Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V8 Bolt-Ons & Tunes
Old 10-16-2013, 07:33 PM   #1
OHIO SPEED
OHIO SPEED's Avatar
Drives: 2010 1LT v6 Twin Turbo
Arrow FOR SALE LS3 Meziere Electric Water Pump WP329N Add 11-14hp
Ohio Speed now offers the Meziere 300 Series electric water pumps are the Big Daddy of electric water pumps. They're capable of flowing 55 gpm--enough for a 600 hp oval track car or a 2,200 hp Pro Mod. They have larger internal passages and heavy-duty motors and are available in radiator, remote mount, or engine mount versions. These pumps feature CNC-machined aluminum housings, epoxy coated motor windings, an RF suppression circuit, and a one-piece, carbon-ceramic seal
Introducing our all-new design for the 2010 and later Camaro's. Unbolt your factory pump and bolt on an easy 11-14 horsepower with our street style water pump. An idler is incorporated onto the pump so your belt routing remains in its stock configuration. American made with quality far superior to any other performance aftermarket company, we build our water pumps with pride right here in the USA. Don't be mislead by inflated flow numbers and competitors' outlandish claims. Our 300 series pumps move more water and produce more pressure than any other electric pump on the market. That means better protection for your high horsepower, high demand engine! Our 2 year, unlimited mileage guarantee and full satisfaction money back guarantee should convince you that buying Meziere is buying value!
This water pump model features:
Fits 2010 and later Camaro's with GM LS3 engines
Idler design lets you keep all of your serpentine belt driven accessories
Suitable for street or drag strip use – 3000+ hour life expectancy
Show quality natural machined and clear anodized finish
Standard motor provides 55 gallons per minute free flow rating
Ports provided for heater and bypass
Outlet fitting, heater and bypass fitting included
Stainless steel large diameter main shaft with high performance ceramic seal
Technical Specifications:
Finishing The System: This pump is supplied complete with gaskets, hardware and fittings. No additional items should be necessary.
Amperage draw: Under normal use the pump will draw 11-12 amps.
Overall Height Dimension: The standard pump is 8.15" long from the mounting surface to the tip of the pump.
Pump Weight: This application weighs 16.6 lbs.
Pump Material:Aluminum
Pump Finish:Natural
Flow Rate @ 12 Volts (gpm):55 GPM
Hose Adapter Required:No
Hose Adapter Included:No
Inlet Hose Size:1 1/2 in.
Inlet Hose Attachment:Nipple
Overall Depth (in):8.150 in.
Amp Draw:12.00 amps
Weight:16.600 lbs.
Quantity:Sold individually.
Notes:Fits manual transmission models only. Includes idler to maintain stock belt routing, gaskets, and all hardware.
PM for PRICING
Ohio-Speed is your #1 Online Store for High Performance Parts and Show Car Accessories!
https://www.ohio-speed.com/default.aspx
TAKE ADVANTAGE OF OUR LAYAWAY PROGRAM!
OHIO SPEED is offline   Reply With Quote
Old 10-18-2013, 07:32 PM   #2
OHIO SPEED
OHIO SPEED's Avatar
PM for PRICING
Old 10-22-2013, 07:04 PM   #3
OHIO SPEED
OHIO SPEED's Avatar
all pm's sent
Old 10-24-2013, 07:40 PM   #4
OHIO SPEED
OHIO SPEED's Avatar
PM for our LOW PRICE with FREE S/H
Old 10-28-2013, 07:56 PM   #5
OHIO SPEED
OHIO SPEED's Avatar
sale continues
Old 05-10-2014, 11:14 PM   #6
Groffunitmotorsports
Drives: 97 e36 m3 ls3 swap
still have these?
Groffunitmotorsports is offline   Reply With Quote
Old 05-11-2014, 03:54 PM   #7
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
pm price
DaFisch is offline   Reply With Quote
Old 08-02-2014, 01:43 AM   #8
Chevrolade
Drives: 2010 2SS/RS
What's the difference why does it fit manual trans only?
Chevrolade is offline   Reply With Quote
Old 02-26-2015, 11:55 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Please PM price with USPS shipping to 09469
Dan
2010 IOM SS
Cam - Some bolt-ons
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 02-26-2015, 01:11 PM   #10
Ryder
Ryder's Avatar
Drives: 2013 1ss 1le
pm price please
2013 1LE ashen grey 1.25 in drop. CAI Vmax L/T headers Flowmaster outlaw catback Catch can. Jannetty tuned
Ryder is offline   Reply With Quote
camaro, horsepower gain, ls3, water pump
