Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 10-26-2013, 02:27 AM   #1
Rornls3
Drives: 2010 RJTC 2SS RS/SS LS3
Question Heater ON = cool engine temps during HPDE ?
So plain and simple question. To HELP with keeping an LS3 cool, does turning the fan and heater ON during laps around a track help?
I was a passenger in a 350z twin turbo and he blasted the heater the whole time and even with the windows down it was dreadfully hot, but he claims it helps keep his temps down.
Any thoughts or experiences? I still haven't asked my tuner but thought I would post up to everyone here.....
Rornls3 is offline   Reply With Quote
Old 10-26-2013, 02:35 AM   #2
Quick
Quick's Avatar
Drives: 2012 Camaro SS 45th
I've done it several times....Yes it works.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh...
Quick is offline   Reply With Quote
Old 10-29-2013, 09:21 PM   #3
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
No personal experiences in doing this, but I have heard it claimed to work many times. Although Clinton claimed to not have sexual relations with that woman as well.
13lstuner is offline   Reply With Quote
Old 10-29-2013, 09:37 PM   #4
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
It works well but on a hot day its not an really an option you want to use and thats when you really need it.. Looks into getting heat extractor vents for your hood.
The faster way to cool down your engine in between your track session is to let it run with the AC full on and the hood open. It takes less then 10 minutes to get back to 190f.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 10-29-2013, 10:47 PM   #5
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
Never thought of the AC. Does it work because it kicks on the fans on high? Running the heat in AZ is not pleasant since its normally on the warm side but i guess it would matter much with the windows down at speed.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 10-29-2013, 11:38 PM   #6
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
It should help keep the coolant temperature down a little. The heater core is basically a small radiator and air flows through it when the HVAC fan is on.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 10-30-2013, 02:27 AM   #7
Rornls3
Thanks for the input guys! Looks like I will have my heater blowing during my track sessions.
Old 10-30-2013, 02:45 AM   #8
Merc
In The Circle
Merc's Avatar
You can also jump the cooling fan relay and have them both run continually, along with removing the engine cover. That's what I do on track days.
Old 11-05-2013, 08:01 PM   #9
Rornls3
Yes, I do remove the engine cover. Never heard of having the option of having the fans run all the time though.
Good to know!
Merc, what do you set your passenger compartment heater and fan speed setting to?
Old 11-05-2013, 10:44 PM   #10
SSteven
SSteven's Avatar
Drives: 2013 ZL1 Black
That should pull some heat up the engine. I've done it with cars in the past that were overheating. Once in a hundred plus degree weather sitting in traffic which sucked
2013 ZL1 (purchased 3/2017 with 5k miles) - Black/Auto/Nav/Sunroof/Rotofab CAI/RDP tuned/1 7/8" LT Speed Engineering Headers w/TSP HF Cats/NPP with 3-way control switch/HD-Link
Previous Camaro (sold 11/2015): 2012 2SS - Auto/RS/Black/Sunroof/MyLink Nav/SP 1 7/8" LT Headers w/HF Cats/Hybrid SW Retro Catback w/Borla Pro XS Mufflers/ADM Dyno Tune/C.A.I. CAI/Vmax Spiral Ported Throttle Body/APEX Catch Can/275x4 Squared Wheel Setup/Custom Fit Full Size Spare/Ceramic Tint
Replaced with 2013 Black Dodge Charger SRT8
SSteven is offline   Reply With Quote
Old 11-05-2013, 10:57 PM   #11
Merc
In The Circle
Merc's Avatar
Good to know!
Don't turn them on, just run the 2 engine cooling fans during the run and cool down sessions down the pits.
Old 11-06-2013, 12:08 AM   #12
Rornls3
Originally Posted by Merc View Post
Don't turn them on, just run the 2 engine cooling fans during the run and cool sessions down in the pits.
So you don't run your interior heater on the track at all?
I love the tips and tricks but my chief question still is if I should be running the heater during hot laps....
Old 11-06-2013, 11:31 AM   #13
Merc
In The Circle
Merc's Avatar
No I don't actually by jumping the fan relay as shown it disables the heater and AC fan too. On occasion when I do that it sometimes throws a code that I have to clear after running for the day.
Old 11-06-2013, 12:59 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Road race ignoramus here, would it be better to cool the coolant more, or the oil?
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
