JDP Motorsports
Old 10-21-2013, 06:17 PM   #15
mcsoul
Drives: Want a gen 6
Originally Posted by Eagleone View Post
What part of the refresh is going to make the difference?
No idea, I just like to trust but verify.
mcsoul is offline   Reply With Quote
Old 10-21-2013, 11:55 PM   #16
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by willc1980 View Post
is this a traction issue? i pulled better times with my 2000 SS with 75 less HP
This is info has been asked many times but let me say it again; different gearing force you to shift into 4th just before the end of the 1/4 while the regular SS do not need it, AND the IRS/20'' wheels/manual is tricky to launch.
What was your 1/4 mile times with your 2000 SS?
TSP 231/236 111 lsa cammed 1LE
WHAMMO is offline   Reply With Quote
Old 10-22-2013, 07:34 AM   #17
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
12.588@110 is the time to beat. But great run Cammie! Bryan 1LE has the most impressive stock 1LE run so far 12.858 @ 112.61. The time is close to yours, but that is the fastest mph of any stock SS I think. Bryan has the shifting down.
I think with NPP (lighter+3HP) and electric power steering any 2013+ LS3 has a chance. But I think a standard SS has a better chance. I gave up getting into the 12s stock and joined the dark side. I think in the good air now I would have made it. But having fun trying to go deep into the 12s.
Fraxum is online now   Reply With Quote
Old 10-25-2013, 03:08 PM   #18
Vbh_1LE
Drives: Victory Red 2013 Camaro 2SS/RS 1LE
I've seen video of the "launch control" and I have tried it a couple of times with no luck.
Vbh_1LE is offline   Reply With Quote
Old 10-25-2013, 03:11 PM   #19
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
At the drag strip it's TC = Off and lots of practice.
Old 10-25-2013, 03:13 PM   #20
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Originally Posted by Fred 6528 View Post
Road course times are the important number for the 1LE. They are not set up for drag racing.
All you need is Drag Radials and 1LEs do just fine drag racing.
Old 10-25-2013, 07:28 PM   #21
detox
detox's Avatar
Drives: 2002 ss camaro
I thought the stock Good Years had an equally soft or close to it soft compound...they only last about 15000 miles.
How is the clutch holding up? Any chatter or warpage caused from speed shifting?
detox is offline   Reply With Quote
Old 10-25-2013, 11:09 PM   #22
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
The Goodyears are sticky, but the sidewalls are short and very stiff. So they have a very fine line between bogging and spinning. On standard SS Pirellis I was able to run 1.9 60's. The best I was able to do with the Goodyears was 2.1, although better drivers than me have run 2.0s.
As an example my best run was 13.2 in the heat of the summer, stock on Goodyears. I added a CAI and drag radials and started running consistent 12.80s. And this was with NT555Rs, not the best Drs.
The LS3 clutch is pretty stout. No chatter here at all, and I beat mine. I do have the clutch reservoir mod, so that may help the sticking to the floor problem. I have only seen the beginning of that, but so far not the problem I experienced on my '11 SS. Speed shifting is harder on the drive train than the clutch.
Old 10-27-2013, 01:00 AM   #23
SSCamaro1LE
SSCamaro1LE's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
I tried launch control twice in my car and it doesnt work, the stabilitrack brakes the wheels. Just launch around 2k!
SSCamaro1LE is offline   Reply With Quote
Old 10-28-2013, 05:57 PM   #24
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Just an FYI, don't drop the clutch when using the launch control as it doesn't work that way. You have to let the clutch out at a controlled but fast pace. (Not a side step)
Old 10-31-2013, 05:05 PM   #25
BAPD77
BAPD77's Avatar
Drives: 2013 Yellow ZL1/2015 Z51 Stingray
Road racing is where the 1LE shines, but high 12s is impressive nonetheless. It is still a drag strip capable car!
BAPD77 is offline   Reply With Quote
Old 10-31-2013, 05:39 PM   #26
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Mine is at 12.465 @ 114.20, with more still in it with bolt-ons and no tune. So at least the 1LEs are as capable as the standard SSes. If I can get my 60' down very low 12s are possible.
