Old 10-20-2013, 10:38 PM   #1
rray
rray's Avatar
Drives: 2013 GAZ 2SS/RS
I pulled the trigger on my home built NAV Radio this weekend:
I finally got rid of that horrible Mylink Navigation unit that came with my 2SS/RS. This weekend I put the replacement in, an I7 Mobile based CarPC. First I removed the Mylink screen and nav radio. That radio even has a CD slot, although there was no way to use it.
I had to cut some plastic away so all my electronics and the 8" screen would fit:
Next I made a video cable to tap into the oem backup camera, after getting and info and pin numbers from 2SSRS@Gen5diy, StealthZL1, and Robdollar77:
I was able to use a 90 degree Dupont Pin Header, as the pin spacing was perfect at 2.54mm, and I ty-wrapped it onto the connector so the cable would not come unplugged:
I built up a CarPC using mostly high temperature industrial components. An industrial socket G2 motherboard, Mobile I7 35W processor, 85C rated low profile DDR3, and I used a Hifidiy Saber USB DAC to output an extremely transparent audio signal. The power supply is a 160W intellegent DC-DC converter that uses a combination of ignition switch position, and timers to start and stop the PC, so I don't ever have to power down the PC. I just drive, and it runs automatically, and powers down automatically when I pull out the key:
I routed cables with airflow in mind:
If you see it, get it, for tomorrow it may be gone!
rray is offline   Reply With Quote
Old 10-20-2013, 10:40 PM   #2
rray
rray's Avatar
And after slapping the case together, installed a USB Bluetooth Dongle, and a Dual Band N WIFI Dongle:
There's lots of ports for expansion, as I add more devices down the road:
I modified the Metra kit to fit an 8" HDMI touchscreen, HDMI and Composite TFT driver board with auto video switching so I could switch from PC to Backup Camera whe I put the tranny in reverse, a Joycon programmable steering wheel button interface, and an intellegent 80W DC-DC converter to provide computer grade power for the screen and electronics:
I mounted the PC, Amps, Cap, and Sound Processor behind the seat and on the backside of the SUB box. Everything here is powered from a second Stinger Battery when the engine is off, and isolation opens up after the engine is started:
I have both a 1 Farad cap and a backup battery. The cap is just to make extra sure I don't have any power dips that could cause the PC to reset. Here is the batteries and isolation solenoid:
Here is the 8" touchscreen mounted in the metra dash kit:
Old 10-20-2013, 11:04 PM   #3
rray
rray's Avatar
I use the Driveline front end software. It's open source freeware, and the developer is open to suggestions of adding features. I can change the main page layout for stuff I want to use more, and put the other things on the next page:
I found I don't use reset, sleep, or hibernate, so I hid them and made the other power screen options larger:
The Media Player is screen I use the most, and since I have Album Art imbedded in each song, I like the larger window than the Mylink had for album art:
When I get hooked on a favorite sone, I put a star next to it on the Playlist page, and after selecting all my favorites, I can toggle the Play All/ Play Favorites button (bottom left), then turned on Shuffle to randomize the favorites I have selected:
Old 10-20-2013, 11:05 PM   #4
rray
rray's Avatar
I also have an OBD interface thatr pulls data:
The PC supports 3 screens, and the front end software supports 2, so I was thinking an addon will be to put a small flip up screen where the center speaker is to place gauges closer to the road, or even flip the screen mirror, and lay it flat for a second HUD off the windshield:
Old 10-20-2013, 11:49 PM   #5
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Wow man you went all in with this! Looks great. I find it funny how a bunch of us without the my link want it so bad, yet people such as yourself want nothing to do with it lol.
The only thing I would change is paint the dash kit. Idk why I just don't like the silver. Should paint it the same color as your car or something to give it something. Maybe wrap in vinyl idk.
But really if I had half the talent to do this, i would start to do it. I would be completely content with an iPad mini in the dash lol
45thCamaro is offline   Reply With Quote
Old 10-21-2013, 01:23 AM   #6
Johnthegreat
Johnthegreat's Avatar
Drives: 2012 2SS/RS black camaro
How much for the carpc
Johnthegreat is offline   Reply With Quote
Old 10-21-2013, 08:32 AM   #7
rray
rray's Avatar
Not including the audio stuff, I have about $1200 into it so far. It's not hard to do, its much like assembling a barebones home PC, where you buy all off the shelf cpu, memory, hard drive, power supply, and USB gadgets. Even the screen was an open frame lcd kit off ebay.
Add a metra dash kit to interface with the car, buy a copy of windows 7 and load, then get the free open source or paid "Front End" software, of which there are several to choose from, and you got a car pc that does everything a high end navigation head unit does but more and its expandable.
The hardest part was cutting the metra dash bezel, and re-gluing on the cut plastic parts like fingers to hold the lcd screen in place. You dont even have to do that if you buy a 7" screen, but I wanted to fit 8".
Old 10-21-2013, 11:00 AM   #8
45thCamaro
45thCamaro's Avatar
How does the navigation part work? Your running a program off the computer for it correct? How does it get a satellite signal.
I have a Mac mini just sitting here that would be perfect for this.
Old 10-21-2013, 11:32 AM   #9
rray
rray's Avatar
I have a USB GPS plugged in, and it's currently sitting on the right side of the rear deck. I don't have the microphone installed yet, so currently you would have to pull over and type in your destination. I also have a copy of Microsoft Streets and Trips that works with this USB GPS, but I have not loaded it on the PC yet.
I also have a digital I/O board to install, with 16 in and 16 outs, and each out can drive a 2A load common collector mode. The I/O is integrated into the Driveline front end software, so I can modify the code to turn things on and off by which screen I am on or by status of input bits, etc.
I also have a 6 port intelligent USB hub that I am going to mount in the cup holder area so I can plug in a USB volume control knob, and thumb drives, and charge my phone, etc.
There's lots of room for expansion.
You can install a Mac Mini, and run it off the intelligent DC-DC converter. It's output is jumper selectable up to 24V, I think the mini uses 19V? There are guys doing it.
Old 10-21-2013, 11:38 AM   #10
rray
rray's Avatar
Today is the first day I drove in to work with the new setup. I listened to FLAC files, kind of like 320 bit MP3's but lossless. The sound quality was totally awesome! Although I used a few patches of Dyanmat, the Camaro itself is very well insulated against road noise, so all I heard was crystal clear music. I was blown away!
Old 10-21-2013, 08:38 PM   #11
Robdollar77
Drives: 2013 Camaro 2SS
That's a awesome setup rray!
Robdollar77 is offline   Reply With Quote
Old 10-22-2013, 06:30 AM   #12
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
You, my friend, are the master. Incredible.
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 10-22-2013, 08:13 AM   #13
vtxretro02
vtxretro02's Avatar
Drives: 2012 Camaro 2ss Heritage Grill/GFX
Pm sent
vtxretro02 is offline   Reply With Quote
Old 10-22-2013, 08:21 AM   #14
rray
rray's Avatar
Thanks for offers for the old stuff, but I always keep the stock hardware and swap back just before trade-in. I get the best trade value with all dealer equipt, or dealer accessory option stuff.
