Cold Air Inductions
Old 07-16-2009, 03:05 PM   #1
johnny74
Drives: 1974 Type LT, for now
LT fuel requirement
I am going to be ordering in the next few days and I forgot to check when I was looking, but what is the minimum octane requirement for the V6?
Thanks!
Johnny
johnny74 is offline   Reply With Quote
Old 07-16-2009, 03:08 PM   #2
CAMARO_MOW
CAMARO_MOW's Avatar
Drives: 2011 White 2SS/RS
Regular. I think 87 or whatever the number is.
2SS/RS Summit White with IOM Stripes and IOM Interior, Hurst Shifter....
CAMARO_MOW is offline   Reply With Quote
Old 07-16-2009, 03:08 PM   #3
Mojave
2016 Camaro SS
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
I believe it is 87
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Some AutoX Mods Planned
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
Mojave is offline   Reply With Quote
Old 07-16-2009, 03:08 PM   #4
djm96z28
djm96z28's Avatar
Drives: 2012 Camaro 1SS LS3
The V6 should run on 87 octane.
djm96z28 is offline   Reply With Quote
Old 07-16-2009, 03:11 PM   #5
buddylok
buddylok's Avatar
Drives: Chevy
Minimum is 87, runs fine with a little bit of "knocking / ping".
I use 90 octane fuel in my 1LT, I can feel the power now !
buddylok is offline   Reply With Quote
Old 07-16-2009, 03:14 PM   #6
camaro guy
camaro guy's Avatar
Drives: 2010 camaro LS
i was told that using a higher octane than recommended will dirty your engine. any insight?
camaro guy is offline   Reply With Quote
Old 07-16-2009, 03:24 PM   #7
djm96z28
djm96z28's Avatar
It shouldn't knock or ping on 87. When I had my '93 Camaro V6, it was programmed to run on 87 and I got a ping on hard acceleration. Took it to the dealer and they reprogrammed the PCM (I think) and problem solved.
Old 07-16-2009, 03:30 PM   #8
johnny74
Thanks all!
Old 07-16-2009, 03:44 PM   #9
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
no. in some cases it can be a slight waste of money if the computer isnt programed to make use of the higher octane fuel. but the v6 req 87. if you want to run premium, it wont dirty or harm the motor at all
I piss excellence
and fart awesomeness
Old 07-16-2009, 03:54 PM   #10
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
unfortunately the dashhawk isn't able to log thing like the knock sensors or if the computer is pulling timing... BTW, the motor will actually hear the ping before you do... I may have to try playing with it again and go through the item more carefully to see if I can find something useful to monitor...
scrming is offline   Reply With Quote
Old 07-16-2009, 06:34 PM   #11
johnny74
Thanks again everyone, I just wanted to know what is required so I can estimate my fuel costs. I'm sure I'll put premium in once in a while, just not every time.
I asked the question because it's 11:1, and compression is usually the main factor, but from the little I've learned, it seems the DI helps it to better avoid detonation. I'm guessing this is because it can inject the fuel later during the compression stroke.
Old 07-16-2009, 06:50 PM   #12
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
87 or 89 will be fine. anything more will be a waste of money in a 6cyl Camaro due to its timing setup.
patriotpa is offline   Reply With Quote
Old 07-16-2009, 08:39 PM   #13
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
I'm at 1,600 mies total and 1,300 miles on 89 - it took 2 tanks to feel the difference from whatever 87 the Dealer put in on delivery. Now it sounds so much better on start-up and idle, and seems like it enjoys the slightly higher octane level on passing or merging.
So for me I'm sticking with 89, preferably from Sunoco.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 07-16-2009, 09:26 PM   #14
scrming
scrming's Avatar
not necessarily... still a lot of unknowns with the Bosch computer... Some cars like the Mustangs will automatically try to add a bit a timing... The Camaro in theory might be doing the same thing... just don't know... yet... LOL
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 01:27 PM
