Cold Air Inductions
Old 07-15-2009, 02:19 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
6l80e stall tune
what is everyone doing to keep there new stall converter alive, seeing that non of the aftermrket converters are designed for pwm tcc or wot tcc apply
i have a large trans cooler and i have all wot tcc off, all tm off, and only have the tcc on at hwy speeds in 5th and 6th gears
Old 07-16-2009, 02:55 PM   #2
DanD
DanD's Avatar
Drives: 6 camaros
I will have to look at my efi live to see, but we added a binch of pressure I believe on the lock up in 5th and 6th just in case. Can't remember now..
what did you dyno at with the stall?? or didn't you yet?
I can check my files later for you.
Dan
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 07-17-2009, 04:22 PM   #3
camaro1
camaro1's Avatar
no numbers yet, it is getting a custom stainless X-pipe right now, if you can see what efi live has for tcc pressure tables and tcc lock up tables and switches and post them that would be great
Old 07-17-2009, 09:53 PM   #4
DanD
DanD's Avatar
Drives: 6 camaros
ok.. have to get it off my laptop ,will tomorrow hopefully.
2002 Z28 427
1968 383 Camaro
1967 RS 327
Old 07-17-2009, 11:37 PM   #5
craigd853
Drives: 199 SS Camaro
Dan
I just bought EFI Live. Could you please send me you calibrations curves so I have a basline. Thanks
craigd853 is offline   Reply With Quote
Old 07-19-2009, 03:11 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Now - I can see how locking-up the converter will make the tranny more efficient at WOT, but I remember reading articles where locking the converter pulled the engine back down out of the powerband. I never locked the converter at WOT and still found high trap speeds (which I always saw as better efficiency) at the end of the track. I do know that Yank didn't recommend locking this converter at the track unless I upgraded to multi-discs but I always managed to keep my shift extension right around peak power, at about 5300-5400 RPMs.
Are you guys with the 6L80s locking then, and have you made sure it's okay with your converter manufacturer? Just curious
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-19-2009, 04:00 PM   #7
camaro1
camaro1's Avatar
only locking mine at hwy speeds in 5th and 6th, no wot lock up,
the factory tune has the converter locked 2nd gear and up at wot, and had the trans in 5th gear by 30 mph and the lock up on
Old 07-25-2009, 07:28 AM   #8
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
IMHO, locking the factory coverter at WOT is asking for a very short lifespan for it. There aren't very many performance converters that are approved for WOT locking...vig's triple disc is one of the few that you can lock at WOT....you have to find the sweet spot for locking...to low rpm in a gear and you'll drop out of the power band and lose ET/mph, too high and you wont' take advantage of the mph gain...locking at WOT is really only gonna gain you MPH in the 1/4...also good for roll racing. I had heard prematurely that there were tuning issues with stall converters on the 6L80...I haven't researched the issue much, and since I don't have a stall yet, I have no personal experience. Just that when cruising people were having trouble keeping them locked (I believe), such that they would go in and out of lock.
How are your guys 6L80's with converters doing? How much mpg did you give up with them?
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 07-25-2009, 02:40 PM   #9
camaro1
camaro1's Avatar
so far 1500 miles on mine and it stays locked up at hwy speeds just fine, all wot tcc turned off
Old 07-25-2009, 09:30 PM   #10
DanD
DanD's Avatar
Drives: 6 camaros
mine seems ok as well.. I only have 1 slight issue, and not sure if its just the lock up, or maybe the air/fuel (idle air) that it seems to surge a little bit when locked. I will have to mess with it to see.
2002 Z28 427
1968 383 Camaro
1967 RS 327
Old 08-25-2009, 04:39 PM   #11
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Probably the AFM kicking on and off.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 09-06-2009, 12:38 AM   #12
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
Something you can not see in the software is the PWM(Pulse Width Modulated) function of the lock up clutch, it will lock up in a percentage based on throttle percentage ETC., at 0 percent throttle the converter will reduce the percentage of lock up, and as you slightly accelerate(up to maybe 25%) the lock up disc will engage at a greater percentage to try to maintain the same feelingsmoother feeling in the disc locking up, in how much lock up percentage is occuring, the problem is when you change the stall speed this no longer matches the shaft speeds so it will tend to bounce the rpms around more, and we can not access this with tuning software currently.
mike@newera is offline   Reply With Quote
Old 09-08-2009, 01:04 AM   #13
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2015 ZL1 for weekends mostly
I have seen folks at hptuners talking about the pulse width modulation in their G8s and making successful changes. Is this just a software file recognition issue or is the PWM a hidden file in the ECM? I hope this gets figured out due to the significance of the need to adjust for the use of a stall with big cams and such.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 09-25-2011, 10:08 AM   #14
tsears
tsears's Avatar
Drives: 2010 Camaro 2SS/RS - L99 - CGM
Sorry to bring up an old thread, but did anyone get any resolve on this? I've got a built 6l80e with a 3k stall. Shifts a bit funny and when I'm off gas the RPMS dip down to about 1k. It just seems its having a hard time finding a gear at normal drive. And a bit sluggish at WOT.
2007 Corvette Z06 - Velocity Yellow
Halltech | Forgestar | Bilstein
tsears is offline   Reply With Quote
American Racing Headers for 2010 Camaro yields +32rwhp w/o tune, +50rwhp with tune ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 226 08-09-2013 06:01 PM
Where in Arizona can I get a tune?? saguarorvs Tuning / Diagnostics -- engine and transmission 10 06-03-2012 10:49 AM
GMPP LNF Tune The_Blur General Automotive + Other Cars Discussion 22 01-07-2009 05:57 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
minimum hp gains from gmpp headers/A.I./catback? s.norman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 75 11-16-2008 03:23 PM
