Cold Air Inductions
Old 11-07-2013, 08:32 PM   #1
KPowers
Drives: none
problems at the track
Ok let's see if anyone can solve this for me. I have a '13 SS stock other than a set of stainless headers. While at the track I noticed a problem hitting second gear. No matter what mode the traction and stability was placed into as soon as I hit second the car would spin the tires just a little then fall flat on it's face for a second. Much like if the traction control was active. It never did it in first or during the quick little burn out I did to simply clean the tires. All three phases resulted in the same behavior. Could it have been the torque management or abuse mode kicking in?
KPowers is offline   Reply With Quote
Old 11-07-2013, 08:43 PM   #2
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
My thoughts were torque management kicking in.
Camarojt is offline   Reply With Quote
Old 11-07-2013, 08:59 PM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
Yep
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-08-2013, 05:31 PM   #4
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
TQ management sounds like a good winner...
Just to clarify though - to turn traction control all the way off you held the button down for 7-10 seconds right? so both little yellow lights were on the dashboard?
xjer22x is offline   Reply With Quote
Old 11-08-2013, 09:48 PM   #5
KPowers
Drives: none
Yep. Made 2 passes in Competition mode then the last pass was with everything off. Same results. Didn't try with it on cause I knew for sure it would do it then.
