Jason 98 TA
Old 11-09-2013, 08:42 PM   #1
Craig B
Craig B's Avatar
Drives: 2013 1LE
2 Step for M6
Can a 2 step be set up on a M6 to launch it @ the track? Need to be able to set an RPM to launch this tank. I see MSD has one. Thanks for any help.
Craig B is offline   Reply With Quote
Old 11-09-2013, 10:59 PM   #2
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Here's a read for you regarding the 2 step.
http://www.camaro5.com/forums/showthread.php?t=291534
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 11-10-2013, 12:02 AM   #3
Merc
In The Circle
Merc's Avatar
I use a Lingenfelter 2 step and CTAP on my M6 and go 1.66 60's @11.98 on Slick's & Skinnies and I'm just starting to dial it in. Bolt on only.
Old 11-10-2013, 02:55 PM   #4
Craig B
Craig B's Avatar
Drives: 2013 1LE
Bryan
Thank you sir. I will check it out.
Old 11-10-2013, 02:56 PM   #5
Craig B
Craig B's Avatar
Drives: 2013 1LE
I was looking @ that unit from Lingenfelter. It has a big wiring harness to it. Is it hard to install?
Old 11-10-2013, 03:30 PM   #6
Merc
In The Circle
Merc's Avatar
It's not to bad, but getting up under the dash to plug the CTAP into the clutch switch can be a challenge though.
