Old 11-09-2013, 08:07 PM   #1
The Beast ZL1
Drives: 2013 Camaro ZL1 Convertible
ZL1 Convertible Exhaust
Does anyone know of a catback system that is compatable for a 2013 convertible ZL1. So far most companies (Borla,Corsa) only make a system for a coupe and will not fit a convertible. Got it that the frame configuration is different but does anyone know of an aftermarket catback.
The Beast ZL1 is offline   Reply With Quote
Old 11-09-2013, 10:57 PM   #2
HDRDTD
To me the stock exhaust is perfect.
I very nice growl at idle and when you put the loud pedal down yet relatively quiet when cruising the xway.
HDRDTD is online now   Reply With Quote
Old 11-10-2013, 05:55 PM   #3
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
if you do not want headers then, best bet is to call around. If at worst you could always have a pipe shop bend and cut the borla to fit.
Not many ZL1 owners have gone with a cat back. The reason is the stock performs quite well. If your looking for the sound and performance go with the Headers and cats. This will give you both. I went for headers as this was the better money spent and love the sound.
JANNETTY RACING 750 ROUGH IDLE CAM PACKAGE
(681 RWHP & 643 RWTQ) = 783 CRANK HP & 740 CRANK TQ
AMMUSCLE is offline   Reply With Quote
Old 11-11-2013, 03:39 AM   #4
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
BILLY BOAT works i think from what i read,and a member has them on their vert...
you can purchase a aftermarket cross member to replace the factory brace that is even better..Also I think the factory Z28 exhaust is larger by 1/4 inch over the ZL1 if you wanted to go that way..it might work when it comes out..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
