sjm autoprod
Old 11-09-2013, 10:01 PM   #15
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Originally Posted by Stephen12ZL1 View Post
I'm a dentist too...everyone is scared to comment. I think I have mentioned that before.
Haa!
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 11-09-2013, 10:08 PM   #16
Mean Green Z28
Drives: 2010 2SS
So did you'll try tuning something more complicated and just settle on a Camaro tune?
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 11-09-2013, 10:17 PM   #17
ZO6 Bryan
ZO6 Bryan's Avatar
Old 11-09-2013, 10:36 PM   #18
Dega Man
Drives: ZL1
Good numbers. I noticed you used STD correction instead of SAE, did you do any pulls using SAE?
Dega Man is offline   Reply With Quote
Old 11-09-2013, 11:01 PM   #19
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Those are incredible numbers for minimal expense and self tuning.
Great job. I wish you were my dentist.
__________
9.85@140.88
Trackman is offline   Reply With Quote
Old 11-09-2013, 11:07 PM   #20
ZO6 Bryan
ZO6 Bryan's Avatar
I asked the shop owner the same thing. He said he always uses STD
Old 11-10-2013, 02:14 AM   #21
Dega Man
Drives: ZL1
Your numbers are still impressive for the dollars spent. Congratulations!
Old 11-10-2013, 07:15 AM   #22
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
I think the only reason he always uses STD is because it gives his customers a higher reading than using the more correct SAE which is the best to show how much your car is really making corrected to higher standard, otherwise if you show up in the summer in hot houston your car will read much less rwhp !Than newyork in nov...
So its always better to use SAE reading so the temp doesnt play tricks on your mind. your HP will always be the same all things being equal !
SAE has been the gold standard since the early 1990's,and uses a correction factor of standardized temperature to 77-degrees F, 29.23inHg and dry, 0-percent humid air.
SAE also uses a mechanical efficiency (friction) modifier in the correction factor which is what gives us the normal 15% power-train loss due to frictional loss, which is fairly accurate in a standard all-motor applications.
STD only uses 60-degrees with 0-percent humidity and an absolute pressure of 29.92inHg does take in to account for friction loss also !!!
STD shows what your car made ,corrected to a lower (older)stardard
MY 650rwhp is SAE, a lot of shops will give you both,but some will only give you STD to make some car owners that have no clue whats going on feel better about what was done to their car.
I personally feel that SAE numbers should always be used,but I think your RWHP is really about 25rwhp less based on the correction factor of about 4%
If you look at your graph and dont see something on it like smoothing 2" or a graph on the web be suspicious, you might be looking at an altered graph or, at least something run with a strange correction factor to make the numbers look higher than they really are.
I have seen shops where customers have asked for a certain part to be added to their car and the car makes 15rwhpSTD less and then they take it out on the shop owner,so click SAE and look your cars got 10hp just like the book you read said it would...just add up what each parts makes to tell you what hp you have.100 +10+20+80=210 not..
GREAT JOB on doing the tuning,its fun(till it goes wrong) & gives you the proud feeling of being able to say I DID IT ALL, I am guessing you installed all the parts also ? based on the total cost there was no labor....I used to do some tuning,and all my labor but times change now i just get to like i said GOOD JOB,but I hope you still foucs on the teeth before you make a pull I had to say it.... sounded funny at 5am...which is when I also wrote this so it should be correct,I think !!! goodnight ...
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 11-10-2013, 07:43 AM   #23
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
Dynoed my ZL1 today for the first time since I tuned it and did the Mods. Not bad for a small investment.
Mods
RotoFab $400
Kooks stepped headers $930
Kooks Cats $150
9.55 pulley, Innovators West damper, Belt, Idler pulley and crank bolt $500
ID850 injectors $735
Lingenfelter larger intercooler reservoir $75
Kenne Bell Boost-a-pump $350
HP Tuners license $99
Very nice!!
swizlstik is offline   Reply With Quote
Old 11-10-2013, 07:57 AM   #24
MichaelH
SOCAL HT5
MichaelH's Avatar
Drives: 2013 BRM ZL1 M6
Damn your a cam away from 700+whp lol nice numbers
2013 ZL1 M6 - Mods-in the works
Old vehicles
2010 CGM Camaro (sold)
Other Vehicles:
2008 Kawasaki ZX6R-115 RWHP in mid summer
2006 Chevy Trailblazer SS- For Sale; Lots of extras
MichaelH is offline   Reply With Quote
Old 11-10-2013, 10:30 AM   #25
ZO6 Bryan
ZO6 Bryan's Avatar
Here we go. Redone w/ SAE
Old 11-10-2013, 11:35 AM   #26
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 16 BMW M5 & 15 Z/28
My only issue is warranty is gone. Not cool in my book.
URBAN LEGEND is offline   Reply With Quote
Old 11-10-2013, 12:11 PM   #27
ZO6 Bryan
ZO6 Bryan's Avatar
Not at my dealership!
Old 11-10-2013, 06:04 PM   #28
Dega Man
Drives: ZL1
You still have some very good numbers for the money spent using pump gas.
