BeckyD@RodgersChevrolet
Old 10-29-2013, 09:15 PM   #29
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
I'd like to go 3.91, but I don't know how well that would match up with your auto, so, sorry, I'm not much help here.
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-29-2013, 09:24 PM   #30
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
John B.
After I get ss rear diff, axle, and rear portion of the driveshaft it should be the same as you having on your car aside from the clutch and all of the parts it encompasses correct? Or am I thinking incorrectly? I'm just curious as to what you mean by "matching up"?
13lstuner is offline   Reply With Quote
Old 10-29-2013, 09:44 PM   #31
JohnnyBfromPeoria
It depends on the individual gear ratios of the six speeds spitting out rotations from the transmission, of which I am not familiar. It all works together to make the overall total ratio.
And you also need the SS wheel hubs as I understand it.
John B.
Old 10-29-2013, 09:48 PM   #32
13lstuner
13lstuner's Avatar
John B.
Yes I will. It makes me very upset that the 2LS will not accept the 3.55 gears. As according to people on this forum. Because of the carrier. If this wasn't the case I would just get these gears.
Old 10-29-2013, 10:26 PM   #33
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
I decided to do a little research on the carrier issue. They are indeed listed as 2 different carriers
The 3.27 (LT) carrier GM p/n 92230616 list price $221.30
The 2.92 (2LS) carrier GM p/n 22759584 list price $590.00
If you wanted to just add the 3.55 gears to your car, just buy the LT carrier, it fit will your car. GM parts direct lists the LT carrier for $129. I could probably get it from my dealer parts dept for $160 something. Then you can buy my brand new set of 3.55's on the classifieds. Cheaper than an SS rear end swap.
2016 1LT RS, 2.0T A8
13.462 @ 100.65, stock eng/tune w/ some weight reduction
Jason@JacFab is offline   Reply With Quote
Old 10-29-2013, 10:32 PM   #34
13lstuner
13lstuner's Avatar
If you wanted to just ad the 3.55 gears to your car, just but the LT carrier, it fit your car. GM parts direct lists the LT carrier for $129. I could probably get it from my dealer parts dept for $160 something. Then you can buy my brand new set of 3.55's on the classifieds. Cheaper than an SS rear end swap.
My life is complete
Any special tools needed for gear swap? I wouldn't imagine so? Relatively easy self instal of the carrier and new gears?
Old 10-29-2013, 10:52 PM   #35
Jason@JacFab
Originally Posted by 13lstuner View Post
My life is complete
If you don't have, or no one you know has any experience with properly setting up gears, this IS NOT a DIY task... At the bare minimum you would need a press, feeler gauge(s) may or may not be useful, a (or multiple) dial indicators, and a torque wrench. A gear swap is not for the faint of heart.
Honestly your best bet would be to remove the whole center section of your rear end, which can easily be done with normal hand tools, take it, the gears, and the carrier to a local shop that can properly set them up so they last. Taking them in the center section will minimize your labor cost to get it done, rather than taking them the whole car and letting them pull it out.
Call around and get some quotes on what it costs to put some new gears in a rear end. It may be hard to find places that do it as it's a rare practice anymore and the art seems to be dwindling, I can only find one place in my town that will still do it.
Old 10-29-2013, 11:16 PM   #36
13lstuner
13lstuner's Avatar
Message received, I am not doing the instal hahahahaha.
Old 10-29-2013, 11:49 PM   #37
Jason@JacFab
On the plus side, an SS rear end swap should be able to be done with normal tools...
Old 10-29-2013, 11:54 PM   #38
JohnnyBfromPeoria
Backlash and preload need to be set and the gear mesh checked with a dye marker like Prussian blue. Simple, right?
John B.
Old 10-30-2013, 04:32 PM   #39
13lstuner
13lstuner's Avatar
John B.
Sound like it! Haha
Old 11-26-2013, 06:33 AM   #40
BlackoutLFX
BlackoutLFX's Avatar
Drives: 2012, Black 2LS
fyi, i did the gears with the ss 3.45's....super mod......did not have to change anything about my driveshaft....2012 2l2..and my Mace cams are on the way....Just got an email from the nice folks at mace.....I am assured this should be around 40+ hp at the wheels depending on tuning and mods.....that plus a hundred shot sounds pretty damn fine. here is a short video of it now...full bolt ons.
https://www.facebook.com/photo.php?v...type=2&theater
BlackoutLFX is offline   Reply With Quote
Old 11-26-2013, 09:22 AM   #41
13lstuner
13lstuner's Avatar
Whenever you get those cams installed you have to put a video up of the exhaust!
Also, have you gotten a quote as to how much they are gonna be to put in?
Old 11-27-2013, 07:58 PM   #42
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
I have added this information to the 2LS sticky.
Thanks!
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
cam, kit, lfx, tune, warranty
