HURST
Old 10-23-2013, 09:13 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Might be trying something new Friday at T&T
Well folks my current setup with the 100HP nitrous setup maybe getting bumped up to a 140 setting this Friday night. I'll do some short pulls locally and see where the A/F is before doing a 1/4 mile track pull. So anyone want to take a stab at ET /MPH. My best 1/4 mile to date is 12.41@108.11 with a 1.667 60', 7.861@85.94 1/8mile ( DA -660' ). I did pull a 12.43@107.87 last week so my current setup is working nice. ( DA -580 )
Looks like temps should be about the same as last week, so DA should be close.
Thanks MATT@FSP for a great tune.
etmx183 is offline   Reply With Quote
Old 10-23-2013, 09:59 PM   #2
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
Tis DA season. Good luck!
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 10-24-2013, 09:45 AM   #3
KMPrenger
KMPrenger's Avatar
Don't blow the car up!!
If you can get good launches like before, I'm calling a 12.15
Old 10-24-2013, 10:13 AM   #4
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
12.29 is my guess...hopefully faster though!!
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 10-24-2013, 03:53 PM   #5
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
i'm going to guess 12.0x!!!!! GOOD LUCK!!!!!
Old 10-24-2013, 04:16 PM   #6
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Rich needs some company, so I'm going to say 11.83!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-24-2013, 09:15 PM   #7
etmx183
etmx183's Avatar
I did a 3rd gear pull A/F stayed 12.2 -12.3. I needed to get the nerves out of my stomach. So now I feel good about the setup right now. If all goes good Friday than I'll be ready for the 3.91 gear install. Thanks folks for the replies. If I go 11.XX anything you folks will probably only see a brown spot here because I will, well you get the message.
Old 10-24-2013, 09:54 PM   #8
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Best of skill, ETMX.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 10-25-2013, 01:30 AM   #9
blackTT600
Drives: 2011 2LT M6 SC
11.XX would BE SICK!!! good luck! and like KMP said please don't blow up!
blackTT600 is offline   Reply With Quote
Old 10-25-2013, 08:57 AM   #10
HDRS
Fastest V6
HDRS's Avatar
Drives: 2010 CGM 2LT/RS 06 G6 GTP conv.
Hey etmx183 if you hit the nitrous off the launch and you are on MT 20”DR then I will say 11.92 on your first pass but make sure the bottle is 1200PSI.
If you roll into the nitrous then I will say 12.10 Good luck.
BTW if you beat my time then you better be at ATCO on black Friday.
1/4 Mile 11.841 at 113.98mph
SEPA5 /TEAM LLT
HDRS is offline   Reply With Quote
Old 10-25-2013, 09:45 AM   #11
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
May the wind be at your back, the track slope downhill and may you break into the 10's.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline   Reply With Quote
Old 10-25-2013, 10:28 AM   #12
etmx183
etmx183's Avatar
My MT D/Rs are on the car 24/7. If I beat your time I'll be at ATCO but this NYTREX system, nitrous and purge solenoids don't like pressures above 1050PSI or the nitrous solenoids won't always open. Thanks for the words of wisdom. Low 12s Say 12.00 - 12.10 I would very happy tonight. Then my gears ( 3.91 )will go in and I'll do a slow break-in during the winter and be ready for Spring.
lfx, nitrous, nytrex, v6 camaro 1/4 mile
