Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions.
Old 07-14-2009, 07:17 AM   #1
surferbarney
surferbarney's Avatar
Drives: 2010 Camaro, 1999 Mustang
Can't shift into reverse!!!
Ok, so I got to work this morning and went to back into a parking space and I couldn't put my car into reverse. I thought it was very odd but I did add something to the car yesterday which is probably what screwed it up and I just don't know how it could have though. Yesterday I installed a skip shift eliminator which only involves plugging in two connectors so I really don't see how this could have screwed up my ability to shift into reverse. Does anyone know if this could have caused the problem? And if it did, how it could have caused it? Like maybe the connectors aren't seated good enough, or maybe the wire is just bad???
I can't do anything about it right now but when I get home I'm going to remove the skip shift eliminator and see if that allows me to shift into reverse again.
2010 Camaro 2SS RS
IOM exterior, IO interior
Black Rally Stripes (painted aftermarket)
GFX Package
Pre-Ordered 1/19/09
2000 4/9/09
3000 4/24/09
3300 5/4/09
3400 5/9/09
3800 5/15/09
Delivered 6/2/09!!!!!
VIN 2G1FT1EWXA9110199
surferbarney is offline   Reply With Quote
Old 07-14-2009, 07:35 AM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Keep us posted. I wouldn't think it would cause your problem, but you never know.
Crowley
Crowley is offline   Reply With Quote
Old 07-14-2009, 07:46 AM   #3
IROCanSS
Drives: 89 IROC 350
doesn't matter, youre probably going to get a new tranny anyhow!
Old 07-14-2009, 08:17 AM   #4
fastdoc436
fastdoc436's Avatar
Drives: 2010 2SS/RS,35thLE/SS,30thAE/SS
I installed my skip shift eliminator already and is working fine. The instructions stated that there are 3 solenoids and the reverse lock out is most commonly mistaken for the skip shift solenoid. The skip shift solenoid is on top of the tranny...go online and look for pics of the install (I think on slponline.com and pehaps at afterthoughts auto or pfyc). Simply reach up higher on the tranny to locate the skip shift solenoid...it is tuff to see. Good luck!!(be careful the tranny stays hot for awhile, so do this on a cold tranny) Hope this helps!
Ed
2002 35thLE #2474, SLP #5430
1997 30th SS Anniversary Edition #805, SLP #2244
2010 2SS/RS M6, black/black, 20's polished, #11399, DT shorties, muffler delete, RotoFab CAI, Hurst ST shifter, 20%tint, Pfadt lowering springs/ sway bars/ rear trailing arms.
fastdoc436 is offline   Reply With Quote
Old 07-14-2009, 09:18 AM   #5
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
anyone with m6 tranny is crazy to install the skipshift eliminator until these tranny issues are resolved......
you would not want them to hose you saying the skip shift is what caused the failure....
Ltdodge is offline   Reply With Quote
Old 07-14-2009, 09:30 AM   #6
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
hell it only takes 3.5 seconds to remove and anyway vettes have used em for a long timeits not the issue,id bet the wrong solenoid was plugged into,it happens
firestone_ss is offline   Reply With Quote
Old 07-14-2009, 09:56 AM   #7
PsyDoc
Drives: Soon-to-be 1st Gen
I know this happens on some of the older manual cars. All you have to do is to put it in first and get it to move forward a bit...inch or two, and then it should go into reverse fine.
PsyDoc is offline   Reply With Quote
Old 07-14-2009, 10:30 AM   #8
surferbarney
I can guarantee you this is the problem because I just drove it and was forced to skip shift. Should be an easy fix when I get home.
2010 Camaro 2SS RS
GFX Package
Pre-Ordered 1/19/09
2000 4/9/09
3000 4/24/09
3300 5/4/09
3400 5/9/09
3800 5/15/09
Old 07-14-2009, 10:47 AM   #9
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
Yes i did it at first and had to remove and install on the top solenoid it will be longer to let the trans cool than to redo the install.
2SSRS is offline   Reply With Quote
Old 07-14-2009, 08:03 PM   #10
surferbarney
Well my car now goes in reverse again, lol. It was definitely plugged into the wrong solenoid. The correct one was a lot harder to see. But I drove it around earlier after switching and the skip shift eliminator now works properly. Thanks for the help guys.
2010 Camaro 2SS RS
GFX Package
Pre-Ordered 1/19/09
2000 4/9/09
3000 4/24/09
3300 5/4/09
3400 5/9/09
3800 5/15/09
Old 09-02-2009, 05:09 PM   #11
jpsuperman81
That's Right 478whp450tq!
jpsuperman81's Avatar
Drives: 2010 2SS/RS Rally Yellow
Hey guys am I to assume if the skip shift was in wrong place it wouldn't be working? I didn't install it but the guy said it was hard to reach above transmission. I can get in reverse just a little harder than before.
I would like to apoligize ahead of time if any of my posts bother you, I am quite a large smartass and very expressive of my opinion!
I came here to chew bubble gum and kick ass and I'm all out of bubble gum!
Ordered Feb. 13 2009: 2SS/RS/M6/Sunroof/ Rally Yellow built 8/7 Vin# 33534, Delivered 8/26/09!
jpsuperman81 is offline   Reply With Quote
Did Camaro (automatic) reviewers use tap shift ? trudawg660 5th Gen Camaro SS LS LT General Discussions 30 11-09-2010 07:55 PM
Manual shift - 1-4 ? calflan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 12-01-2009 11:38 AM
Reverse lockout? (manual transmission) zq8colorado04 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 06-17-2009 08:37 PM
SS Hurst shift option AMERICANMADE Camaro Price | Ordering | Tracking | Dealers Discussions 11 06-05-2009 11:56 AM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 09:20 AM
