SDTW Custom Wheels & Tires
Old 03-22-2014, 02:35 PM   #85
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Updated to include full photo set, which I couldn't get to load in some 10 previous attempts...
brt3 is offline   Reply With Quote
Old 03-22-2014, 02:56 PM   #86
brt3
brt3's Avatar
Added to first post, along with a PDF version in attachments (see below)...
Old 03-22-2014, 04:22 PM   #87
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
The door sills are bad-ass. I totally dig them. Car is still full of surprises.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28.
Zfatuated is offline   Reply With Quote
Old 03-22-2014, 10:49 PM   #88
brt3
brt3's Avatar
Sometimes Ezra Dyer lays it on a bit thick, but I love a couple of the quotes above:
"This… is the most barbarically analog car on the planet. The Z/28 is uncompromising in ways that will severely limit it’s appeal. It’s also wonderful for all the same reasons. It’s like a homologation special for a racing series that doesn’t exist."
Again, KUDOS to the design and engineering team for refusing to compromise on this car. Those who are buying them totally get it. Those who complain that it's not what they wanted don't. This is a single purpose tool, not a Swiss Army Knife. I just can't wait to get mine out on the track!
Old 03-24-2014, 02:02 PM   #89
brt3
brt3's Avatar
Many updates to original post to reflect the end of the press embargo. Also changed the structure to be more organized, and added some PDFs to the library...
Old 03-24-2014, 02:08 PM   #90
brt3
brt3's Avatar
Automobile just posted their review online: READ IT HERE
Old 03-24-2014, 03:31 PM   #91
brt3
brt3's Avatar
Road & Track First Drive:
The 2014 Chevrolet Camaro Z/28 is a monster track car
Chevrolet re-launched the Camaro from oblivion in 2010 and, from the driver’s seat at least, that car underwhelmed. Built on GM‘s global rear-drive platform, known internally as Zeta, the Camaro’s bones originated from Holden of Australia, where tastes in vehicle set-up tend to differ from ours. The Camaro’s stateside development time was virtually zero, so the US engineering team washed their hands of it and sent the largely Australian-spec slice of Americana to dealerships.
Then Chevrolet unlocked the engineer’s toy-box. Four years later, we have this—a monster. The Z/28 is a low, stiff, single-minded demon, a crazed caricature of a track car, a menace to practicality and civility, a masterpiece.
To build this track-purposed Frankenstein, Chevrolet started with Zeta, took away unnecessary weight like trunk trim, sound-insulation, and a/c (it weighs less than the already lightened SS 1LE). Then engineers added trick aero bits, like a rear spoiler with a Gurney flap and front splitter (all of it good for 150 pounds of downforce at 150 mph). They rounded out the package by adding a Torsen limited-slip differential, massive carbon-ceramic Brembo brakes, and the very trick dynamic-suspension-spool-valve, or DSSV shocks.
DSSV is a fundamentally different kind of shock absorber. Instead of oil passing through deflecting discs, DSSV dampens motion of the wheel through a precisely cut hole in an internal rod that becomes more exposed as suspension travel increases. Admittedly, this is engineer jargon. What’s important to know: DSSV is very accurate, consistent, and expensive. It’s also near magic on the track. Oh, we almost forgot the mega-grippy Pirelli PZero Trofeo R tires, 305/30ZR19’s at each corner.
This raid on the top-shelf parts bin creates impressive numbers. The Z/28 is a 193-inch long, 77-inch wide box that holds nearly 1.1g in corners; an almost two-ton slug of iron that decelerates at up to 1.5g; a 505 hp old-school muscle car that costs $75,000, $17,350 more than the 580 hp ZL1.
Sitting down in the Z/28, it still feels like an everyday Camaro, until you turn the key and bring the seven-liter screamer to life. The 505 hp V8 growls at the start and settles into a low, Trans-Am-racer-like rumble. It’s the business. Clutch in, select first and smile that no automatic option exists for this car. Heading down the hot pit of Barber Motorsports Park, I wonder how the Z/28 will change direction and, more importantly, will it stop?
Then I hit the gas, accelerating through second gear, third, fourth; hitting 120 mph just as I cross the 3-marker for turn-five. I stomp on the brakes, hoping I don’t need to use the run-off, breath held and—Wait, am I stopped?
Yes, completely, and only at the 1-marker. The brakes are that good. Despite multiple attempts, they didn’t fade on track once, even slightly. With stopping power available as reliably as a Tokyo bullet train, the brakes inspired confidence, as did their phenomenal balance. By the third lap, the Z/28 coaxed me into flicking left at full-throttle into the high-speed esses, never going much slower than 90 mph and pulling well over 1 lateral g. No sweat.
