BeckyD @ James Martin Chevy
Old 07-14-2009, 06:59 AM   #1
20 Camaro 10
Junior Member
20 Camaro 10's Avatar
Drives: 2SS/RS Camaro
Launch Control Problems....
here's my story....
I've tried using the Launch Control, but the problem is that the RPM's does not stop at 4,000 to 4,500 RPM's is go's all the way to redline to launch....
Before I get smacked around...lol.., I followed the instructions from the owners manual. It does light up in the DIC that its in Comp mode. So I believe i'm doing everything correct.
I believe my next step is to take it to the dealer and have them check it out....
Has anyone else having any problems with this option?
In Garage - 2G1FT1EW5A9107727 - 2SS/RS, BLK on BLK, 6M, CGM RALLYS
20 Camaro 10 is offline   Reply With Quote
Old 07-14-2009, 07:36 PM   #2
NAHURRY
Love's to Detail
NAHURRY's Avatar
Drives: 2010 SS,97silverado/08crewcab
Bump for reply's
NAHURRY is offline   Reply With Quote
Old 07-14-2009, 09:16 PM   #3
orangeinfernoman
orangeinfernoman's Avatar
Drives: 2010 camaro ss ls3 iom
Originally Posted by 20 Camaro 10 View Post
here's my story....
yes it happen to me some time but drive with the car a little bite and try again it happen to me 5 times on 25 attempts
orangeinfernoman is offline   Reply With Quote
Old 07-15-2009, 01:41 AM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Just take it to your dealer and try it in the parking lot....it'll save you the hassle of calling a tow truck
Old 07-15-2009, 04:06 AM   #5
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
happened to me the two times i've tried it. stabilitrak comp mode, floor it quickly, and bam...it's up to 6k rpms in no time.
Old 07-15-2009, 04:23 AM   #6
20 Camaro 10
Junior Member
Still havent had mine work correctly, but I will try to leave it on for awhile and see if that works, and bring the rpms up slowly.....
Old 07-15-2009, 06:50 AM   #7
jachevy28
Camaro. Is. Life.
Drives: 2016 1SS
Happened to me as well...some guy posted in another thread that you had to put it in neutral, then floor the gas, then the clutch, then put in gear and go. I haven't tried it since....http://www.camaro5.com/forums/showth...863#post609863
I also though maybe I was being too much of a wuss putting the gas down quickly...
jachevy28 is offline   Reply With Quote
2010 Camaro Launch Control = Transmission Failure camaroguy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 140 07-06-2013 12:27 AM
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 10:29 AM
COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 05-02-2009 01:20 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
Launch Control, No-lift, New Zeta II platform, Stability Control, Traction Control RT21 5th Gen Camaro SS LS LT General Discussions 34 02-26-2009 10:29 AM
