ADM PERFORMANCE
Old 11-09-2013, 04:29 PM   #1
1969DNA
1969DNA's Avatar
Drives: '12 ZL1 VICTORY RED
ZL1 tire pressure sensors @ the track
thinking about a track day or two next summer. have extra wheels/tires. when I switch wheels at the track do I have to "reset" tire pressure sensors some how or does the car do it automatically? or will I get an error? also where is the best place to buy the sensors? GM or aftermarket?
1969DNA is offline   Reply With Quote
Old 11-09-2013, 05:26 PM   #2
HDRDTD
If you switch wheels, yes you will need to reset the sensors if you want to be able to monitor your tire pressures.
If you don't you will end up getting a 'service tpms' on the DIC.
If you are switching the wheels just to race and you'll be putting the originals back on after racing. do nothing. You'll just see the message during racing.
On the ZL1's you need a special 'tool' to reset the sensors. Either the dealer can do it for you usually for free and takes only 2min, or there you can buy the tool yourself. It sells for around $50-60 I believe.
All the 'tool' is, is an electronic transmitter that you hold next to each wheel while going through the reset procedure on your radio.
Old 11-09-2013, 06:21 PM   #3
1969DNA
1969DNA's Avatar
anybody got a link for the "tool?"
Old 11-09-2013, 09:37 PM   #4
DrkPhx
DrkPhx's Avatar
This is the one I use.
http://www.ebay.com/itm/New-Tire-Pre...bce57b&vxp=mtr
Old 11-09-2013, 11:07 PM   #5
HDRDTD
I bought mine right from my Chevy dealer. It's the same one they use.
Sorry, I don't have a link or a model number, it's out in the garage and I'm too darn lazy to go out and get it yet tonight.
Old 11-10-2013, 08:18 AM   #6
1969DNA
1969DNA's Avatar
Thanks to all for the help. this place is the best!
Old 11-11-2013, 11:15 AM   #7
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I do not use the sensor in my track tires. It adds some weight in the sensor and then to balance the tire. With no sensors the tire pressure warning comes on and once you get it out of the main display screen you can ignore it. The worse for me is if the street tires are in the pit area it starts to read their pressure every time I come off the track and then every time I go back on the track it gives me a new tire pressure warning.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 11-11-2013, 05:16 PM   #8
Sugar's ZL1
Ron and Sugar
Sugar's ZL1's Avatar
Drives: 2013 Black ZL1 Vert A6
https://gmspecialservicetools.servic...0448_rev_1.pdf
I Love My 08 Pek a Poo
Sugar's ZL1 is offline   Reply With Quote
Old 11-11-2013, 05:22 PM   #9
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Originally Posted by Sugar's ZL1 View Post
That's it!
Rock-It Man is offline   Reply With Quote
Old 11-11-2013, 05:26 PM   #10
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Well! That's a little more fancy than letting the air out till it beeps!
Old 11-11-2013, 08:07 PM   #11
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Originally Posted by DrkPhx View Post
That's the tool I used but got it on Amazon. In case the ebay link goes away since it does. It's a Kent-Moore EL-50448.
That trick doesn't work anymore. GM removed that capability due to interference from other TPMS sensors. Believe it's the 12 and up models on all GM lines.
Life is too short to drive cars that suck.
My build Thread
In or around Savannah GA on the first Sunday of the month? Come meet with us here around 11 am!
mmarx82 is offline   Reply With Quote
Old 11-11-2013, 08:10 PM   #12
Mr. Wyndham
Nice! Learn something new every day.
Never needed to (or could, for that matter) rotate the tires on the ZL1, so I never had to do this...
Old 11-13-2013, 11:33 AM   #13
jessrayo
Speed Freak
jessrayo's Avatar
I'm still scratching my head about this. I check tire pressure when I mount track tires. I check tires between sessions. While driving on the track as fast as I can make the car go I really don't think, "Hmm, I wonder what my tire pressure is reading right now" Seems like a waste of money and more dead weight, maybe only a couple of pounds but you don't need any more rotating wheel mass at the track.... just my 2 cents.
Old 11-13-2013, 12:06 PM   #14
Mr. Wyndham
True, probably. It's handy during a track day...to have real-time feed on tire pressure, as it relates directly to tire temperature...
It's one of the ways how, besides feel, I know when the ZL1/1LE will be able to hold still around a bend. The tires need heat...and the display presents that as pressure.