Every lap was faster than the one before. I felt like I was jogging with a pitbull that’s in much better shape than me. The faster I went, the Z/28 kept pace. When the limit of grip did finally arrive, it came predictably. The Z/28 isn’t merely fast, it’s easy-fast. And that’s what impresses the most.
When the Z/28 first arrived I asked: why the Camaro? Why not apply this same logic to a more purpose-built sports car like, I don’t know, a Corvette? But after experiencing what a $75,000 Camaro really is, the answer is both cliché and fantastic—why not?
Old 03-24-2014, 03:50 PM   #92
brt3
brt3's Avatar
Now enriched with PDF goodness...
READ MORE HERE
Read more: http://www.autoweek.com/article/2014...#ixzz2wuYiGpRg
Old 03-24-2014, 04:03 PM   #93
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Just for fun, Camaro engineers on hand rigged up our red Z/28 with GPS timing equipment to see what kind of lap times Pilgrim could produce. Pilgrim previously had never driven around Barber before but was still able to lay down a respectable lap time of 1:36.29. For some perspective: The fastest lap a GS-class Camaro GS.R race car did around Barber in the Continental Tire Sports Car Challenge race last year was 1:36.02. So a Z/28 off the showroom floor can run with race-prepped cars in the Continental Tire series' quickest class …
That is one bad ass machine.
Moreno Motorsports is offline   Reply With Quote
Old 03-24-2014, 05:35 PM   #94
brt3
brt3's Avatar
This is pretty insane. The GT3 is only .53 second per lap faster with a professional driver. Andy Pilgrim say's it best, regarding the GT3: "Simply put, less mechanical grip and the need for more rear downforce in the GT3 equals more sliding and longer slide-recovery times, and this would be more uncomfortable for average track-day warriors. I can say it's easier for me to go fast in the Z/28, and if I owned one, I'd sure go looking for GT3s to play with at any track day. If both of these are in my garage, it would be the GT3 for the street and the Z/28 for the track, every time."
DAMN!!!
Old 03-24-2014, 05:43 PM   #95
brt3
brt3's Avatar
Also love the blurb under Pilgrim's POV:
"I've driven tons of street cars modified for the track. You couldn't come close to one this capable for the price. If you have $75K... this is your boy right here."
Old 03-24-2014, 06:06 PM   #96
brt3
brt3's Avatar
READ ORIGINAL ARTICLE HERE
2014 Camaro Z/28 Tested: 0-60-0 and 0-100-0
Written by: Brandan Gillogly on March 23 2014 11:06 PM
We camped out trackside as Motor Trend drove a 2014 Camaro Z/28 at Fontana’s dragstrip to see how the 305mm-wide Pirelli PZero Trofeo R tires and carbon-ceramic Brembo brakes harness the LS7′s horsepower. On the turns of a road course, the Pirellis grab like Artie Ziff. This wasn’t a road course, and it also wasn’t Fontana’s prepped starting line. Motor Trend’s Carlos Lago was launching the car from the big end, near the gravel trap, headed toward the traditional dragstrip starting line that was more than a quarter-mile away. The surface was smooth asphalt, so Carlos had to launch carefully to avoid wheelspin.
With an accurate, GPS-based VBOX installed in the cabin of the Z/28, Carlos made four 0-60-0 runs, with an average time of 7.08 seconds and an average distance of 327.86 feet.
Headed the opposite direction, just past the prepped dragstrip launch surface, Carlos made three 0-100-0 runs, with an average time of 13.34 seconds and an average distance of 1,087 feet. To put that into perspective, the Z/28 could back to the stern edge of a Nimitz-class aircraft carrier’s flight deck, accelerate to 100mph, and stop just in time to keep from taking a salty bath.
Road and Track tested a field of supercars back in 2003 that included a Porsche 911 Turbo, a Viper SRT-10, a Lamborghini Murcielago, and a Saleen S7. The Turbo 911 took the crown then, but none of those cars posted a better 0-100-0 time or distance than the 2014 Z/28 Camaro. The new Z/28 benefits from 11 years of tire and brake technology, but that’s still quite a feat, especially considering that there wasn’t even a Camaro on the market 11 years ago.
