Old 10-30-2013, 05:52 PM   #1
BronxRS
BronxRS's Avatar
Drives: '13 2LT RS Convertible - AGM
'13 2LT Convertible Suspension Advice needed
I originally posted this on the convertible forum as its specific to verts. Lots of looks but no feedback, so I'm posting it here...
'13 2LT RS vert - I want to upgrade subframe bushings, trailing bars and toe links. I'm also looking to upgrade the rear sway bar but can't settle on a particular brand/model. I am leaning to BMRs or PFADT for the trailing bar and toe links and Pedders for the subframe bushings. My concern is ordering a part to learn it just doesn't fit. My vehicle is mostly a daily driver but I am getting too much hop on hard starts and roll on lane changes. I'm on stock struts with Eibach ProKit springs.
Can anyone with specific knowledge about '13 convertibles provide some advice on brands/model numbers? I don't know if the additional weight of the verts makes any difference on suspension components. The added OEM suspension components on the vert (under bracing etc) also leave me questioning what will and will not "fit" on my car.
I'm amazed at the number of ads for products for '10-'13 (and now '10-'14) models without regard to minor dimension changes or movement in hole placement. I don't want to be cutting/carving/drilling to install what should be a straight OEM replacement part.
Thanks.
BronxRS is offline   Reply With Quote
Old 10-30-2013, 10:54 PM   #2
Fast6.3
Fast6.3's Avatar
Drives: 2011 2ssrs vert 2010 silverado 6.3
I got a 2011 ss vert that I upgraded the rear suspension to FE4 which has the swaybars outboard of the shocks because I installed the Pfadt ZL1 swaybars. I think yours is also an FE4 you can call JDP Jordan knows his stuff and will advice you good. I got pedders cradle bushing inserts and pfadt trailing arms and toe rods also got pfadt rear upper control arm bushings really happy with my setup Jordan really hooked me up information and price wise highly recommend. My car handles superbly and just hooks at the track. I didnt do springs because I dont want to be hitting parking curbs and messing my splitter. Im also running 275 in front and 315 in rear and the gap is pretty good
[SIGPIC][tsp 2" headers no cats solo axel back magnaflow x New Era OTR Intake pfadtted suspension
H&R springs koni
Fast6.3 is offline   Reply With Quote
Old 10-31-2013, 02:30 PM   #3
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
What is your GMMB?
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 10-31-2013, 02:51 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I just responded to your other thread. Check it out and feel free to call, PM or email me with questions.
Best regards,
Tyler
888-308-6007
Old 11-01-2013, 01:22 AM   #5
BronxRS
BronxRS's Avatar
Originally Posted by TBone View Post
What is your GMMB?
T.
Goals - having a daily driver that will absorb brutal pot holes and speed bumps without jarring me out of my seat, but being able to drive it hard when I want to. For this vehicle, I expect to take highway corners and make uneventful lane changes at speeds of around 65-70 mph without body sway/roll. I also don't want the car hopping at that speed over a slight bump.
Model - 2013 2LT RS convertible (6AT)
Modifications - current suspension mods are Eibach ProKit springs only. Performance mods include CAI intake, VMax ported TB, Solo catback exhaust,
Budget - increments of around $250 at a time (one mod per month)
Old 11-01-2013, 11:51 AM   #6
JDP Sales
JDP Sales's Avatar
You are probably going to have to save up for a couple months and get some funds together for some items. I'd suggest starting off with the Pfadt ZL spec sway bars with new front and rear endlinks (Part # 1410138). This will be your best bang for your buck for handling. From there, I'd go with the Pfadt rear trailing arm package (Part # 1410134), then some Prothane Subframe mounts and Pfadt upper control arm bushings Pre-pressed in a new GM bracket (Part # JDPS1001)
Feel free to call, PM or email me with questions or for the BEST pricing.
Best regards,
Tyler
888-308-6007
