Emblempros
Old 10-13-2013, 04:10 PM   #1
Chevrolade
Drives: 2010 2SS/RS
Front sway bar removed anyone?
Thinking about removing my front away bar for a lil better weight transfer
So anyone have there's removed ? And how does it ride on street ?
I have mine removed on truck and it transfers badass but not sure how car will feel? So need info
Chevrolade is offline   Reply With Quote
Old 10-14-2013, 11:18 AM   #2
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
Yikes, to be honest I can't imagine that will accomplish anything but mess up your car's handling and make it dangerous during evasive maneuvers if you find yourself swerving to avoid an accident. Body roll will also suck.
Your best bet is to install a bigger rear sway bar. Also, starting in 2012 the Camaro's rear sway bar mounting was revised which dramatically improved handling and reduced understeer. Contact Pete at Pedders, he can give you the parts you need to make the update. He can recommend a group of parts to meet your goal and and budget.
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 10-14-2013, 11:47 AM   #3
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Unless your car is a trailer it to the track car you should not remove your front sway bar. Remove one endlink stud nut and secure the endlink so it does not foul with the front suspension at the track. The front sway bar is now disabled to enhance weight transfer. When you track day is over, put it back on.
Old 10-14-2013, 01:34 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
We removed the front sway bar on our BMR Suspension 2010 Camaro a while ago but it only sees very minimal street duty so it isn't a big deal. If you drive the car a bunch I wouldn't remove the sway bar completely but instead just undo one of the end links from the sway bar and tie it up to the strut itslef. This will give you the same effect but without having to remove the entire sway bar.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 10-14-2013, 02:56 PM   #5
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
mines off . the car lifts alot more then before. i dd mine aswell its go more roll but nothing to bad. but i dont flyon the road anyway. but it still sticks in a curve better then i thought i it would. does it handle like before no . does it feel bad not at all. but im no road racer.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 10-14-2013, 03:00 PM   #6
Orange Crush 1LE
Drives: 2013 SS 1LE
Really? You guys are scaring me, LOL. Doesn't sound like an engineered solution that could work well on the track or street.
Old 10-14-2013, 03:01 PM   #7
Chevrolade
Drives: 2010 2SS/RS
I removed mine yesterday completely will see how it feels soon as I get my intake on.shed 10lbs lol
Old 10-14-2013, 03:06 PM   #8
JusticePete
Removing your front sway bar and driving on the street is a bad idea. Everything is just fine as long as everything is under control. When you are forced to make an emergency maneuver for whatever reason, the control the sway bar provides is be the difference between a near miss or something much worse.
Old 10-15-2013, 01:47 PM   #9
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Same here daily driver on the Hwy and local street. Its been with out the front sway bar for over a year and it doesn't feel bad at all with the stock wheels. But I also have the BMR Large Drag sway bar set at its stiffest setting, and I don't take curves at high speed.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 10-15-2013, 02:08 PM   #10
JusticePete
Russian Roulette
I pulled the trigger.
I am still here.
Russian Roulette is safe.
Old 10-15-2013, 06:13 PM   #11
Orange Crush 1LE
Drives: 2013 SS 1LE
Russian Roulette
I am still here.
That was pretty much my reaction too, LOL.
Once I had to make an evasive maneuver to avoid a car on the freeway that rapidly changed lanes into mine. I had my studless snow tires on after a ski trip, and hadn't had time to swap them for my street set. Holy cow I just about lost it, those tires are horrible at the limit. Removal of the front sway bar would result in handling that is dramatically more unstable, I would think.
Old 10-15-2013, 06:29 PM   #12
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Russian Roulette
I am still here.
LOL
So Cal Camaro is offline   Reply With Quote
Old 10-20-2013, 12:58 AM   #13
BLACK10
BLACK10's Avatar
We remove the front sways on cars that see a lot of drag strip time. It does let the front end transfer better.
Old 10-20-2013, 01:04 AM   #14
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I DD a 1981 Camaro with no sway bar and a spool for a long time in my early 20s. I'll do it again lol.
