Old 10-23-2013, 09:12 PM   #1
eagle1
eagle1's Avatar
Drives: 69rs/ss 2014 ss/rs 1le
Best way to break in engine on 2014 ss/rs 1le
Hi just bought a new ss and just wanted to see what the word is on brake in on the new camaro's with the Ls3. Im getting a few different ways to go about it. I would like to hear what the best way is to go about it. Im new here and i hope to learn some great stuff on the camaro. Thanks
Semper Fi
Luis
eagle1 is offline   Reply With Quote
Old 10-23-2013, 09:15 PM   #2
SemperGumby
I'll probably offend you
SemperGumby's Avatar
Drives: 2013 2SS/RS M6
I drove mine pretty gingerly til 500 to 600 miles then let loose on it like I stole it. That's what other's I worked with did and it turns out pretty damn well. Just make sure to change the oil after around 1500 miles no matter what you do.
SemperGumby is offline   Reply With Quote
Old 10-23-2013, 09:17 PM   #3
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
best way to brake is, fill gas tank with jet fuel. your welcome
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe
2002 35th Aniversary SLP SS-Sold
aggieguy13 is offline   Reply With Quote
Old 10-23-2013, 09:21 PM   #4
eagle1
eagle1's Avatar
I knew some one was going to eat that up once a seen what i wrote! What about the real brake in any ideas!
Old 10-23-2013, 09:24 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I got my foot into it during break in but kept it under 4500 rpm for the first 500 miles. Also engine braked a few times per drive. Seated the rings well, hardly any oil in my catch can, just condensate for the most part.
Iam Broke is offline   Reply With Quote
Old 10-23-2013, 09:29 PM   #6
SGDM
SGDM's Avatar
Drives: 2016 2SS
I dumped the synthetic, put in Pennzoil, drove it like I stole it for 500 miles, put Mobil 1 in it, and all is good. The synthetics are slick and won't allow the rings to seat the cross hatch cylinders.
Who Dares...Wins
ADM Performance Built LT4 SC
SGDM is offline   Reply With Quote
Old 10-23-2013, 09:33 PM   #7
eagle1
eagle1's Avatar
I heard pamper for 500 change oil and rip it. I also heard 1000 miles change oil a run it like you stole it. The last one said run for 500 miles change oil run for 2500 miles change oil and run hard. None of this really makes sense to me! I run many 60's gm hot cars and it was a typical deal brake in easy for 500 miles check oil for any signs of metal. If good start getting some heat cycles in and run it hard!
Old 10-23-2013, 09:35 PM   #8
eagle1
eagle1's Avatar
Thanks for the info man.
Old 10-23-2013, 09:38 PM   #9
mrpyle
mrpyle's Avatar
Drives: 2011 2LT/RS - Synergy Green
Any thoughts on Royal Purple break in oil??
mrpyle is offline   Reply With Quote
Old 10-23-2013, 09:39 PM   #10
eagle1
eagle1's Avatar
Did you leave the syn in it broke in with?
Old 10-23-2013, 09:42 PM   #11
eagle1
eagle1's Avatar
Ok i have just under 350 so far in 3 days you think its cool to change it now?
Old 10-23-2013, 09:44 PM   #12
Iam Broke
PHAT B33
Iam Broke's Avatar
Factory oil until 1500 miles, then Red Line 5w-30. Penz Ultra starting next change before storage.
Old 10-23-2013, 09:49 PM   #13
eagle1
eagle1's Avatar
This is crazy they should brake it the engine at the factory. I hate having to wait! This ride is sick and i cant get in it! Thanks for the info man
Old 10-23-2013, 10:00 PM   #14
fradaj
Drives: RS
I would say just drive it normally for about 600-1000 miles before any hard driving. I don't think any early oil change is really necessary. Most important thing is not to overheat the engine.
fradaj is offline   Reply With Quote
