R1 Concepts
Old 11-05-2013, 08:57 PM   #15
MikeOD
Drives: 2010 M6 2SS
Originally Posted by Slowhawk View Post
It will be a fun build and we have plenty of time so we do not have to rush and over spend to get done ASAP.
The reason for the 416 is because we wanted a better crank that will take the load of the ysi pulling on it, so why not go with a 4" stroke. The bigger cubes will make more low end power/ torque which helps keep a more street friendly converter.
My goal is 800- 850 rwhp at 6200 rpm for now. That should be very safe on the motor and put this car safely in the 9's on a bad pass. ( my dyno reads low)
Right now we are waiting on the pistons to be made. Should be about 2 weeks to get in.
You know full well you're going to make 800-850 on that setup by accident with a stupid safe tune...
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 11-05-2013, 09:02 PM   #16
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Post of the decade....
VanquisherSS is offline   Reply With Quote
Old 11-05-2013, 09:13 PM   #17
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
That'll be made without meth. Are you going to use a cog setup, or will you be using a 10-rib pulley?
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 11-05-2013, 09:21 PM   #18
Muddflap
Muddflap's Avatar
Drives: 2010 Camaro SS
Congrats bro.... I will be following this build!!
TSP 1 7/8 LT, ADM Race Cold Air w/ Race Scoop, GPI SS3 LS3 Cam, Powerbond UD, 3.91 Gears, GPI Posi Mod.
498RWHP/451RWTQ
Muddflap is offline   Reply With Quote
Old 11-05-2013, 09:38 PM   #19
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Now this is a build to look forward to. Finally getting rid of the heat pump for a more efficient blower and complete setup.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 11-05-2013, 09:38 PM   #20
CyberPredator
50 Shades of Prey
Drives: TT/SS
Good move. Now we will get to see what your car does with power.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 11-05-2013, 10:07 PM   #21
RBL
Drives: 2010 camaro 2SS
I am very interested in this build and to see your opinions on the YSI vs the roots one you drive the car.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete.
RBL is offline   Reply With Quote
Old 11-05-2013, 10:11 PM   #22
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Very nice, subscribing. I had one of the first custom YSI setups for a 4th gen way back in 2004.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 11-05-2013, 10:31 PM   #23
02bluess
Camaro Addict
02bluess's Avatar
Drives: 2014 Camaro ZL1 SIM A6
Glad to hear you're moving forward, good luck Jamie!!
Paul...
2014 Camaro ZL1 SIM A6: Rotofab, VMax TB, 22% Lower Pulley, Stainless Power 1 7/8, Cat Delete, ID850s, DSteck Flex Fuel Kit, DSteck Supplemental Fuel Pump, DSteck E85 Tune
Best Timeslip: TBD
02bluess is offline   Reply With Quote
Old 11-05-2013, 10:36 PM   #24
grocerygetter
instigator
grocerygetter's Avatar
Rawk on!
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 11-06-2013, 12:37 AM   #25
Fast6.3
Fast6.3's Avatar
Drives: 2011 2ssrs vert 2010 silverado 6.3
that build is going to rock congrats cant wait for the results
damm I wish I had that kind of money for a build of this type
[SIGPIC][tsp 2" headers no cats solo axel back magnaflow x New Era OTR Intake pfadtted suspension
H&R springs koni
Fast6.3 is offline   Reply With Quote
Old 11-06-2013, 04:56 AM   #26
Supercharged SS
Drives: 2010 Camaro
Yeah, me too. Right now I'm Dons Bitch for the next 15 years.
My disposable engine deal is over. This one will last.
Old 11-06-2013, 04:57 AM   #27
Supercharged SS
Drives: 2010 Camaro
Matt said 10 rib. It's up to those guys.
Old 11-06-2013, 05:05 AM   #28
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
And this is the problem with you. Always someone's bitch.
nyny69 is offline   Reply With Quote
