Old 10-18-2013, 01:53 AM   #1
LS6-M22
Rockcrusher
Drives: 2017 SS 1LE
2014 Z/28 roll up windows?
I was wondering if the new Z/28 will have roll up windows to save weight? I understand A/C is an option as is a radio so I'm wondering if power windows also will be an option?Anyone Know?It would make sense and most important save weight...
LS6-M22 is offline   Reply With Quote
Old 10-18-2013, 03:08 AM   #2
DavidW
Drives: 2013 ZL1 Vert Auto IOM
I doubt it , you would also lose the auto rolldown fuction of the window with manual windows so the glass would be subject to much greater strain when closing the door
DavidW is offline   Reply With Quote
Old 10-18-2013, 07:31 AM   #3
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
it has power windows, they are lighter than manual crank
-RPM custom cam, Kooks Headers W/ Cats, CAI Intake, Dewitt's radiator, Mocal 44 row oil cooler
-Z/28 Coilovers and Swaybars, BMR trailing arms, JPSS radius rod inserts
-C7 Z06 Front Brakes, Stainless Brake Lines, Quantum Ducts
-Z/28 Splitter, Underbody Panel, Spoiler and grille
AGM 1LE is offline   Reply With Quote
Old 10-18-2013, 07:23 PM   #4
Gary B
Gary B's Avatar
Drives: Subaru
Modern electronics...got to love that!
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
Gary B is offline   Reply With Quote
Old 10-21-2013, 03:12 AM   #5
Brian 1LE SS
Drives: 98 Camaro SS
Not sure why people still think roll up windows are lighter than power windows. Power windows have been lighter for decades.
98 Camaro SS M6, a few mods
13 Ram R/T, tow vehicle
6th gen??
<a href=http://www.norcal-lsx.com/multimedia/data/500/562752_4054654816027_115782456_n.jpg target=_blank>http://www.norcal-lsx.com/multimedia...15782456_n.jpg</a>
Brian 1LE SS is offline   Reply With Quote
Old 10-21-2013, 12:47 PM   #6
LS6-M22
Rockcrusher
Drives: 2017 SS 1LE
That's news to me. How so? The power motor must weigh more then a crank. The only reason I thought the Z/28 would come with power windows is it would be too expensive to engineer crank windows on a limited edition car being that power windows are standard and all you can get on all models.
Old 10-30-2013, 12:16 PM   #7
DavidW
there's linkage from the crank to the window and you need some sort of gear reduction in there too, and youre converting circular motion into linear motion
Old 10-30-2013, 04:30 PM   #8
Col. Brain
Drives: 2012 Ram 1980 Malibu
the Z/28 should have come with the old Chrysler belt windows that were in the super stockers in the 60s.
A belt and a snap attached to the window. 2 positions open or closed
Col. Brain is offline   Reply With Quote
Old 10-31-2013, 07:27 AM   #9
Serge627
Serge627's Avatar
Drives: 11 SS
Now thats a good idea, old school, hardcore!
Serge627 is offline   Reply With Quote
Old 10-31-2013, 03:11 PM   #10
b4z
Drives: '06 Pontiac GTO M6, '09 V8 SRX RWD
The reason it is coming with power windows is because they never designed roll up windows for the 5th gen. So its not worth the expense to design and tool the parts for 2000 cars.
b4z is offline   Reply With Quote
Old 10-31-2013, 03:15 PM   #11
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
That!
Arguably a small electric motor weighs more than a crank handle. But the difference these days is small. Very few GM cars can be had with manual windows and that is driven by cost on the end not mass which is also very critical.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 10-31-2013, 03:37 PM   #12
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
That!
It isn't the crank handle vs electric motor.
It's what's inside the door. Crank windows require a lot of heavier metal components, and electric hardly and additional metal at all. The motors are thin and lightweight. No comparison.
Bye bye, Bumblebee!
Old 10-31-2013, 06:25 PM   #13
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
I come from manual crank days. I will always choose electric power windows. Ever break a hand crank off? I have many times. Cheaply made and no longer relevant. Looking at all of the new drivers around me most these days would probably crash trying to roll up a window and drive straight down the road.
ZL1-V is offline   Reply With Quote
Old 10-31-2013, 09:14 PM   #14
Number 3
Number 3's Avatar
No, it's the motor. Look at any recent cable drive window regulator. You'll see the rails and cables and mechanism are pretty much the same between the two with the exception that you have a motor and a bracket. The difference is the motor weight, not the mechanism.
You might be thinking of the old arm and sector type drive mechanism and even then.............it's the motor.
