JDP Motorsports
Old 10-20-2013, 12:24 PM   #1
zobi10
Drives: Camaro
deep paint scratch - what do I do?
Soft cloth wash (NEVER again) put a pretty deep scratch about 6 inches below the side mirror on my passenger door. Like someone keyed it. White scratch, approx 7 inches long, thru the clear coat. Need to have it repaired.
Tried to attach a photo here...not sure I did it right.
Any idea on cost I should expect, how it should be fixed or any suggestions?
She's a 2014 2LT in blue ray metallic named Laverne, I live in Chicago.
Hope you guys can help. Sick about it.
Thanks.
zobi10 is offline   Reply With Quote
Old 10-20-2013, 12:27 PM   #2
SSTG
Drives: 2014 Z51 Corvette
If you want to try and repair it yourself, Dr.Colorchip is a good option.
If not, find a good Detailer in your area to fix it.
If you were closer I could help.
SSTG is offline   Reply With Quote
Old 10-20-2013, 01:09 PM   #3
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Expect about $500. That's the only way it'll look right.
Sent from my HTC One using Tapatalk 2
[B]
Old 10-20-2013, 10:55 PM   #4
Green Machine
Always Workin
Green Machine's Avatar
Drives: 2014 1SS 1LE
I have the same problem in a different area, my detailer should be able to fix it. Will find out next Monday.
After my hood wrap is done, this dealer will not touch my car.
Green Machine is offline   Reply With Quote
Old 10-21-2013, 10:39 AM   #5
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Thanks.
Ouch, sorry hear...
A proper repair would require respraying the area with color and blending the new color back into the door and front fender, then applying clear coat over any panel that was blended. It's really a pain and could be fairly costly for a good job.
You can attempt a DYI repair using a Dr. Colorchip patch and likely get good results, provided you aren't too anal.
I know you mentioned the scratch is white in color, which would lead us to believe it has penetrated through the clear coat However, sometimes the "white" is just residue from whatever caused the scratch. Can you feel it with your finger nail?
Old 10-21-2013, 01:40 PM   #6
alv927
alv927's Avatar
Drives: 2013 camaro 2ss/rs dusk edition
I have the same on my passenger mirror and stands out its about an inch and a half in length and was gonna take it in for repair. might try color match first.
alv927 is offline   Reply With Quote
2014, 2lt, blue ray metallic, scratch
