Old 10-24-2013, 10:21 AM   #1
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
GM Oil pump fail
Hi guys, finally got bit. Started it up and rolled about 50 feet and got the dreaded "No Oil Pressure" message. Shut it down. I know you've heard this story before. Here is the twist...
This was already a new pump installed when I did my CAM at 10,000 miles. I am now just over 25,000. JDP motorsports suggested the early change as a preventive measure at that time. Little did they know that the GM pumps continue to fail even in the new year models and was not just a bad batch problem. They have fixed 6 other Camaro's already this year apparently.
So the moral to my story and maybe what you readers should take away is don't replace bad with bad. I am going to put a Melling oil pump in this time which is what JDP is using going forward. I am just hoping that there was no damage up top to add to my grief.
That is all! Have a good day.
gr8daneh is offline   Reply With Quote
Old 10-24-2013, 10:41 AM   #2
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Thanks for letting us know. Hopefully no damage!!
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Twin Mini's...soon
Permagrin...Always
Unobtainium is offline   Reply With Quote
Old 10-24-2013, 01:28 PM   #3
briancb1
briancb1's Avatar
Drives: C6 Z06
Sorry to hear but wow lack of details.How did it fail?Debris cause a the reliefe plunger to be stuck i assume? No aftermarket pump will fix that unfortunetly as they all are copies of the OE design in that regard.Bad batch? What was bad about them?
briancb1 is offline   Reply With Quote
Old 10-24-2013, 01:31 PM   #4
jth6373
Drives: 2013 Camaro 1SS
Is it a more aggressive cam which is causing these to break, or is this happening on stock engines as well?
'13 1SS - TSP 229/236 112LSA Cam, TSP 1 7/8" LT headers with off-road pipes
jth6373 is offline   Reply With Quote
Old 10-24-2013, 03:39 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
No it is not a copy melling 10296's are of different materials and are blue printed. The plunger sticks or the rotors gall due to two cheap metals in contact with each other.
Ls pumps have sucked since 1997 they are all the same. Except the L99's but the melling a are still an upgrade.
Old 10-24-2013, 03:41 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Pump failures have absolutely NO correlation with big cams.
Old 10-24-2013, 03:48 PM   #7
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Unknown what the failure mechanism is. The event was just last night. JDP is going to open it up this weekend, but all indicators are debris causing a stuck plunger which is the common failure mode with the GM pumps.
Old 10-29-2013, 10:44 AM   #8
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Fuuuuuu****K! Just got the verdict. Scored my CAM to sh*t, lifters are bad, check valve completely stuck open on pump = no pressure. Only ran for less than a minute this way. Looks like major dollars for less than 15,000 miles of run time. Can't believe it. :((
Old 10-29-2013, 10:54 AM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
What a nightmare, sorry man, thats awful.
Old 10-29-2013, 11:21 AM   #10
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Question then is: did the cam disintegrate first, introducing metal into the oil and causing the oil pump regulator to stick? Seems to be common, and frankly makes me very nervous, given my setup.
Cam brand? Oil brand?
Sorry for your troubles, OP. Good luck, my friend.
Bye bye, Bumblebee!
Old 10-29-2013, 12:25 PM   #11
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Thanks! Appreciate the empathy...
CAM Is missing a chunk, not sure that happened first. Comp CAM, Mobil synthetic. Thanks for the wishes.
Old 10-29-2013, 06:03 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Mobil 1 makes me cringe when guys/gals get aggressive cams
Old 10-29-2013, 06:10 PM   #13
BigRed
BigRed's Avatar
Drives: SS RS SIM
May I ask why? I'm actually curious due to the fact I'm going in for a Cam install Monday and that's what they said they are going to put in the car.
BigRed is offline   Reply With Quote
Old 10-29-2013, 07:52 PM   #14
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Sounds like another one of the comp cam failures. A chunk of a cam for less then 60 seconds without oil pressure seems like a bit much.
I once had a Dodge Ram with a 318 where the old gasket stuck to the block after changing the oil and filter. With more then 1 minute running driving to an exit with no oil pressure I had the truck towed home, put a new filter and oil, and all's well for 140,000 miles and counting (my brother in-law still has it on the road).
I've got a the factory oil pump in my car with over 30,000 miles since a cam swap (ZR1 cam) with nothing but Mobil 1 0W40. The rev limiter is set at 6,800 rpm and is brought that high pretty frequently with dozens of 1/8 mile passes. Only at my last oil change did I start adding a ZDP additive.
Granted my cam uses stock springs which aren't high pressure but I wonder how many of the oil pump failures posted have been with comp cams?
Irnwkrkev is offline   Reply With Quote
