SDTW Custom Wheels & Tires
Old 10-14-2013, 10:25 AM   #1
CamaroI
Drives: 2010 IOM Camaro
Hood liner and Whipple install
Do you lose the Hood Liner when doing a Whipple install? Curious on clearance
CamaroI is offline   Reply With Quote
Old 10-14-2013, 12:11 PM   #2
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS 05 Jag S type R
As mentioned before it will rub. Mine does not rub hard but it will eventually rub the finish off the top front of the Whipple. I took a few strips of packing tape and put it on the top of the Whipple where it rubs. When I enter it in a car show (not many of those around here) I remove the tape and clean up the residue with some cleaner. Still looks new.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, No Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 10-15-2013, 07:17 PM   #3
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
When I had mine it just touched, no marks were left.
BrainleSS is offline   Reply With Quote
Old 10-15-2013, 07:20 PM   #4
rdblan2
Drives: 2SS RS
I have a little rub mark on the hood liner where the whipple rubs. Can't see it unless you look for it.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 10-15-2013, 08:08 PM   #5
bwk1971
Res Ipsa Loquitur
bwk1971's Avatar
Drives: 2013 Camaro SS Vert Supercharged
Mine rubbed hood liner and coolant cap. Removed liner and lowered coolant reservoir slightly and fixed both.
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
bwk1971 is offline   Reply With Quote
Old 10-15-2013, 09:13 PM   #6
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Here is what mine looks like.
Sent from my Samsung Galaxy S4 using Tapatalk
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
