ADM PERFORMANCE
Old 10-26-2013, 03:11 PM   #1
Orange Crush 1LE
Orange Crush 1LE's Avatar
Drives: 2013 SS 1LE
Pedders Supercar Coilovers - street settings?
My Supercars are dialed in perfectly for the track, but I'm going to take a break from tracking for the winter and want to dial down the damping. Interested in the best ride, not best performance for the street. I'll dial them stiff again for the track before my next event.
Anyone have any suggestions for optimal damping for the street? My car's only lowered 1/2" front and 1" rear, so not much risk of bottoming out.
Thanks
Sold but not forgotten! Pedders Supercar Coilovers, 32mm rear sway bar,bushings; APR wing and splitter
Forged 416 road course stroker. 514 RWHP, 497 RW Ft-Lb
1 Camaro, 75 Vipers: http://www.camaro5.com/forums/showthread.php?t=393697
Buttonwillow Raceway: http://www.camaro5.com/forums/showthread.php?t=389086
Orange Crush 1LE is offline   Reply With Quote
Old 10-27-2013, 12:06 AM   #2
SPCBA
Drives: pleather and Chiclets
Ask Mr Pete.
I have a question why the ride height is set to take away the natural rake of the car?
SPCBA is offline   Reply With Quote
Old 10-27-2013, 12:38 PM   #3
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
You have to play with them to see what you like for road feel, but on the street I have them softer, top adjustment 16 from full soft, canister 12 from full soft, front/rear same settings....still has some road feel, but ride quality is good...
So Cal Camaro is offline   Reply With Quote
Old 10-27-2013, 12:54 PM   #4
Orange Crush 1LE
Drives: 2013 SS 1LE
Originally Posted by SPCBA View Post
Ask Mr Pete.
Good question for Jedi Master Pete. During install, we initially lowered it 1" R and 7/8" F, but per Pete's advice for optimum handling we lowered it by 1" R and 1/2" F (with stock tires/wheels). Good thing, because with my 315/30-18 track tires, the total drop is 2.2" R and 1.7" front. That is slammed, wouldn't want it any lower.
Old 10-27-2013, 12:55 PM   #5
Orange Crush 1LE
Drives: 2013 SS 1LE
Thanks! I'll try that for initial settings.
Old 10-27-2013, 01:04 PM   #6
Dyk-NO
Trust me I'm a Scientist.
Drives: My wifey ;P
If you're running the 305/30/19 wheel/tire setup that Pedders has, they dropped the front 15mm and 25mm rears. I think
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator.
Dyk-NO is offline   Reply With Quote
Old 10-27-2013, 01:21 PM   #7
SPCBA
My i ask what your ride is height is with track wheels? Curious because i kind of did the same thing. Lowered car then put on shorter track tires and car was to low, had axle issues
Old 10-28-2013, 05:39 PM   #8
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Lowering the car with shorter tires does not effect the suspension. It's when you drop below an inch via springs or coilovers that you start having axle problems.
Best regards,
Tyler
888-308-6007
Old 10-28-2013, 06:06 PM   #9
Orange Crush 1LE
Drives: 2013 SS 1LE
Blake, I haven't had a chance to take a measurement, but what Tyler said is the case. I didn't adjust the coilovers at all when I installed my 18" wheels. The suspension drop is still 1/2" F and 1" R. Then the smaller track tires drop the car another 1.2", so total drop is about 1.7" F and 2.2" R. Hope that helps. I can still take the measurement if you like.
What axle problems are you having? I have an issue too, but it was there before I dropped the car. At 90+ MPH, there's a pretty good vibration coming from somewhere, it sounds like drivetrain in the rear. Not sure what it is. It's as if something is out of balance in the differential or the half shaft assemblies. It has me concerned. So far no problems other than the noise. If anyone has any thoughts, please let me know.
Yep, that's pretty much the same as 1/2" F and 1" R. For optimum handling, that's the drop.
Old 10-28-2013, 06:07 PM   #10
the rich dude
Drives: Getting 2010 Camaro
What happens with the axles? Is there a fix? I plan on dropping my car at least 2" and plan on making 650-700rwhp
Thanks!!!
the rich dude is offline   Reply With Quote
Old 10-29-2013, 03:02 AM   #11
Orange Crush 1LE
Drives: 2013 SS 1LE
Blake, more info on ride height. With the 315/30-18s, see attached pics.
1st pic: Front fender 27" above floor
2nd pic: Rear fender 27" above floor
3rd pic: Rocker near front 3-3/8" above floor (painted portion of rocker)
4th pic: Rocker near rear, below door seam 3-7/8" above floor (painted portion)
You can see from the rocker measurements, there's a subtle rake with the front a little lower, but the car is nearly level front to rear.
Old 10-30-2013, 07:07 PM   #12
the rich dude
Thanks!!!
no one??
Old 10-30-2013, 08:00 PM   #13
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
no one??
More the 1" the axels are not at the right angle. One member out here had it lowered more and broke both on a roval track
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Pedders Supercar coilovers and Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 10-30-2013, 11:14 PM   #14
the rich dude
is there a fix for this?? I see tons of people with cars lowered more than 1". WHy are they not complaining of broken axles?
