sjm autoprod
Old 10-27-2013, 10:13 PM   #1
13lstuner
13lstuner's Avatar
Drives: 2013 2LS BLK
2013 2ls gears
From the research I have done I know this. I have 2.92 gears and to my knowledge the only gears I can put in my rear or better stated the
"Best" are the 3.55 gears. What amount of RWTQ could I expect to see from this change I'm gears. And also what amount of decrease in gas mileage? And excuse my ignorance but why does a higher gear ratio decrease gas milage? Will
It carry my shift points higher?
13lstuner is offline   Reply With Quote
Old 10-27-2013, 11:10 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
Well, uh... Mathematically 3.55s would give you a 21.6% boost in torque compared to 2.92s... (3.55/2.92)
Gas mileage I'm not sure. That's a bit of a guessing game.
All due respect, I'm going to make this as simple as possible. Basically, the gear ratio is how many times the drive shaft rotates compared to how many times the axles rotate. So with 2.92s the axles rotate 2.92 times before the driveshaft rotates once.
As for cruising RPM, take your current cruising RPM at any given speed and multiply it by the torque multiplication of the gears over stock (so 1.216, or 1 + [3.55/2.92]). So what a speed once was at 2000 rpm is now at 2431 rpm.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Caliper Conversion, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, VIS Terminator Hood
DSX_Camaro is online now   Reply With Quote
Old 10-27-2013, 11:12 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Forgive me but my post sounds so weird... need someone else to verify it. I'm very tired and don't want to be leading this fellow astray.
Old 10-27-2013, 11:19 PM   #4
LStick
LStick's Avatar
Drives: 2015 2LS Red Rock
[QUOTE=DSX_Camaro;7133295]Well, uh... Mathematically 3.55s would give you a 21.6% boost in torque compared to 2.92s... (3.55/2.92)
Would make sense that a lower gear ratio (higher number numerically)would give you more torque off the line, and in the same token, at a given speed, your engine would be turning more RPMs in order to sustain that speed.
And that being the case, it will use a little more gas.
The LS and LT cars that are carrying the 3.27 rear ratio are rated at 28 MPG Hwy.
The 2LS with the 2.92 is rated at 30 MPG hwy. (mine gets a little more)
So it would make sense a 2LS running an even lower setup would get less MPGs.
LStick is offline   Reply With Quote
Old 10-27-2013, 11:37 PM   #5
13lstuner
13lstuner's Avatar
Yeah I'm sure I will get less mpg. Thank you both for the information! And dang a 21% increase in torque would be... Amazing. Heck a 15% increase would be more than worth it to get the gears. My only question I have left is would this effect my powertrain warranty?
Old 10-27-2013, 11:59 PM   #6
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
I would venture to say that gas mileage in a high traffic, stop and go environment would be better, as the car does not have to work as hard to get moving from a stop... I imagine the only mpg loss would be on the hwy, however...
http://www.camaro5.com/forums/showpo...4&postcount=11
Read from post 11 onward regarding fitment of the 3.55 gears in a 2ls rear.
Jason@ is offline   Reply With Quote
Old 10-28-2013, 12:04 AM   #7
13lstuner
13lstuner's Avatar
I completely trust your information but how does that happen? Not being able to put the 3.55 in mine? And what gear ratio does the stock ss have?
Old 10-28-2013, 12:24 AM   #8
Jason@
Supposedly a different carrier (ie: 2 series carrier vs 3 series carrier)... Only one person has brought and tried the 3.55 gears in his 2ls and claimed they didn't fit the 2.92 carrier. Supposedly he contacted Richmond, the gear manufacturer and they werent even aware...
A manual SS has a 3.45 ratio, while the auto has the same ratio as the 1ls, and 1/2lt, a 3.27. Swapping to the SS 3.45 rear end would be like an 18% torque gain. Even swapping to someones take out 3.27 a6 v6 rear, a straight swap, would be appx a like 12% gain in tq.
Old 10-28-2013, 12:34 AM   #9
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Personally, and this is my opinion, is that the gear swap isn't worth it since you have to swap out the whole rear end pretty much and it's not going to cost you less than at least 1000 dollars. And if you're going to do it, I'd at least go with the 1LE gears which are the 3.91. They'd be a vast improvement but your MPG will take a hit.
Old 10-28-2013, 01:58 AM   #10
Mr Monte
Mr Monte's Avatar
Drives: 2014 Chevy SS
In my Wife's Mustang I replaced the 3.31 gears with 4.10 gears. City mpg got better by 5mpg & hwy only dropped 2mpg. Fun factor when up 100%.
Now I'm looking to install 3.91 gears in her Camaro. Unless you are mostly a hwy cruiser more gear is the biggest bang for the buck.
Even going from 3.73 gears to 4.10 gears in my Suburban made a big improvement in performance & I didn't loose any mpg city or hwy because it stayed in OD longer.
It's nice to have options.
Mr Monte is offline   Reply With Quote
Old 10-28-2013, 04:54 AM   #11
13lstuner
13lstuner's Avatar
What process would I have to go through to get the 3.91 gears?
Old 10-28-2013, 06:54 AM   #12
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
In an LS, you will need to swap the diff to one from an SS or LT(M6) to be able to fit 3.91s (or just find a 1LE diff). You may also need to swap axles, hubs and the rear half of the driveshaft to get it to fit (they are required in an A6/V6).
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 10-28-2013, 07:26 AM   #13
13lstuner
13lstuner's Avatar
Would I have to have axles,hubs and driveshaft for the 3.45 ss manual swap?
Old 10-28-2013, 08:44 AM   #14
Jason@
Yes
2.92, 3.55, gears, lfx, rwtq
