BeckyD @ James Martin Chevy
Old 10-16-2013, 03:08 PM   #15
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Kick his @$$ "SeaBass"!!!!!! (I mean Kyle)!!!!!!!!!!!
BMR FTW!!!!
blazzin1 is offline   Reply With Quote
Old 10-20-2013, 08:13 PM   #16
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Originally Posted by Evil-Bee-NH View Post
It's a vendor war everyone run for the hills!!!
Lol !! I was just thinking the same as I was reading.
Sent from my iPhone using Tapatalk - now Free
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 10-21-2013, 07:29 AM   #17
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R
Ended up ordering the bmr inserts and pfadt trailing arm package as advised to me by a reputable person. I am very excited to install. Should help out the rear end. I'll keep you guys posted on the install and test drive
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 10-21-2013, 08:11 AM   #18
blazzin1
blazzin1's Avatar
Glad to see that you went with the BMR Bushing Inserts, you won't be disappointed!!!
Old 10-21-2013, 02:41 PM   #19
caverman
caverman's Avatar
Drives: '69 SS Convertible
OP....I know you've already placed your order but thought I would at least let you see my thread. If you're going to be installing these yourself just know what you'll be getting into with that style of insert. If you drop the cradle all together you can probably get a decent angle on those inserts but if you plan to do it from side to side there is a good chance you'll run into the issues I did. Not saying you will 100%. Just know how much easier the Pedders inserts are to install.
Mine were Energy Suspension inserts. I don't know if the poly will be the same as BMR but the design is the same. IMO it was worth the extra money for the Pedders inserts.
http://www.camaro5.com/forums/showth...hlight=pedders
Build Journal
Old 10-21-2013, 04:58 PM   #20
ssmike
BliSSard has come!
ssmike's Avatar
Drives: '16 Camaro 2SS, '13 Equinox CRT
I am going to buy full rear cradle bushings and want to know how your DIY experience went and if the upgrade was worth the 250$+ and the roughly 6 hours to install?
I wish I would have seen this thread before you ordered! I went the same route as you when I installed the BMR inserts and trailing arms. At first they seemed OK but I was still getting rear end step out and wheel hop. I then discovered that BMR was having issues with their outer trailing arm bushings so I ordered a set of Pfadts and replaced the BMR bits. That did not resolve the problem so I decided to replace the BMR inserts with full Pedders bushings. Yea it cost over $500 but I wish I would have sprung for them right away! Now the rear end is solidly planted, no step out OR wheel hop! The cradle bushings are the most important suspension mod you can do so it makes the most sense to save a little more and go for the real deal! I WASTED 2 hours under the car and whatever I spent on those inserts! I would hate to see you learn a hard lesson like I did! I'm only at 424 rwhp so it's not like I'm pushing a lot of power to cause the step out and wheel hop, it's all in those cradle bushings! That's my experience!
BMR FTW!!!!
Pete, you gonna take that?
Pedders FTW!
Old 10-21-2013, 05:49 PM   #21
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I'm waiting on mine from Kyle now. When I called him late last week he went over all three offerings with me so I could make an educated decision.
Old 10-21-2013, 06:55 PM   #22
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I have all BMR suspension parts on mine and couldn't be happier, I'm over 650rwhp and have no problems at all. BMR FTW!!!
MODS:
Old 10-21-2013, 08:16 PM   #23
ssmike
BliSSard has come!
ssmike's Avatar
Full bushings or inserts?
Old 10-21-2013, 09:05 PM   #24
camaro500
camaro500's Avatar
damn, i know pedders has a great reputation and maybe i should have waited. The issue was i didnt want to spend more than $600 on inserts, trailing arm and toe rods because im saving up for a cam package/conversion and either pedders or pfadt coilovers for spring 2014. I would love to buy the best of everything but cannot afford to. I will let you guys know how my parts perform if I have a chance to take my car for an alignment before winter. Montreal is already experiencing 0 degree weather at night. Thanks everybody for the feedback, much appreciated.
Old 10-22-2013, 12:02 AM   #25
caverman
caverman's Avatar
Kind of an after the fact but this would've been my shopping list and probably would've been able to be done in your budget.
Pedders Street Z package (cradle inserts and radius rod inserts)
BMR or Spohn Trailing Arms and Toe Rods
Pfadt trailing arm/hub bushings
Alignment set to Pedders or Pfadt aggressive street specs
Toe Rods could've waited if they didn't fit in the budget. They will help but from my experience they didn't help as much as the other stuff. Actually, I would've ditched the Toe Rods and bought a set of Pedders rear eccentrics bolts to get a better alignment. Again, another on of those not so cheap but extremely good parts.
Build Journal
Old 10-22-2013, 12:11 AM   #26
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
This is the exact thing I'm contemplating. What do you think? I have pfadt tie rods already but considering selling them and buying eccentric bolts to get my rear z bar in and the alignment done.
Old 10-22-2013, 12:19 AM   #27
caverman
caverman's Avatar
Personally (especially if your car is lowered) the eccentrics bolts really made a difference in order to get the alignment into the Aggressive Street specs. Couldn't get there without them but my car is lowered about 1.5". My alignment guy wasn't a believer and kind of gave me the "your wasting your time/money" until he put them on the car and saw how much better an alignment he got with them. He was a definitely believer afterwards and commented on them when he didn't have to.
Toe rods on the other hand....so far I haven't seen any great advantage they've done for me just yet. I'm sure they'll help but I just have seen or felt some day/night difference. I did them because I was doing my FE4 conversion and I knew I was about to get an alignment. I had the extra $125 or there abouts for toe rods so I just threw them in the mix.
It's hard to swallow the cost of these but for real a alignment these are the ticket.
Build Journal
Old 10-22-2013, 12:56 AM   #28
lscamaro
lscamaro's Avatar
It's definitely hard to swallow the price for the bolts but having read a bunch of people saying they're great, I'll take your word for it. I was also going to just do the tie rods because I'm doing the conversion and they're there but I might sell them to get the bolts.
Now, considering this is a bushing thread, was the street z or street 1 kit worth it? Night and day difference in the rear cradle bushings?
