JDP Motorsports
Old 10-24-2013, 09:34 PM   #1
Fear1LESS
Fear1LESS's Avatar
Drives: 2013 Black 2SS/RS/1LE
Oil question
Hey guys so I really want to get the best oil for my 1LE I'm curious as to what you guys recommend and/or what you guys are using for all your fluids. Also if you guys could include what weight you use that would be much appreciated. Thanks in advance
2013 Black 1LE 2SS/RS 1 of 451
Fear1LESS is offline   Reply With Quote
Old 10-24-2013, 09:44 PM   #2
Cleancoupe
Drives: 2013 AGM 2SS/RS/1LE
Mobile 1 full synthetic oil, redline d4 ATF & redline 75w90 rear diff
Cleancoupe is offline   Reply With Quote
Old 10-24-2013, 09:49 PM   #3
Fear1LESS
Fear1LESS's Avatar
this may be a noob question but can you use ATF for a stick shift?
Old 10-25-2013, 06:45 AM   #4
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Just MHO, but you can find much better oil than Mobil 1. It isnt what is used to be. There is an entire section dedicated to lubes, I suggest you search around there and read some threads. I did the same a while back and learned a ton.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is online now   Reply With Quote
Old 10-25-2013, 07:01 AM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Yes, I am running Redline AFT in mine and it shifts so much better.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-25-2013, 09:25 AM   #6
willc1980
Drives: 2013 Camaro SS 1LE
mobil 1 has the 2nd highest film strength in testing, what are u basing this statement on??
willc1980 is offline   Reply With Quote
Old 10-25-2013, 09:26 AM   #7
willc1980
i run the same except Torco SGO in the rear diff
