BeckyD @ James Martin Chevy
Old 10-17-2013, 02:24 PM   #1
madmax13
Drives: '13 2SS/RS/1LE/NPP
Torsen limited slip?
Does anyone have any information about the new limited slip and the specific improvements over the current stock unit? I am thinking about it for my 1LE.
Thanks
madmax13 is offline   Reply With Quote
Old 10-17-2013, 02:47 PM   #2
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
GM said they gained .7 seconds around MRC by changing to the helical LSD.
Bhobbs is offline   Reply With Quote
Old 10-17-2013, 02:59 PM   #3
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
...combined with ABS based line-shaping and traction control, which he won't be retrofitting :-)
From a time/trouble/expense standpoint, Madmax would be far better served investing instead in a high-quality performance driving school experience.
Zfatuated is offline   Reply With Quote
Old 10-17-2013, 03:32 PM   #4
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Come on gm performance
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 10-17-2013, 04:38 PM   #5
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Looks almost identical to the Eaton True-Trac that I just installed....
blazzin1 is online now   Reply With Quote
Old 10-17-2013, 05:28 PM   #6
Forty5th
Forty5th's Avatar
Drives: Camaro
It's a pretty robust differential. Ford uses it on the Boss 302 (optional on non laguna Seca and standard on the Laguna Seca models).
http://forums.corvetteforum.com/othe...ferential.html
http://www.torsen.com/files/Ford%20M...2%20Torsen.pdf
Forty5th is offline   Reply With Quote
Old 10-18-2013, 09:59 PM   #7
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
.7 seconds is 14 seconds in a 20 lap session!
For a Z/28 with 305 Trofeos all round you need a stronger differential or you will be doing one wheel peels as you accelerate through the corners. On a damp Ring the Z/28 pulled 1.8 Gs in some corners. That puts a huge load on the differential. Keep in mind, the .7 seconds is a comparison of two fresh differentials. Put a season or two of track time on both differentials and run the back to back test. The difference will be greater than .7 seconds.
Old 10-18-2013, 10:08 PM   #8
LOWDOWN
Downright Upright
Drives: Daily
Torsen was optional on Gen-4 Firehawks. We used one very effectively in the 500+ hp supercharged "Firehawk Lite" that finished 2nd Overall in the '98 One Lap of America.
LOWDOWN is offline   Reply With Quote
Old 10-18-2013, 10:52 PM   #9
OldScoolCamaro
...lotsa worm gears in that unit......modern science! With an old school application. Gotta love the power of thought, engineering, and application of same.
Old 10-19-2013, 11:36 PM   #10
madmax13
True that! I've been to Bondurant once, looking to go back soon! Especially now that they have 1LEs! I was going to drive mine out there but heck I'll roast their tires!
Max
Old 10-19-2013, 11:44 PM   #11
madmax13
That's a lot of time! 1.8 Gs is pretty crazy. Do the diffs break in? Very interesting.
Old 10-21-2013, 09:23 AM   #12
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I've been using a Torsen which was an SLP pull out in an S10 for 10 years or so. It was an excellent decision. I plan to upgrade to the TruTrac as it most likely will be cheaper than what GM will sell that Torsen for. They are so similar they might as well be the same.
Firefighter is offline   Reply With Quote
Old 10-28-2013, 01:15 AM   #13
j-rho
Drives: '67 Z28
Does the Z28 Torsen unit have a means for initial preload? One place helical differentials like the Torsen suffer in comparison to clutch-types is in heavily loaded highly dynamic situations, like autocross. They need a fair amount of grip on the inside rear for the mechanism to work, otherwise it becomes a 1-wheel peel.
GM equips their Corvettes (don't have any Camaro5 experience) with the best clutch-type diff setups of any OEM, curious to know the reasoning.
j-rho is offline   Reply With Quote
Old 10-28-2013, 04:23 AM   #14
Synner
Drives: not stock
My only concern is that it recommends non-synthetic oil and there's a lot of heat buildup during a track session. I bought a spare case to build up a rear but I don't want to put it in until I can get the Z28 diff cover and run a cooling system for added insurance with a torsen style diff.
