ADM PERFORMANCE
Old 10-11-2013, 05:09 PM   #1
intensifi
Drives: '12 2LT Convertible
DOT 4 brake fluid recommendations please
I'm about to install the SS Brembos on my 2LT.
I have all the parts or they will be here shortly. So it's time to pick the brake fluid.
I'm planning on DOT4 fluid. The main reason is I live in the hills and deal with pretty steep roads on a twice daily basis.
I see many of the C5 vendors sell Motul 600.
I hear I can't use the ATE blue fluid because of federal laws.
Note: I'll be using Goodridge stainless lines so line decomposition with DOT4 fluid shouldn't be a problem.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 10-11-2013, 05:15 PM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
I plan on going with the Motul RBF600 and will be buying it next month.
I also don't think you can buy the ATE Blue anymore. When the feds jumped in and said it couldn't be blue they and ultimately was only for off road use they decided to stop making it from what I was told.
Proud owner of litho #179 Click Picture for Build Thread
Old 10-11-2013, 05:32 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We use Motul RBF 600 brake fluid in our shop and on all of our track cars including our JDP sponsored NASA road race cars. It's good stuff!
Best regards,
Tyler
888-308-6007
Old 10-11-2013, 06:36 PM   #4
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Castrol SRF is the gold standard by which all other fluids are measured and is the only fluid I use. LCF and RBF cost half as much.
CASTROL SRF
‘Typical’ New Dry Boiling Point = 310C (590F)
‘Wet’ E.R. (Equilibrium Reflux) Boiling Point = 270C (518F)
The ultimate racing brake fluid
Castrol SRF Brake Fluid's unique silicon ester technology absorbs less water than conventional glycol ether fluids and prevents the fluid's high temperature performance from deteriorating. Its wet boiling point of 270C is vastly superior to the minimum requirement of 155C demanded by the current US DOT 4 specification. Its ability to withstand temperatures in excess of 300C and superior resistance to the effects of absorbed water have established Castrol SRF Brake Fluid as the world's premier fluid for the hydraulic brakes used in all forms of motorsport and racing.
Brembo LCF600
‘Typical’ New Dry Boiling Point = 316C (601F)
‘Wet’ E.R. (Equilibrium Reflux) Boiling Point = 204C (399F)
Brembo LCF 600+ exceeds all DOT 4 requirements and is suitable for use in all DOT3, DOT4, and DOT 5.1 brake system applications.
LCF 600+ is an ideal choice for racing or performance use - combining ultra-high dry boiling point, low compressibility, and consistent pedal feel.
IMPORTANT NOTE
DO NOT USE Brembo LCF 600+ fluid in contact with any type of magnesium components (e.g. gearbox / clutch components) as a chemical reaction is caused resulting in gases being generated. This will then prevent the clutch hydraulics from working efficiently.
MOTUL RBF600
‘Typical’ New Dry Boiling Point = 312C (594F)
‘Wet’ E.R. (Equilibrium Reflux) Boiling Point = 216C (421F)
Motul RBF 600 is a 100% synthetic fluid for hydraulic-actuated brake and clutch systems. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
Motul RBF 600 far exceeds the standards of DOT 3 and DOT 4.
The RBF 600 container is filled with Nitrogen to increase shelf life and eliminate contamination while factory sealed.
Old 10-12-2013, 06:15 PM   #5
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Glad I have a stock pile. This stuff is great!
LSX Camaro is offline   Reply With Quote
Old 10-12-2013, 07:14 PM   #6
ssmike
Missing Big Red
ssmike's Avatar
Drives: '13 Equinox CRT
Pete, who sells the Castrol and what does it typically cost?
Old 10-13-2013, 11:01 PM   #7
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
I use Afco racing HTX, great luck with it. 600 degree boiling point.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 10-14-2013, 10:26 AM   #8
JusticePete
Summit Racing
Dry boil temps are flashy, but it is the wet boil temp that should determine which fluid you purchase. HTX is wet is 421.
Old 10-14-2013, 06:29 PM   #9
intensifi
While I swap my 2LT brakes out for the Brembos do you think I can get away with the manual swap/bleed using the Castrol SRF or should I first perform the brake upgrade using GM DOT3 fluid then take it to the dealer (or a shop) where they can do the full swap to the Castrol SRF (purging the ABS, etc.)?
My mechanic friend and I were planning on swapping the calipers, rotors, lines, pads & master cylinder out in my garage.
Old 10-14-2013, 06:34 PM   #10
JusticePete
You can do this as a DIY. After you have bled the system with the new calipers engage the abs in a safe place. Then bleed them again.
Old 10-14-2013, 07:19 PM   #11
JDP Sales
JDP Sales's Avatar
A gravel or dirt road works well for this. Or while it's raining.
Best regards,
Tyler
888-308-6007
Old 10-14-2013, 07:26 PM   #12
intensifi
Thanks guys!
Sorry for asking the same follow-up in two threads...
For the re-bleeding after the bedding procedure, which caliper or is it all of them? How will I know if I've got the fluid that was in the ABS reservoir out?
Also for the bedding procedure how can I be sure I have forced the ABS system to cycle and force it's reservoir fluid into the system?
Old 07-14-2015, 05:55 PM   #13
Camaro Dude
and Sledge
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
CASTROL SRF
Brembo LCF600
IMPORTANT NOTE
MOTUL RBF600
I would add Gulf Competition RF 1000 to that list.
My distributor claims it's made under the same umbrella as the Castrol SRF folk, but at a much better price point. I'm looking into the former claim..
Nonetheless, it seems to have very favourable reviews in EU, and the local track guys here seem to love it.
I'm using it as well, testing it out on track this week.
Camaro Dude is offline   Reply With Quote
