ADM PERFORMANCE
Mechanical Maintenance: Break-in / Oil & Fluids / Servicing Discussions on mechanical maintenance and servicing of your Camaro
Old 07-14-2009, 10:47 PM   #1
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
Oil change based on oil life monitor?
If I did that, I'd be going almost 15,000 miles between oil changes. What's up with that? I have over 1600 miles on the car since the last (first) oil change and the oil life monitor tells me I have 89% remaining. There is NO WAY I will be going another 13k+ miles, much less 3k miles before it's changed again. Is the monitoring system really worth a damn? Is GM crazy enough to really stand behind their warranty if someone doesn't change their oil for 12,14,16k miles based on the monitoring system? Just curious. You guys seeing crazy numbers like that?
trm0002 is offline   Reply With Quote
Old 07-14-2009, 10:48 PM   #2
Vash
Drives: 00 Blazer
It's for the people that buy cars and just drive them till they die or they get another. Some folks never open the hood themself during the entire ownership of a car.
So no it's not for hardcore gearheads that's 4 sure. The percentage is not time but condition I think.
Old 07-14-2009, 10:57 PM   #3
five-oh
five-oh's Avatar
Drives: 2010 Camaro 2SS/RS Victory Red
I've done a little research on this and what I've heard is that today's oils are so good compared to where they were years ago that changing oil at 3,000 miles is nothing more than a waste of money. By changing the oil so soon, the oil never actually "breaks in" to its maximum viscosity. With longer, even lifetime, powertrain warranties I don't think the manufacturers would be calling for such long intervals if they didn't feel confident in the abilities of today's oil. The manual on my work Impala specifically says not to change the oil until the monitor indicates to do so.
five-oh is offline   Reply With Quote
Old 07-14-2009, 11:02 PM   #4
trm0002
trm0002's Avatar
But what's the real deal with Mobil1? It SHOULD last longer than regular oil but do you really want to bank on that? I have never been a 3k oil change religious zealot but I have never been a 10k nut either. Regardless of the vehicle I have/had, it's always been a 4-5k change cycle; you know the routine- "damn, 4000 miles, gotta stop soon and get the oil changed"...becomes..."holy s*** almost 5000 miles, gotta stop TODAY and get the oil changed"...
I think that's about where my comfort level remains with the Mobil1 until someone tells me different and why; around 4k between changes.
Old 07-14-2009, 11:07 PM   #5
SSOOCH
"El Dictator"
SSOOCH's Avatar
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429
Synthetic oils don't break down for at least 12k miles. You are wasting your money, but I'm still changing mine at 500, 1500 and then every 3000 after that. It's all preference.
Old 07-14-2009, 11:12 PM   #6
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
SSooch, you stated the 1st sentence as fact and then you proceed to go against it. Why would you change your oil b4 12K if it does not break down? Obviously you do not trust your factual 1st statement. I will change my oil every 7,500 miles and use Mobil 1 synthetic oil. Why? Because that's what GM recommends and the oil they felt confident in it in upholding their warranty.
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 07-14-2009, 11:50 PM   #7
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Send a message via MSN to edog
The service Manager at Radley states he changes his every 5k. The salesman I purchased from said to change it when the car tells you to, which is around 7k. I just went to check my indicator, and I am at 70% life remaining. I have 3400 miles on mine.
I feel if regular oil gets changed every 3k to 5k, then synthetic should be able to last at least twice as long. My question is does the car determine by distance, or viscosity of the oil? How does it tell?
Doug Thorley Tri-Y LT/cat back, Ported TB, Halltech CAI, Pedders sways, endlinks, Drop Springs, Tuned by TandTPerformance 371HP/383TQ
edog is offline   Reply With Quote
Old 07-15-2009, 06:36 AM   #8
earn88hardt
Drives: 2010 IOM Camaro SS
The engine oil monitor is based on the hours the engine is run not teh miles on it
earn88hardt is offline   Reply With Quote
Old 07-15-2009, 07:02 AM   #9
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I would say run 7500-8000 on the oil, if you are a firm 3000 guy move that up to 5000 with synthetics or just move back to dino oil and do it every 3000.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-15-2009, 09:58 AM   #10
CamaroHutch
CamaroHutch's Avatar
Drives: 2010 Camaro 2SS RJT
It actualy monitors several indicators, such as engine revolutions, temp, etc.
Ordered Jan 09
2SS RS RJT
Delivery?? 5/27/09 #10630
AFTERMARKET:
Hurst STS
Borla ATAK Catback
CamaroHutch is offline   Reply With Quote
Old 07-15-2009, 10:05 AM   #11
trm0002
trm0002's Avatar
Same earlier question. Does GM then stand by the engine if you (crazily) don't change the oil until the monitor tells you to?
Old 07-15-2009, 10:08 AM   #12
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Crazily? I'd have to dig for the post but that's what Number 3 recommended.
Edit: here ya go.
UCF w00t is offline   Reply With Quote
Old 07-15-2009, 10:09 AM   #13
trm0002
trm0002's Avatar
You're telling me that if your indicator didn't tell you to change your oil until 14,000 miles you'd be ok with that? I sure as hell wouldn't be.