Read more: http://blogs.hotrod.com/2014-camaro-...#ixzz2wv7SG5FT
Old 03-24-2014, 07:23 PM   #97
Mikebrinda
Mikebrinda's Avatar
Drives: Ferrari F430 Spider F1 Azzurro Arge
Z/28 vs GT-R
http://autos.yahoo.com/blogs/motoram...4455.html?vp=1
Mikebrinda is offline   Reply With Quote
Old 03-24-2014, 08:18 PM   #98
brt3
brt3's Avatar
ORIGINAL ARTICLE HERE, WITH VIDEO
The showdown: 2014 Chevrolet Camaro Z/28 vs. Nissan GT-R for all the marbles
By Alex Lloyd
March 21, 2014 3:04 PM
Motoramic
Imagine, if you will, an email containing a first drive invitation for Chevrolet’s all-new Camaro Z/28. As you continue to thumb through, you notice a challenge of sorts – feel free to bring any competitor of your choice for a comparison.
Time to pick up the phone. Within 30 minutes a 2014 Nissan GT-R Track Edition is secured. Our Z/28 first drive was to be a showdown between American muscle and Japanese finesse. The venue for our battle: the Barber Motorsport Park in Birmingham, Ala. — a track with curves as unpredictable as Sandy Koufax, and more crests than Ben Nevis.
I’d ridden in the passenger seat of a Z/28 test mule last year, and the grip level was astounding. The power from the 505-hp, 7.0-liter LS7 V-8 motor was punchy, and yet civilized. The issue back then was the carbon-ceramic brakes: “It doesn’t stop how I’d like it,” the Chevrolet engineer, who was in the driver’s seat, told me.
Fast-forward a month and it was determined that the Pirelli Trofeo R tires were slipping on the rim. Just 10-degrees, they thought — until they realized that 10 was more like 370. After blasting some abrasive grit to the surface of the rim, the problem was solved.
And so here I was. The finished product sat in an open garage at Barber, flurries of mechanics warming her up. I was summoned to the mandatory — keep the shiny side up, don't bruise our baby — safety briefing.
Parked ominously off to the side was the black GT-R. No mechanics. Just Steve, Nissan’s motorsport manager, his luggage, and a set of car keys.
Ironically, Steve was the name given to the Z/28 back when the idea to revive the iconic moniker was envisaged. Only key individuals within the GM Empire knew Steve was not the engineers’ coffee boy, but actually the most capable Camaro ever.
It’s also the most expensive. But, at $75,000, listen to what arrives as standard: Carbon-ceramic Brembo brakes, dampers by Multimatic — the same company that supplies the Red Bull F1 team and the first production application outside of the exclusive Aston Martin One77 — and the aforementioned tires.
Those tires. Originally built for an amateur Porsche racing series in Europe, they’re practically slicks. With less tread than Mini Me, in the dry, they’re stunning. However, when it rains, as it did in the closing moments of the car’s timed Nurburgring run — where it still lapped faster than a Lexus LFA — spare underwear becomes a necessary option. Quick hands, too.
Back to the price. Here’s what you don’t get: Air conditioning (that’s an option – one you should definitely take, despite the roughly 30 lbs. weight penalty), a stereo, a navigation, or sound deadening.
The Z/28, then, is a race car. Only one with a usable trunk, backseats (left because they’re part of the car’s structure, and the weight saved by removing them and adding the necessary rigidity would make any gains negligible), and a license plate.
Why a $116,000 GT-R? Surely a Ford Mustang Boss 302 Laguna Seca is more comparable? Chevrolet has tested the two at its Milford Proving Grounds and claims (and has evidence to back it up) that the Z/28 is more than five seconds faster. Having driven both, I don’t doubt that. And the Shelby GT500? Well, that’s slower than the Boss.
Chevrolet says the Z/28 should hustle with the vastly more expensive GT-R and Porsche 911 GT3. Fighting talk, I thought. Over confident? Maybe.
As with every Camaro, the view from the driver’s seat is shocking. I’d have seen better if I plunged my head into a pool of hydrochloric acid and went mining. But the Z/28 is a track car. So you overlook that. You don’t care that the interior is sparse, or that the rear seats are sized for Bilbo Baggins. You don’t care how it looks. All that matters is how it drives.
The GT-R, conversely, arrives with cool air: it has a lovely stereo, navigation, and the power of sight. It has turbos — two of them — and pushes 545 hp. At 463 lb.-ft. of torque, it’s 18 less than the Z/28’s 481 lb.-ft. But it has shorter gear ratios linked to a dual clutch automatic transmission, as opposed to a six-speed manual in the Camaro, and, notably, features all-wheel drive.
