Cold Air Inductions
Old 10-12-2013, 02:35 PM   #1
vcyclenut
Drives: 2011 ctsv
Reliability of blown ls3 with stock internals??
There have been several camaros for sale recently with superchargers and stock internals.
What's are peoples experience with the reliability of this combination.
There are some with a decent amount of miles on them which makes me believe if you don't tune it too crazy and aren't beating on it all the time it's pretty reliable.
Also how does the stock drivetrain hold up to 550 plus rwhp
Thanks
vcyclenut is offline   Reply With Quote
Old 10-12-2013, 02:45 PM   #2
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
Mines had no problems whats so ever, I'm over 600 at wheels and not afraid to drive it a cross the state at anytime. It's been very reliable. It honestly depends how u drive it. My stock clutch lasted awhile before it acted up but at my power level it was only a matter of time. Plus mine only saw the 1/4 mile a couple times. I do drive my car hard, but not on sticky tires, I run 315 nitto invos and I believe they stick less than the Pzero it comes with.
2017 ZL1 A10: Under the knife.
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 10-12-2013, 02:48 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
IIRC the stock internals are good to 12 psi with a solid tune.
Firefighter is offline   Reply With Quote
Old 10-12-2013, 04:18 PM   #4
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
If done right than stock internals are fine. 600rwhp here and drive it 100 miles a day.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 10-12-2013, 05:49 PM   #5
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Mine is at 570hp on 9psi with 11:1 a/f and 14* timing. I expect if it ever let go it wouldn't be because of the tune.
Old 10-12-2013, 07:29 PM   #6
Gary B
Gary B's Avatar
Drives: Subaru
Really depends on how its driven. You can have 750+rwhp, as long as you drive it easy, I'm sure 600-650 will have its issues if beat on constantly.
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
Gary B is offline   Reply With Quote
Old 10-12-2013, 09:07 PM   #7
Suprslo
Drives: 2013 SS
12-13 lbs and 709 rwhp here. I don't drive it easy and so far everything is fine. Maybe 30 passes and drove on the weekends. I've put about 2000 miles on it so far but I know I'm on borrowed time.
Suprslo is offline   Reply With Quote
Old 10-12-2013, 10:22 PM   #8
Bo White
Bo White's Avatar
As long as the tune is safe and its not been bounced off the rev limiter you should be fine. You might blow gasket or something repairable but nothing major.
Old 10-13-2013, 09:19 AM   #9
PIGSMOKR
2010 Lingenfelter SS
PIGSMOKR's Avatar
Drives: 2010 lingenfelter ss
I put 30xxx miles on mine with no issues running 580whp. I added a big cam and went to 650whp and a month later cracked a piston. So in my experiance 650 hp is pushing it to the limit if u drive with a heavy foot like me.
PIGSMOKR is offline   Reply With Quote
Old 10-13-2013, 11:38 AM   #10
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Reliability
Thanks
More power typically means the potential for more wear. This question is asked about every month on one of the forums here. The way I look at it is, the stock motor that GM builds makes 330-375 on the wheels depending on version. That motor is good for 100K miles plus. When that power output is increased N/A . You can probably cut that down by 25%. Just guessing . Unless of course you never step on the gas pedal and actually make that power. There are many effects from forced induction. Mainly heat in the combustion chamber and then increased pressure on rotating parts . Stock motors are fine but hey will wear faster and sometimes break. I would guess that the life of the engine could be about 60K like the old hemi motors when they came out backin the day. Just an example of power and wear. Anyway.
I ran 530 WHP for a while on the stock shortblock and ran the crap out of it at the track and on the street. When it finally gave up I wasn't surprised. If you're gong to make big power , stock engine or high performance build . You better be ready for the thing to break because they both do sometimes. If you can't fix it, you should consider not running the horsepower because you're not going to be happy with a broken car sitting in the driveway that you don't have the resources to fix. So the point is , more power is typically reduces overall engine life with a few exceptions. Just know what the score is before you get into something you wish you hadn't .
I'm at 600 to the ground and everything from the trans back is stock with no problems so far. However, I haven't run wide drag radials because I'm concerned I'll break an axel if it hooks solid at the track. I've been just too lazy or too busy to put the new upgrades in.
UNRIVALED SS is offline   Reply With Quote
Old 10-13-2013, 11:42 AM   #11
UNRIVALED SS
Accurate
This is good info. I've talked to many shops that have said 12psi is where the stock piston has problems. Most say the trans is good to about 630 WHP.
Old 10-13-2013, 12:27 PM   #12
epstein
Drives: SS/RS
Send a message via AIM to epstein
In my opinion its not just the tune . Its also quality parts. Dont skimp on fuel delivery or other key parts then you can tune with cushion. I installed my SC when I had just under 2000 miles and havent looked back. I have made changes and continue to but After 32,000 grin filled miles I have full confidence taking it on a romp or across the country.
I do plan on forging my spare motor and installing it because I feel Im at the threshold of what is considered reliable. I then will be going down to a 3" pulley.
epstein is offline   Reply With Quote
Old 10-13-2013, 12:41 PM   #13
Bo White
Bo White's Avatar
Epstein, how many lbs or boost now?
Old 10-13-2013, 01:54 PM   #14
epstein
Drives: SS/RS
Im between 8 lbs ....with it approaching 11 ish high in the rpms....Im tuned on the more conservative fatter side..
