Jason 98 TA
Old 07-13-2009, 09:31 PM   #1
John68and10
John68and10's Avatar
Drives: 1968 Matching Numbers RS 'vert
Question LS3 M6 Tach not working
Have had my Camaro for 10 weeks now and 1600 miles (have been out of town a lot...). I LOVE IT!!
A couple weeks ago I was leaving work (this is my daily driver) and the tach didn't come up. I turned the car off and restarted and the tach still stayed down (it didn't do the self check or anything - it just laid there), I drove about 1/8 mile and it came to life - I checked these forums and found nothing simialr.
So today same thing - I leave work and the tachs dead - restart the car a few times - no luck - drive all the way home and nothing.
I'll add it to the list of things for my dealer to take care of (add GMPP Catbacks and find the damn spoiler nut that fell off before I lock-tighted them).
I'll give it a couple more days to see if it comes back.
Anyone else have this issue?
OWNER of 2010 2SS LS3 RS RJT
1100,1102 10/29/08
2000 03/16/09
2030 01/09/09 - 02/25/09 not sure what
2500, 3000 03/17/09
3100, 3300 04/04/09
3400 04/08/09
3800, 4000, 4104 04/22/09 VIN: 2G1FT1EW9A9104684
4106, 4150 04/27/09
4200 04/25/09
4B00 04/22/09 - 04/25/09 ?
unloaded 5/1
DELIVERED 5/4
John68and10 is offline   Reply With Quote
Old 07-13-2009, 09:32 PM   #2
DarrenJ
DarrenJ's Avatar
Drives: '67 Camaro ZZ4 & 2010 IOM 2SS
Not an issue with mine.
DarrenJ is offline   Reply With Quote
Old 07-13-2009, 09:45 PM   #3
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
Not yet, keeping fingers crossed. I am also hoping if my car has a bad tranny, that it gives out b4 3 years/36,000 miles. I would have no problem with a recall to fix this supposed problem.
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 07-13-2009, 09:50 PM   #4
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
The power train warranty is 5 years/100K miles.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 07-13-2009, 10:10 PM   #5
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
Man, I feel like I stalk these forums more than anyone else and I don't even have a car on order, lol. There is an issue with the early instrument clusters - the needles are pushed too tight on it or something. Fbodfather confirmed it himself in one of the threads. Unfortunately, you have to search, but whatever, it'll be covered under warranty apparently.
Edit: Here ya go: http://www.camaro5.com/forums/showth...rument+cluster
OUTATIME is offline   Reply With Quote
Old 07-13-2009, 10:46 PM   #6
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Yep...here is the service notice from GM...
SERVICE INFORMATION NOTICE
xTooltipElement
Service Information
2010 Chevrolet Camaro | Camaro Service Manual | View All Bulletins | Document ID: 2291505
#09-08-49-011: Instrument Panel Cluster Needle(s) Stick Intermittently (Replace Instrument Panel Cluster) - (Jun 15, 2009)
Subject: Instrument Panel Cluster Needle(s) Stick Intermittently (Replace Instrument Panel Cluster)
Models: 2010 Chevrolet Camaro
Condition
Some customers may comment that one of the instrument cluster needles becomes stuck at a specific value. This may be an intermittent condition based on the interior temperature of the vehicle. Clusters that are vulnerable to this condition will have the pointer stick at elevated interior temperatures or when the cluster has been operating for a period of time.
Cause
This condition may be caused by cluster needles that were installed too deep on the gage.
Correction
Replace the instrument panel cluster. Refer to Instrument Cluster Replacement in SI. Reprogram the instrument panel cluster using the Multiple Diagnostic Interface (MDI) and Service Programming System (SPS) with the latest TIS2WEB calibrations after replacement. Refer to Instrument Cluster Reprogramming in SI.
Parts Information
Important: DO NOT obtain parts from GMSPO. Contact a GM authorized Electronic Service Center (ESC) for replacement.
To identify the correct part number, use the Global Diagnostic System (GDS) application or remove the unit for inspection.
Warranty Information
For vehicle repaired under warranty, use:
Labor Operation
Description
Labor Time
N4180
Use Published Labor Operation Time
N4199
Instrument Cluster Reprogramming with SPS
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2009 General Motors Corporation. All rights reserved.
Legend is offline   Reply With Quote
Old 07-14-2009, 07:38 AM   #7
John68and10
Thanks for the feedback. I see it may be heat related and both times this has happened was when the car was sitting in 100 degree sun all afternoon...
Sure enough - got in it this morning and its fine.
Next time it happens I'm driving straight to the dealer.
I'm just concerend about damage from replacing the cluster, I do know my dealer has done this before so maybe they got it down now,
1100,1102 10/29/08
2000 03/16/09
2500, 3000 03/17/09
3100, 3300 04/04/09
3400 04/08/09
4106, 4150 04/27/09
4200 04/25/09
unloaded 5/1
DELIVERED 5/4
Old 08-14-2009, 02:10 PM   #8
John68and10
Follow up - took it in and they swapped out the cluster no questions asked. Everything is fine and I LOVE THIS CAR.
1100,1102 10/29/08
2000 03/16/09
2500, 3000 03/17/09
3100, 3300 04/04/09
3400 04/08/09
4106, 4150 04/27/09
4200 04/25/09
unloaded 5/1
DELIVERED 5/4
tach tachometer m6 ls3
Dash gauges not working and clicking noise Tigerrag24 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 26 02-26-2013 03:16 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Edmunds: GM Foreign-Exchange Program: Holden Special Vehicles Getting LS3 Scotsman General Automotive + Other Cars Discussion 5 03-27-2008 01:51 AM