It should be faster. It should be more refined. The Z/28, despite weighing 300 lbs. less than the Camaro ZL1, is a portly 3,820 lbs. Camaros are notoriously heavy. And even in this, its lightest form, mass poses a problem.
The GT-R, however, is no Takashi Miura. At 3,881 lbs., it’s even heavier than the Camaro. Both cars, therefore, need a diet, especially with the GT-R’s all-wheel drive system adding a chunk of extra metal. Oddly, the Z/28 has had one. Even the rear windshield has been thinned by 0.3mm. That saves 400 grams, documenting the seriousness behind Chevy’s efforts. So despite the hard work, why is it still so inherently heavy?
I had hoped to get a lap time in both cars to discover which is faster. Only there was a problem. The folks in Nashville who prepared the GT-R forgot to tighten the lug nuts. After a few runs concentrating on the video I was recording, I pitted noticing a worrying vibration. The stud, with the nut still attached, had sheared clean off.
After tightening the remaining ones, there was a concern regarding pushing it to the limit, given it now possessed too few nuts. I might have thought otherwise, but this wasn’t my car. And Steve needed it to drive home.
So I spent a lot of time thrashing the Z/28. It was 30 degrees in Alabama, and on cold tires, it was treacherous. As the rubber warmed, grip like you’ve never felt materialized — even more than I remembered from my time as a passenger. The massive winglets on the front splitter and rear wing produces 440 lbs. more downforce than a Camaro SS. It hugs turns unlike many high-end supercars, in part due to the massive Pirelli tires. How much is down to the near-race tires is debatable, but don’t negate the importance of the dampers and new limited-slip Torsen differential.
There is still a touch of understeer, however (something that has plagued previous generation Camaros). This, though, is minute, although its setup feels safe. You can’t adjust the dampers yourself to add some neutrality — which is unfortunate for a track car — but Chevy doesn’t want you messing with them. And for good reason, as there’s no noticeable roll or pitch. It’s impeccably stiff, and yet it rides curbs without harshness or launching the car off line. When the back slides, it isn’t progressive. It snaps. Which is precisely what a race car does.
The GT-R, even with the Track Edition’s tightened suspension, floats and wallows compared to the Z/28. It also doesn’t feature carbon brakes. The Camaro stops like no production car I’ve ever driven. They’re that good. But the GT-R sprints out of the corner far faster. It’s inherent with Godzilla — thanks to short gear ratios and all-wheel drive. You never get used to it. You smile. You laugh.
You don’t smile in the Camaro. You fret about missing your apex by 5 inches, or botching a shift (the manual gearbox is a tad notchy, and if you try to change too fast, what should be third, ends up as first). The steering, too, is lifeless — something GM is struggling with in all its performance cars.
But those brakes. And the car's composure; its grip; its noise; its prowess.
Back in 1967, when the original Z/28 debuted, it was a fierce competitor on the SCCA race circuit – so this latest version has much to live up to. The new Z/28 does things no Camaro can. But I had more fun in the GT-R. It’s still mesmerizingly good through the turns, despite the occasional understeer. And you can sense the electronics help make driving on the limit effortless. But it’s just so damn fast out of the turns. I mean, hit the gas and clench. It’s spectacular.
Am I disappointing we didn't get to see lap times? Absolutely. But in the same breath, that's not a definitive marker over which car is best. In fact, in the real world, it's nothing but bragging rights. What was more interesting to me was how differently both cars behaved.
To me, the GT-R felt quicker on the clock (just), primarily due to its acceleration advantage. But the Z/28, which costs $40,000 less, was more competent through the bends. Tires on the Camaro went off quicker, however — becoming a slithering mess during long runs. So get out your checkbook, because Trofeo Rs will be pricey.
I’m also not sure GT-R buyers would cross shop a Z/28. Despite its brilliance, a Camaro is still thought of by the elitist as crass. Those elitists would not drive a GT-R either; rather they’d snatch a GT3. The Z/28 and GT-R, though, are very different. One’s more for pleasure while the other is a no-compromise weapon.
But it’s the opposite of how I’d envisaged.
You imagine American muscle to be like a heavy mallet — punishing, somewhat sloppy, and brutish. You’d deem Japan’s acclaimed supercar to be refined, like driving in the Gran Turismo video game. And the Nissan is. It's brilliant. Only the Camaro plays tricks with your senses. During my time at Barber it was like a piercing Samurai sword held by the hands of Musashi. While the GT-R, well, that felt like Thor’s hammer.
