#15 |
![]() ![]() ![]() ![]() Drives: 2013 2LS BLK Join Date: Oct 2013
Where is the best place to find a complete rear axle? And what warranties will this most likely void?
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 LS M6, Black Join Date: May 2009
John B.
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
#17 |
![]() ![]() ![]() ![]() Drives: 2013 Summit White 2LT/RS Join Date: Feb 2013
Reading my post now I can safely say I am retarded. Thank you for clarifying, too.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, VIS Terminator Hood, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I
#18 |
You just got slightly mixed up. Thank you for your input!
#19 |
![]() ![]() ![]() ![]() Drives: 2016 1SS SW Join Date: Jun 2013
Greetings all! I've ordered all the parts (3.91 ring/pinion, SS carrier, axles, hubs) to do this swap. I'm sitting at about 3k for parts and install. I tried to go the Richmond route and ran into the same issue, it doesn't fit a 2ls 7.6irs carrier. I'm having the work done at Lucky's Speed and Performance in Longview, TX sometime next week. I've talked with C5 member BlackoutLFX who has swapped to a SS carrier with 3.45 gears (and don't forget the LSD) to make sure the drive shaft fits. He claimed it all mated right up without a hitch. I'll be posting a thread on this with under carriage pictures when the work is done. My expectation is that my little six banger is about to feel like a monster!
#20 |
The SS driveshaft is too short for our cars. I think maybe the SS Trans(tr6060 & 6L80) are bigger than ours, so the drive shaft is shorter as it has less distance to cross. Not sure though could be talking out my ass, but I do know that our drive shafts are not interchangeable.
#21 |
REDZONE
Drives: 2017 1ss Auto,NPP,MRC Join Date: Mar 2013
Man I was sure the 3:55 would fit In my 2ls. Damn until I heard on this thread that someone tried it and failed. ..is there any 2ls owner that can dispute this and made the switch.
]2017 1ss (Auto), MRC, NPP, suede accents, dealer instAlled all weather floor mats,suede knee pads,8 inch mylink radio, blackout kit, gloss hood/spoiler wrap,2nd cat/muffler delete,
#22 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
I have a complete 2LT diff setup (3.27 gears) axles and hubs for sale. Was removed at 3,500 miles to install SS diff. Had first fluid changed at 500 miles along with all the fluids ( trans, diff, engine oil ) in the car to full synthetics and again at 3,000 miles.
#24 |
Sorry buddy, We have a 7.6" gear carrier. It is different from all the other v6's and v8's. I've cried and cried over this, but its just a fact. Luckily it isn't THAT costly to get the bigger V6 gear carrier ($800ish) and that comes with the limited slip differential too.
#25 |
I was wrong, its $221...
The 3.27 (LT) carrier GM p/n 92230616 list price $221.30 |
#26 |
#27 | |
REDZONE
#28 | |
REDZONE
Tags |
2.92, 3.55, gears, lfx, rwtq |
Thread Tools | |
