HeadlightArmor
Old 11-06-2013, 11:24 AM   #1
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
2013 SEMA Show - AP Racing/Stillen
Here's a few pictures of our new line of Big Brake Kits!
The STILLEN Team is no exception, with a big booth introducing the world to the new AP Racing Radi-CAL line of calipers used in the STILLEN-engineered Big Brake Kits. These new Radi-CAL road calipers get there heritage from the racing Radi-CAL high performance calipers launched in motorsports in 2007, which have been dominating the likes of F1, F3, NASCAR and countless others. This new caliper design features a 2-piece aluminum body with H-structure, and a non-symmetrical design developed to have a large reduction in mass yet improved resistance to braking torque. Another benefit is increased caliper cooling surface without decreasing structural rigidity.
More info to follow...
Team STILLEN is offline   Reply With Quote
Old 11-06-2013, 11:31 AM   #2
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
JT, get going on some C7 products! LoL! I finally made the move... As always, you have some great products.
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 11-06-2013, 11:48 AM   #3
Team STILLEN
Drives: Varies
Congrats on the new C7 bud!!
I will keep you posted.
JT
Old 11-07-2013, 03:19 PM   #4
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Great looking display guys!
Sales @ CAI Inc is offline   Reply With Quote
Old 11-07-2013, 03:45 PM   #5
those look real nice
Old 11-15-2013, 01:39 PM   #6
Team STILLEN
Drives: Varies
Here is some more information on the new AP Radi-CAL Kits...
- Each kit is designed specifically to the vehicle application with special attention to proper piston and rotor sizing to match OE ABS, stability control systems and brake balance.
- Hats and brackets are designed and engineered in Stillen's R&D Department and machined in house with the latest CNC lathe and mill machining.
- Each Kit design is based on vehicle weight, heat index required at maximum speed and GVW to provide repeated high speed stops while managing the heat in the most efficient way using components designed and validated for a high performance environment and every day road use.
- Each kit is complete with calipers, pads, rotor assemblies, hardware, brake lines and instructions.
- Track braking performance that is safe and compliant for road registered vehicles.
Radi-CAL Calipers
- Derived from AP Racing's patented and widely successful race Radi-CAL Calipers
- The unique asymmetrical designed and forged aluminum caliper bodies are tested at over 500,000 cycles of pressure and torque to meet AP Racing's stringent high performance and OE road use validation requirements to provide maximum stiffness and reducing weight.
- Opposed piston design provide better pedal feel and immediate brake response.
- The 6 and 4 piston caliper design allows larger pad surface area to be used which decreases heat at the friction point between the pad material and rotor surface.
- Differential piston sizing to minimize pad taper.
- Forged removable bridge support for east pad change and additional strength to the caliper mouth.
- Designed for larger and wide rotors with taller annulus to increase thermal capacity and reduce rotor surface temperatures for increased pad and rotor life.
