10-11-2013, 05:05 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Running straight pipes is not "back-pressure-less", perse. It sounds like you were running pipes that were too big. Plenty of guys are running straight pipes on their Camaros with no issues... it just sounds awful.
The Solo HFCs are good, and an axle-back won't change your back pressure at all. And an X-pipe might MARGINALLY change flow. But you shouldn't have any issues.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood
DSX_Camaro is offline   Reply With Quote
2013, back pressure, cats, lfx, muffler