Old 07-15-2009, 10:13 AM   #14
UCF w00t
Geek
UCF w00t's Avatar
No, I wouldn't. I'd certainly change it before then. But the idea of not changing it til the thing tells you to isn't that crazy... I'll probably do my first change around 1000 or 1500 miles but 6k-8k after that, depending on what the OLMS says.
Old 07-15-2009, 02:34 PM   #15
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
Good for you guys i go by the indicator on all my GM cars my 1996 Impala had 254,000 mi on it and i sold it to a guy that works for me and he still drives it work every day, My 2004 GMC denali yukon xl has 207,500 mi on it and it runs all the time and that is all on the indicator, So all my cars run all most 10,000 mi before a oil change.
2SSRS is offline   Reply With Quote
Old 07-15-2009, 03:23 PM   #16
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I've always been told by my mechanics and some mechanic friends as well as the techs at my local Chevy dealer to change the oil every 1,000 miles per quart of dino oil and 2,000 miles per quart of synthetic oil. I was told this is where the 5,000 mile mark for for dino and 10,000 miles mark for synthetic came from as most engine take around 5 quarts of oil. With a 8.6 quart capacity, the SS will easily go 10,000 miles before needing a oil change.
Old 07-15-2009, 03:51 PM   #17
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
actually, its based of the hours, the operating temps, the loads put on the motor, the miles, oil press, and other inputs.
its not how long the motor was ran, its HOW the motor was ran.
I'd change it at 10k personally.
but modern engine technology as well as modern oil technology has surpassed the old school "3000 mile oil change" requirement. my 94Z still gets the oil changed every 3k during the off season and every 500 miles during the racing season. but I thrash the living piss out of that car.
my 98 pickup with 191k miles on her gets the oil changed around 7k miles, the 08 pickup got the first oil change at 1500 miles and a second one at 11k.... when the OLM indicated it needed an oil change (was at 28%)
another thing to keep in mind...
the OLM is not going to register the oil life directly proportional to the miles you travel. sometimes it will be 7k, sometimes it will be 12k, etc. it all depends on HOW the miles are driven. if you cruise the highway 90% of the time, your oil will last you longer than someone who is thrashing on the car all the time. just part of the way it works.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 07-15-2009, 03:57 PM   #18
wullger
Bring on the Supercharger
wullger's Avatar
I wait until the OLI on my Sierra tells me I have about 20% life left, then take it in. It's about that time I notice gas mileage going down, too.
Your mileage may vary, since Camaros and Sierras are two VERY different animals, but it's been my experience the OLI is pretty reliable
Here's the OnStar page about the OLI: http://www.onstar.com/us_english/jsp...s/oil_life.jsp
2SS/RS IBM A6, White Rallies
1100: 4/30/09 2000: 6/30/09 3000: 6/30/09
3300: 7/15/09 TPW of 7/27! 3400: 7/22/09
3800: 7/28/09 #30334!! 4B00: 7/30/09
4200: 8/5/09
6000: DELIVERED! 8/18/09
wullger is offline   Reply With Quote
Old 07-15-2009, 03:58 PM   #19
GrnMchin
Not easy being Green
GrnMchin's Avatar
Drives: 67 Nova SS
+1
I don't fear the oil breaking down rather the dirt that it picks up. Yes the filter should take care of most but not 100%.
GrnMchin is offline   Reply With Quote
Old 07-15-2009, 07:28 PM   #20
UCF w00t
Geek
UCF w00t's Avatar
Came across this today in the OnStar maintenance report...
http://www.goodwrench.com/_res/pdf/OLS1.pdf
Old 07-15-2009, 07:43 PM   #21
surferbarney
surferbarney's Avatar
Drives: 2010 Camaro, 1999 Mustang
My cousin has a corvette and uses mobil 1 synthetic and he changes his oil only every $12K miles or so.
2010 Camaro 2SS RS
IOM exterior, IO interior
Black Rally Stripes (painted aftermarket)
GFX Package
Pre-Ordered 1/19/09
2000 4/9/09
3000 4/24/09
3300 5/4/09
3400 5/9/09
3800 5/15/09
Delivered 6/2/09!!!!!
VIN 2G1FT1EWXA9110199
surferbarney is offline   Reply With Quote
Old 07-15-2009, 07:55 PM   #22
CamaroSpike23
The Jalopy Jedi
thats some expensive miles...
I piss excellence
Old 07-15-2009, 08:05 PM   #23
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
I'm comfortable at 10K miles between oil changes after the break in.
GMtothecore is offline   Reply With Quote
Old 07-15-2009, 08:32 PM   #24
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
I'll need therapy if I let it go anymore than 4000 tics without changing, 125K on the S-10 and 147K on the Silverado. But at 80 to 90 dollar a oil changes I might be able to let go bit further. (Ufc woot) good information
69 Hugger is offline   Reply With Quote
Old 07-15-2009, 08:42 PM   #25
KJS
4 years old May 2013
KJS's Avatar
Drives: '10 in RJT; 95 Vette
I usally change it when the wife goes on the warpath. Takes about 5-6 hours to do.
Sometimes it needs changing every other weekend.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Is the Earth producting MORE oil???... Scotsman General Automotive + Other Cars Discussion 11 04-21-2008 04:37 PM
Oil Change anyone? The_Stache General Automotive + Other Cars Discussion 9 01-30-2008 01:43 PM
Huge offshore oil discovery KILLER74Z28 Off-topic Discussions 36 11-14-2007 06:14 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
