JDP Motorsports
Old 11-09-2013, 12:59 AM   #1
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
TH400 swap/cam only... track results!
11.75@117.1
I just got my baby all fixed up finally!!! After 2 weeks of issues I have it all sorted out, stupid poly trans mount... dont use them!
I beat the piss out of it for an Hr to make sure its all good, went over everything and the DRs are mounted. Me and Little88 are hitting Byron tomorrow morn, high 57 and sunny so weather should be good.
The car feels AMAZING with the th400, the 3600 stall drives very nice on the street! Way better then I thought it would, props to FTI! I totally expect to have a new PB tomorrow!
I think I am the first to do a th400 swap on a cam only car, so we will see what the results are! I made 440 with the M6, ran 12.4-12.3s 115-116 before the swap.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 11-09-2013, 01:01 AM   #2
Chevrolade
Drives: 2010 2SS/RS
Should run an 11 easy man keep me updated
How hard was the swap and what does and doesn't work ? Like speedo ?
Chevrolade is offline   Reply With Quote
Old 11-09-2013, 08:42 AM   #3
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
I agree with ^^. Should go 11's easy!
Camarojt is offline   Reply With Quote
Old 11-09-2013, 08:51 AM   #4
cybergrayls3
Drives: 2010 camaro 2ss/rs..m6..CGM
i want a th400! damn if you dont mind me asking how much did the swap end up costing?? Does the torque converter still lock at highway speeds? Im very interested in your results as im cam only and have been going back and forth with swapping an auto
-Lethal Racing NF cam
-Kooks LT's/high flow cats
-Borla ATAK catback
-CAI cold air intake (black)/Apex scoop
-LSR shifter
-Rick Crawford intake manifold
-Monster level 3 clutch
cybergrayls3 is offline   Reply With Quote
Old 11-09-2013, 09:27 AM   #5
Bad70supreme
Heading out soon! No the converter does not lock on the highway. I can cruise about 65 and 2600rpms with the 3.45 gear. My speedo works, trans temp is not hooked up, I have a check engine light on right now. My traction control is still active too! I did all the labor and already had the trans, end up around 1600$ total.
Old 11-09-2013, 10:38 AM   #6
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
Good luck! Can't wait to see how it goes.
You wouldn't happen to have the Part number for the TCI flexplate your running would you? I accidently bought the wrong one (non-sfi rated) when I was at Summit and I can't for the life of me find the part number I need.
Tuned by Back Street Performance 471hp/429tq
11.86 @ 117.47, 1.749 60'
Neumatic is offline   Reply With Quote
Old 11-09-2013, 10:46 AM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Good luck Mike!
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 11-09-2013, 01:48 PM   #8
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Good luck mike!!!! curious to see how it goes.
I have a Th400 sitting on the ground right next to my camaro in the garage... The temptation is there to say the least. lol
xjer22x is offline   Reply With Quote
Old 11-09-2013, 02:44 PM   #9
Bad70supreme
11.77@116.4!!!!
Stupid trans is short shifting itself into second early because I don't have the 12 volts running to the trans I guess. But man she's running awesome, I am able to hold 2nd as long as I want, shifting it at 6800. Need to get 1-2 worked out, might have 11.6!
Old 11-09-2013, 02:49 PM   #10
Supercharged SS
Drives: 2010 Camaro
11.77@116.4!!!!
Damn, that's crazy. Guess you made the right decision!
Old 11-09-2013, 03:23 PM   #11
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Awesome job !!!!
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 11-09-2013, 03:28 PM   #12
Bad70supreme
Just trapped 117.7 on a 11.80 pass! 60ft was slower, I shifted 3rd at 7k! Once I fix 1-2 it's gonna pick up for sure!
Old 11-09-2013, 03:56 PM   #13
Bad70supreme
11.75 @ 117.7
7.5 in the 1/8th at 93.5. 60ft 1.75
Old 11-09-2013, 04:19 PM   #14
Pro Stock John
Writer
Nice!!
PROJECT HEAVY CHEVY
