Gen5DIY
Old 07-14-2009, 09:23 PM   #1
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
yep... slow shifts...
So for giggles did a 0-60 run and capture the data... Looks like about .3 sec for the shift... seems a bit slow to me... gosh, this calls out for a tune! LOL!
I will say it did shift at 6950! LOL!
(click to view full size)
scrming is offline   Reply With Quote
Old 07-14-2009, 09:47 PM   #2
MadMaxx
Master of the V6
MadMaxx's Avatar
Drives: 2010 Camaro 1LT/RS
Damn torque management....
I do find if you get aggressive w/ the tap shifter, the times start reducing between up and down shifts. I piss that thing off...drive it like a SMG box LOL
MadMaxx is offline   Reply With Quote
Old 07-14-2009, 09:49 PM   #3
scrming
scrming's Avatar
LOL!
I do love the throttle blip on the downshifts! And of course the "Shift Denied" really should just be "NO!"
Old 07-14-2009, 10:04 PM   #4
Countach
Countach's Avatar
Drives: Future 2010 Camaro 2LT/RS
i have never really heard a strait answer on this, and you two seem to use the tapshift a lot. So is the tap still faster then someone who is pretty affluent with a manual or is it just a novelty?
2LT/RS Auto with IO interior
1100 - 7/12/09 - NMGJKP
2000 - 7/20/09 - Order Accepted By GM
2500 - 7/22/09 - Order Preferenced
3000 - 7/23/09 - Order Accepted by Production Control TPW 8/17/09
3100 - 8/5/09 - Order Available to Sequence
3300 - 8/5/09 - Order Scheduled for Production
3400 - 8/12/09 - Order Broadcast
3800 - 8/19/09 - Order Produced 2G1FC1EV6A9137780
4200 - 8/20/09 - Order Shipped
5000 - 8/27/09 - Delivered to Dealer
6000 - 8/27/09 - Home
Countach is offline   Reply With Quote
Old 07-14-2009, 10:14 PM   #5
MadMaxx
Master of the V6
MadMaxx's Avatar
For being a slushbox, it's quite fast on the upshift. I mean.. its no F1 box out of a Ferrari, but she's pretty quick. I don't like how much timing is pulled between shifts, you can feel the re-ramp of power...but I think this occurs on the manual gearboxes as well (perhaps not as pronounced).
It's pretty close to what the average Joe can bang out w/ a stick on the street, if not a tad faster. I don't think I've hit as bad as .3 though... that seems pretty brutal.
Should be tons of fun on a tight autocross course, never leave 3rd gear. The cool thing is that it will actually allow you to hold the revs to redline - most of the time the auto part will take back over and force the upshift. It will however tell you to kindly piss off if you try and downshift back to M2 from like 90MPH though (as it should)
Old 07-15-2009, 12:48 AM   #6
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
am so glad they put the shifters there. in drive at 50 mph (cruising) you are in 6th at just over a thousand RPM's. try to punch the gas from there and see what happens.......not a damn thing. but with the shifters you cant drop a gear or two and watch it starts kicking again.
trudawg660 is offline   Reply With Quote
Old 07-15-2009, 11:12 AM   #7
scrming
scrming's Avatar
Actually in Sport mode it downshifts very early and very quickly.. and in fact will drop 2 gears! At leas mine does.... Cruising like you said, if I get on the gas quickly by 1/4 throttle it's downshifting! Keep pushing and it down shifts again!
Hmmm... sounds like a good data logging experiment... at what throttle point does it downshift? LOL
Old 07-15-2009, 11:16 AM   #8
scrming
scrming's Avatar
Yeah, this was in Sport mode not Tapshift... hmmm... guess I need to make a run with the Tapshift and see if the shift is quicker...
Looking back at my Mustang logs looks like the shifts were about .25ish... Unfortunately I don't seem to have the ability to log the commanded shift time and the actual shift time... Does seem like it could use a bit of firming up...
My other thread on data logging from the track really shows the drop in timing when the car shifts...
Old 07-15-2009, 04:48 PM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
In my L99 A6, when I mash the gas at 50mph it quickly drops a couple gears (I believe it drops to 3rd gear from a 50mph punch) and pulls pretty hard. I'm not sure where the 2nd gear cut off is. I'm still trying to figure out the max drop down speeds for each gear. I had the A4 completely figured out in my GTO.
But your A6 shouldn't be staying in 6th gear when you punch it going 50mph. I should quickly downshift to most likely 3rd gear. If you were going a little slower, it would most likely drop to 2nd gear.
Old 07-15-2009, 07:38 PM   #10
trudawg660
a couple weeks ago i was driving close by a G35 at around 45 to 50 mph. so he decided to gun it a little. and for the fun of it i pushed it from 1/8 throttle to about 1/2 at just over 1000 rpm's i heard alot of engine but not alot of go (because it stayed in 5th).
since then i have gotten very comfortable with the paddle shifters so if i had the urge to speed up more. i would put it in sport mode and use the shifters and drop it some gears. and 1,000 rpm's turn into 6,000 rpms very quickly.
Old 07-15-2009, 07:41 PM   #11
trudawg660
i think am going to go out and see if it will drop a couple gears. (maybe it could of been all in my head)
Old 07-16-2009, 05:00 PM   #12
scrming
scrming's Avatar
Dashhawk records shift time! Only quickly tested it out.. downloading now!
Old 07-16-2009, 05:40 PM   #13
scrming
scrming's Avatar
Ok.. so this was just puttering down my street...
First set of shifts in D mode:
1->2 = .400
2->3 = .325
Send set of shifts in S mode:
1-2> = .300
2->3 = .250
Data log graph:
Will data log this next time i make it to the track!
Old 07-16-2009, 06:09 PM   #14
MadMaxx
Master of the V6
MadMaxx's Avatar
I want logs of TAPs damn it!
L99 owners with slow cars going to dealers for fix. Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 131 12-21-2009 03:30 PM
Slow off The line? NeedMyFix 5th Gen Camaro SS LS LT General Discussions 16 06-29-2009 09:29 AM
challenger slow because of wheel hop? What about Camaro? jordan 572 5th Gen Camaro SS LS LT General Discussions 77 02-17-2009 10:23 AM
Fast or Slow Car stovt001 General Automotive + Other Cars Discussion 8 09-14-2008 02:31 AM
Its been slow... FLAWLS3 5th Gen Camaro SS LS LT General Discussions 10 08-14-2008 06:29 AM
