Caryle Racing
Old 07-13-2009, 11:40 PM   #1
SirBrad
The Captain
SirBrad's Avatar
Drives: 2010 2LT/RS SIM
Tree Sap
What to use?
SirBrad is offline   Reply With Quote
Old 07-13-2009, 11:40 PM   #2
coolman
Guest
wd-40
coolman is offline   Reply With Quote
Old 07-13-2009, 11:42 PM   #3
SirBrad
The Captain
SirBrad's Avatar
That was fast. Thanks, I'll give it a try tomorrow. Parking under trees sucks. You get leaves, sap, bird poop, sticks sometimes, etc.
Old 07-14-2009, 12:01 AM   #4
coolman
Guest
After you use it wash the spot with soap and water.
Don't get the wd-40 on any trim or rubber parts.
Old 07-14-2009, 02:09 PM   #5
Fast Eddie
Drives: 2010 SS/RS
Why would you put WD40 on your paint!!?? It contains chemicals commonly used to remove paint, stain, etc.
After you wash it use a clay bar. It will probably do a better job and leave your paint intact.
Fast Eddie is offline   Reply With Quote
Old 07-14-2009, 02:12 PM   #6
jsmith
jsmith's Avatar
Drives: 2010 Camaro 2SS IBM
Just dab some of your car soap on the area where the tree sap is and let it sit there for a few hours then wash it off. This has worked for me in the past, the soap loosens up the tree sap off of the paint so that you can just wash it off like normal.
Ordered on 3/31/09: 2010 Camaro 2SS IBM Black Leather L99
Event 1100 - 4/2/09
Event 2000 - 4/6/09
Event 3000 - 4/10/09
Event 3300 - 4/27/09
Event 3800 - 5/12/09 VIN#9436
Event 4200 - 5/18/09 :party0038:
Event 5000 - 5/28/09 delivered
jsmith is offline   Reply With Quote
Old 07-14-2009, 02:14 PM   #7
coolman
Guest
One of my best friends is a detailer for 25 years. I thought he was crazy too,but it doesn't hurt the paint if you wash if off after you remove the problem. Just don't use it on the trim or rubber. Also works great to debage a car. And by the way there are alot of chemicals used in automotive products used detailing that are worse for a cars paint.
Old 07-14-2009, 02:16 PM   #8
coolman
Guest
one of the worse things you can do is put soap on a car and leave it there.
Talk about spots that are hard to remove.
Old 07-14-2009, 02:18 PM   #9
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
Tree sap can also be removed by using a water-soluble paint brush cleaner. A common household solution is bacon grease or lard. Just rub it on, and off comes the sap. To get tree sap off of your hands, simply rub mayonnaise on them and wash it off. To remove tree sap and other substances, you can use common solvents like lighter fluid, rubbing alcohol, WD-40 or even Skin-So-Soft bath oil.
You're right cool man!
http://www.usautoparts.net/bmw/repai...g/tree_sap.htm
I also think a quick clay bar on the spot would take it right off.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 07-14-2009, 02:35 PM   #10
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
IPA
isopropyl alcohol.
hot ss is offline   Reply With Quote
Old 07-14-2009, 02:51 PM   #11
Vash
Drives: 00 Blazer
Chainsaw.
The outdoor cover probably if you can't chop it. And cleaners as suggest.
Then you get the fun task of hand washing a giant car cover in a bucket outside (washer would tear it up I fear).
Old 07-14-2009, 02:55 PM   #12
coolman
Guest
Your right Vash, Chain saws do the best job. You don't even have to lay a hand on the paint.
Old 07-14-2009, 10:07 PM   #13
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
I've used wd-40 on my Chevelle to remove tire rubber behind the rear tires after a day at the drag strip worked great and no harm to the paint. I used quick detailer after the wd-40.
bono83 is offline   Reply With Quote
Old 07-14-2009, 11:54 PM   #14
SirBrad
The Captain
SirBrad's Avatar
Claybar definitely did not do the job.
My Chevy Camaro vs. Tree chapmadl Camaro Photos | Spyshots | Video | Media Gallery 198 02-17-2012 03:06 AM
75,000 2010 Prius orders...my philosophical quandry MrIcky General Automotive + Other Cars Discussion 80 05-30-2009 06:34 PM
Joke about equal opportunity employment (Newfie outsmarts a canuck) Mindz Off-topic Discussions 13 04-13-2009 02:34 AM
GOOGLE MONEY TREE IS A SCAM!!! DON'T DO IT!! Matrix Off-topic Discussions 2 03-05-2009 12:31 AM
