SDTW Custom Wheels & Tires
Old 10-20-2013, 12:17 PM   #1
Camaro Dude
and Sledge
Camaro Dude's Avatar
Drives: '13 1LE, 2SS, NPP
Elite Catch Can FULL of OIL at 2500km!!
Well I almost had a heart attach, upon first laying my eyes on this
Camaro Dude is offline   Reply With Quote
Old 10-20-2013, 12:25 PM   #2
Camaro Dude
and Sledge
The pictures above demonstrate how much oil was collected 2500km(1553 miles) later. I installed it approximately when the odometer was reading its first 800km(497 miles). Oil change was done with Mobil 1 5w-30 at around 1500km(932 miles) mark if memory serves right, so some of that oil in there is the factory oil.
I took 3 pictures because I was OBSESSED trying to figure out if it I allowed the oil to reach a too high level, and not allowing the oil to drain properly, perhaps even backing up !
I took a ruler out, and I think there were 2mm to spare before there would be no more room left for oil top drain in the can.
I'd like to hear your feedback on all this!
Is this amount of oil normal?
Does it look like I maxxed the can out?
Old 10-20-2013, 12:30 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
That's an excessive amount of oil. I drive my car very hard and I have never been anywhere near that. Something is wrong IMO. How did you break the car in? That has a lot to do with blowby, but either way that seems too much at 1600 miles.
Here is mine at 1700 miles (just ran out and took these)
Sent from my 2SS/RS
FSP tuned: 377/389
Old 10-20-2013, 12:36 PM   #4
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
My car 2013 1LE had an Elite can on it at maybe 800 miles and I've MAYBE got 2.5 oz since then.
I emptied it at 1500 miles when I changed out the factory oil. Followed it up at 5000 miles next oil change and measured just shy of 2 oz. Maybe 1/2"-3/4" of oil in the bottom of the can.
You sir have something wrong with either the can install or the motor itself. Is the motor consuming oil?
Firefighter is offline   Reply With Quote
Old 10-20-2013, 12:38 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Stop using that garbage Mobile1!
Switch to a better oil like amsoil and see the difference.
When I put Mobil in my Ls1 I would use 2 qts in 3k miles. I switched to Quaker state 10/30 and it would stop.
Old 10-20-2013, 12:43 PM   #6
nyrfan
Let's go Rangers!
nyrfan's Avatar
I usually agree with you, but in this case I somewhat disagree. I agree there are better oils, in fact next oil change I am changing to Pennzoil platinum. But my pics are with M1 and I have no oil loss at all and very little in my catch can. With that said I drove my car like I stole it off that lot which I believe has a lot to do with it, more so then the actual oil.
I think we agree that ring seating during the initial break in period is very important and improper ring seating can lead to excesses blow by.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 10-20-2013, 12:50 PM   #7
Camaro Dude
and Sledge
FWIW, I drive my vehicle hard, meaning I gave it the same break-in procedure as any car of mine in the past. You guys know which procedure I'm referring to, no redlining, but hard acceleration to 4500 rpm the first 1000km.....
To answer the above question if the engine is consuming oil, well I just checked the oil dipstick, car sitting all week. It is slightly above at the half way point, but let's call it half. Oil was replaced with the (as the gentleman aptly put it with the garbage Mobil 1 oil) at 1500km(932 miles) mark, and now it reads 3700km (2299 miles), so thats 2200km (1367 miles) since the last oil change.
The amount of oil we see in the catch can is not all that consistent with what I'm observing on the oil dipstick right now. I would of thought that it would have been a lower reading considering the amount of oil in that catch can?!
Could this mean it burned quite a bit during the break in stage as I was kicking it and now it has suddenly levelled off?
More data collection will surely answer my questions, but one thing is for sure. Anyone who questions that a catch can is not needed at all, because a stock (as the engineers intended cough...cough) car is the best, need think again.
Again FWIW, I'm performing an oil change with Amsoil 5W30 Signature Series and their oil filter this week, before I put the car away for the winter in a few short weeks.
Old 10-20-2013, 12:58 PM   #8
Firefighter
It's a shame you won't have a chance (due to weather) to drive it a couple thousand miles and monitor the oil situation. You may have to go straight to the dealer come the spring...
Old 10-20-2013, 01:01 PM   #9
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
I have the elite can as well. Initially I was catching a lot too. It's slowed down since.
45thAnniversary2SS is offline   Reply With Quote
Old 10-20-2013, 01:05 PM   #10
blueallie
blueallie's Avatar
Drives: Abm 1ss/rs 6m
I'd like to know more about this also as I'm having the same thing with my catch can.
halltech,flowmaster,kooks 1 7/8, Frost tuned.. Next some 3.91 gears and a bumpstick
blueallie is offline   Reply With Quote
Old 10-20-2013, 01:09 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Sent from my 2SS/RS
All motors are different bud. Lots of Ls1's back in the day were fine with it. Not mine lol. So I had to switch and it worked. It's a suggestion he could try and he could get back to us.
Old 10-20-2013, 01:19 PM   #12
Camaro Dude
and Sledge
I will do an engine oil analysis when I drain it next week.
Sadly, I won't be allowed to log much more on the new oil Amsoil fill, due to weather, unless of course winter arrives late. I stop driving it the day I see one grain of salt on the road.
I might get lucky, weather has been weird and unpredictable last few years.
Very very curious now what the end game to all this will be.
Old 10-20-2013, 01:34 PM   #13
SeaCompiler
...not a marine biologist
SeaCompiler's Avatar
Drives: 2012 Camaro RY SS LS3
... I switched to Quaker state 10/30 and it would stop.
Two cars I owned in the 90's with Quaker State blew up! I'll never put that stuff in my car again. Seems like they dropped off the map for about a decade and now it's back. I didn't think anyone was buying it!
Turbocharged with Huron Speed & Cammed with Cam Motion from Spartan Performance, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock, Turbosmart controller, MSD 2-Step, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, CAI, Cherry Bomb, blackouts, Lowered, Custom badges, VDI lambo doors, Hines vents,RPI fender vents, BlackVue 1080P Dashcam, Technostalgia Tail Lights, KW 500W on 10", Metra Kit, Pioneer AVH 4600BT, Morimoto RGB Halos, Tuned by Pat G
SeaCompiler is offline   Reply With Quote
Old 10-20-2013, 01:37 PM   #14
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
My Elite only had a couple ounces each oil change but I have a buddy with the same problem as you.
I'd really like to know the answer to this one too.
