Jason 98 TA
Old 10-21-2013, 08:17 PM   #1
Supercharged SS
Drives: 2010 Camaro
New engine is blown, and so is the trans.....New Damage Pics
and I'm f*#king done!!
Was told today the the number 8 piston needs to be replaced and the trans is slipping bad in 1st gear. Don't know the extent of the trans damage yet because it was not opened up.
Car was fantastic on the dyno. Struggled to make 4 passes last Friday. Got the stabilitrak and check engine light mid pass on run 4. Shut it down as fast as I could.
Simply posting this as to many like to know what's going on. Well, here's exactly what's going on.
This is the plug that was taken out. It still a ZR1 plug.
Currently gathering my thoughts on what to do next.
Supercharged SS is offline
Old 10-21-2013, 08:23 PM   #2
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Take it apart,fix it.Fix the tranny or you Can try a 6L90 tranny instead.
Get a bigger fuel system.
Race again.
Motion427 is offline
Old 10-21-2013, 08:25 PM   #3
white ZL1
Drives: none
Wow.
Let it sit. Enjoy the C7 while you decide what to do.
white ZL1 is offline
Old 10-21-2013, 08:26 PM   #4
Supercharged SS
Drives: 2010 Camaro
Race again.
The car will be fixed but right now I'm 50/50 on it ever seeing the track.
Old 10-21-2013, 08:32 PM   #5
Motion427
Take it easy on the NOS,and have fun with it.
It comes a time that 2 much HP and torque cost more $ than what it's worth.
Theirs nothing wrong with a high 9-low 10 second car that you can drive anywhere.
Old 10-21-2013, 08:35 PM   #6
joelster
Drives: '94 Z28+ '14 1LE
Ran out of fuel up top.
'94 Z28, 414" LT1, 10.15 at 133.65 N/A pump gas
'14 1LE, NPP, 12.991 at 109.40
joelster is offline
Old 10-21-2013, 08:35 PM   #7
Supercharged SS
Drives: 2010 Camaro
Originally Posted by white 2SS/RS View Post
Wow.
It's still with Nick over at ARH being used to prototype parts. Should be done in a couple more weeks. We had it for 2 days amd my dad was using it then.
You're probably right. Ever since the nitrous it's been eating plugs and breaking.
Old 10-21-2013, 08:36 PM   #8
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Sorry to hear. :(
I'm in a similar boat: hung around in Indy to get in one last run so I could win an extra $100. Hit it hard and broke the diff, then come home to find my EWP is leaking. So that $100 will cost me $5000 for a DSS 9".
I have the same question: build it stronger and better, only to go out, beat on it and break the next thing? It's not in my nature to not run hard, so it's a tough thought.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline
Old 10-21-2013, 08:36 PM   #9
old motorhead
Drives: Maggie blown LS3 vette
Ahhhhhhh shoot. that sucks. Was hoping for bigger and better on your latest. Don't throw in the towel now
old motorhead is offline
Old 10-21-2013, 08:38 PM   #10
Motion427
Don't forget.These Street camaro's is not a 2900 lbs fox body.
It's over 2 tons.
You got to give respect to you guys running 10's or 9's
Old 10-21-2013, 08:39 PM   #11
Supercharged SS
Drives: 2010 Camaro
Fuel pressure dropped to 49 on a few occasions. I'd believe you to be correct but I don't know enough to make any assumptions.
On the dyno the fuel pressure was very good, averaged about 65 and never going below 60.
Old 10-21-2013, 08:44 PM   #12
Motion427
Might be a stupid question.When you run it at the track,i'm guessing you log,but do you also log the AFR aswell?
Old 10-21-2013, 08:49 PM   #13
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
just a ? if you run nitrous can you also use meth to keep it cooler and not be so lean
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline
Old 10-21-2013, 08:49 PM   #14
Supercharged SS
Drives: 2010 Camaro
Yes log, no on the AFR. My father just asked the very same thing. Wouldn't have made any difference. By the time I saw anything bad it was to late.
